  3. Home Assistant
  4. Basic question: Light sensors
3 Posts 2 Posters 2.1k Views 2 Watching
  • D
    D
    drock1985
    V_LIGHT_LEVEL; does home-assistant support the SI unit LUX? I have a sketch for a LUX sensor I am trying to integrate into HA but it gives a value back in % in the GUI.
    Thanks,
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      V_LIGHT_LEVEL should have the unit percent (%) according to the mysensors serial API. For lux use V_LEVEL and a custom unit of measurement, V_UNIT_PREFIX. Read more here:
      https://home-assistant.io/components/sensor.mysensors/#custom-unit-of-measurement
      See the example sketch here:
      https://home-assistant.io/components/sensor.mysensors/#example-sketch
      D 1 Reply Last reply
        D
        D
        drock1985
        @martinhjelmare
        Thanks martin. I think I got the code handled properly, but i'm getting a compile error.
         * Version 1.0 - Derrick Rockwell (@Drock1985)
        // Enable debug prints
        #define MY_NODE_ID 21
        #define MY_REPEATER_FEATURE //Enables Repeater feature for non-battery powered nodes.
        #include <OneWire.h>
        #include <BH1750.h>
        #include <Wire.h>
        #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
        int lastTemperature = 0;
        boolean metric = true;
        #define CHILD_ID_MOTION 1   // Id of the sensor child
        #define CHILD_ID_TEMP 2   // ID of Temperature Sensor
        #define CHILD_ID_LUX 3  // ID of Lux Sensor
        BH1750 lightSensor;
        // Initialize  messages
        MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
        MyMessage msgLux(CHILD_ID_LUX, V_LEVEL); //Sets up custom units (this case LUX for Light)
        MyMessage msgPrefix(CHILD_ID_LUX, V_UNIT_PREFIX); // Sends controller the LUX value instead of %
        uint16_t lastlux = 0;
          lightSensor.begin();
          sensors.begin();
          send(msgPrefix.set("Lux"));
        void presentation()  {
          sendSketchInfo("LuxMotionTempSensor", "1.0");
          present(CHILD_ID_MOTION, S_MOTION);
          present(CHILD_ID_LUX, S_LIGHT_LEVEL);
          uint16_t lux = lightSensor.readLightLevel();// Get Lux value
          Serial.println(lux);
          if (lux != lastlux) {
              send(msgLux.set(lux));
              lastlux = lux;
            int temperature = (((sensors.getTempCByIndex(0)) * 10.)) / 10.;
            #if COMPARE_TEMP == 1
            if (lastTemperature != temperature && temperature != -127.00 && temperature != 85.00) {
            #else
              send(msgTemp.set(temperature,1));
              lastTemperature = temperature;
            // Read digital motion value
        //  Serial.println(tripped);
          send(msgMotion(tripped?"1":"0"));  // Send tripped value to gw
          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
        I'll try it again tomorrow.
        Thank you again for pointing me in the right direction on custom units.
        My Projects
        2 Door Chime Sensor
