  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 34.7k Views 29 Watching
  • E
    E
    exilit
    wrote on last edited by exilit
    #41
    @sundberg84 Thank you for your reply. Do you see big differences regarding the safety?
    As far as I see both projects use a slow blow fuse and a thermal fuse to protect the AC-side.
    Sorry for digging deeper, but both projects look great. Yours seems to be better tested,
    but the other one has two relays. Hard to decide, which one to use :-).
    • E exilit
      @exilit - I think we both origin from the original discussion about the HLK-PM01: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers.
      If you read this you can pretty much see everything in the PCB (fuses, varistor and temp fuse to protect the HLK module).
        Martin Nicolaisen
        Hi @sundberg84 does it fit the fuga (scandinavian) wall socket? :=
        • M Martin Nicolaisen
          @martin-nicolaisen - Im not familiar with the fuga wall socket.
          I use standard round wall sockets (60cm). Can you point me to an image with dimensions ?
          gohanG 1 Reply Last reply
          • sundberg84S sundberg84
            @sundberg84 said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
            (60cm)
            Wow that's quite a wall plug
              (60cm)
              @gohan - lol :)
              60mm!!!!
              • meanmrgreenM
                meanmrgreenM
                meanmrgreen
                https://photos.app.goo.gl/JBIVogCZMp0mOCVh2
                I must have been drunk when I ordered this. Any idea what I have ordered? I ordered thru dirtypcbs somehow.
                Does look a little bit like this PCB but not really. Have I found a early version and drunk ordered 10 of em?
                  That looks like version 4.1
                  • N
                    N
                    Nightbodom
                    Hi folks, I manage to solder all the tiny pieces together and now I need some advice on uploading some code/sketch. To start with... is there any instruction for dummies on internet how to upload sketch through ICSP ? I have one arduino which can be programmer, but I don't know how to do it. Then there is question about powering circuit during uploading code.... is it OK if it's connect to AC power during uploading code? And finally, can anyone post some simple sketch for this board to check if everythiing is working? Thanks for help.
                    H 1 Reply Last reply
                    • N Nightbodom
                      H
                      H
                      hugch
                      @nightbodom Arduino have a tutorial for this https://www.arduino.cc/en/Tutorial/ArduinoISP
                      • N
                        N
                        Nightbodom
                        @hugch thanks for info. I also find this: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard for burning bootloader. And after that... how should I upload sketch?
                        • N Nightbodom
                          @nightbodom you connect it to a ISP programmer to the port. This will take care of 5v and Gnd as well so don't connect to AC during upload
                          • N
                            N
                            Nightbodom
                            @sundberg84 so I use ISP programmer for burning bootloader... but after that how can i upload sketch... usualy I use FTDI programmer for proMINI ect. but here I don't see TX/RX... so how do you upload sketch?
                            • N Nightbodom
                              #54
                              @nightbodom / either you use the isp to program the sketch without the bootloader or you can use the MysX connector where you will find all the necessary pins for ftdi.
                              • N
                                N
                                Nightbodom
                                @sundberg84 thanks for advice... I successfully load bootloader through ISP with spare Uno as programmer, then I try to load a sketch with ftdi but it didn't recognize PCB. I also try with arduino uno as ISP and it goes without problem. I use node manager sketch with relay and connect it to AC wires...and nothing!
                                After visual checking of PCB I check fuses and notice that thermal fuse is dead. So I think I burn it with soldering. Any advice how to solder it?
                                sundberg84S ben999B 2 Replies Last reply
                                • N Nightbodom
                                  @nightbodom - this can be a bit tricky. Some suggest cooling pincers or tongs to hold it while soldering. Myself I solder as normal and wait it to cool down before continue. As long as you are quick and not heat it up to much it should work.
                                  If you power the pcb with FTDI it should work without the fuse though. But I guess you power it through AC->HLK and use only RX/TX/GND and Rst from ftdi?
                                  • N Nightbodom
                                    ben999B
                                    ben999B
                                    ben999
                                    @nightbodom I use crocodile clips and get fairly good results with very few dead fuses....
                                    • G
                                      G
                                      Grave
                                      Is it possible to use with RFM69 modul?
                                        I guess not on as this module is using SMD NRF24 module
                                          @Grave - well @gohan is right, I cant fit a RFM69 module on this board.
