  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 34.7k Views 29 Watching
  • G
    G
    Grave
    I will try to rebuild it in eagle for RFM69. I think the space is there for an RFM69.
    • G
      G
      Grave
      Or I will build an adapter.
      • G
        G
        Grave
        Hi sundberg84,
        can you maybe take a look on my board. I have rebuild it so you can use it with rfm69 and NRF24 moduls. I have build an adapter, which will stand vertical behin the HLK-PM01.
        But how can I upload a picture?
        • G Grave
          Hi sundberg84,
          @grave Sure, you can just copy it into the message box.
          • G
            G
            Grave
            http://www.directupload.net/file/d/5020/dyi4y337_png.htm
            • G Grave
              @grave - at first it looks really good. Hard for me on a image to check every connection but I can not see any errors.
              • G
                G
                Grave
                Thanks,
                I can upload this evening the schematic and the board. But my schematic is not so fine as yours. I didn´t find pinheaders with 2mm distance, so they are single pads.
                • G
                  G
                  Grave
                  here are my schematic and the layout. I have build also an adapter for the rfm69 modul to use with an Sensebender Micro, because I had still place enough.
                  https://www.file-upload.net/download-13018265/InWallPCB71RFM69.brd.html
                  https://www.file-upload.net/download-13018266/InWallPCB71RFM69.sch.html
                  • G Grave
                    @grave - sorry, I dont run Eagle anymore so I cant check them.
                    • G
                      G
                      Grave
                      Do you use both, thermal fuse and the normal fuse? I can´t see it in your picture. I don´t find a normal fuse with 0,2A in Germany.
                      • G Grave
                        @grave yes I do for both temp and current protection. I want it to be overkill when it's diy. If you follow the links on openhardware you will find the security discussion.
                        • G
                          G
                          Grave
                          I have read it. But i didn´t find the fuse on the picture. Do you have one with both fuses? I have problems to find such fuses in this dimension in Germany. For the Varistor I have find one with 120 Jule. I think it´s ok.
                          • G Grave
                            @grave - I have bought my fuses from China. Im sure its possible to find on mouser or digikey,.
                            • S
                              sineverba
                              @sundberg84 sorry for question. i'm tryng to understand the scope for the SSR Relay. Can you explain me? Is it for some kind of safe or is it governable from the Atmega? Thank you!
                                It has smaller footprint and it doesn't wear out during time like mechanical relays
                                • S sineverba
                                  @sineverba it is much to learn and instead of me trying to make a half ok job I would suggest you search SSR vs mechanical relay. I think greatscott did a great Youtube video about it.
                                  • rzyliusR
                                    rzyliusR
                                    rzylius
                                    hi, I get constantly messages Arduino: 1.8.5 (Linux), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
                                    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xde
                                    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4c
                                    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9d
                                    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xaa
                                    is this hardware problem? I select Arduino Pro Mini board setting with AVRISP mkII programmer. are these ok?
                                    • rzyliusR rzylius
                                      @rzylius could be a bootloader or hardware settings. I would check the reset resistor. Do you know which bootloader is on or did you manage to upload one though iscp header?
                                      rzyliusR 2 Replies Last reply
                                      • sundberg84S sundberg84
                                        rzyliusR
                                        rzyliusR
                                        rzylius
                                        @sundberg84 said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                                        header?
                                        No, I did not. I used to work with arduinos, so this is the first time I bought and try mega328p. could you advise where to find a resource with step-by-step instructions on that?
                                          rzyliusR
                                          rzyliusR
                                          rzylius
                                          @sundberg84 , sorry, I meant I did not burn the bootloader and was not aware of that.
                                          Did you mean "reset capacitator", not resistor?
                                          And on that note, am I right that reset to iscp should go to DTS contact?
                                          thanks for help.
