  3. Problem: I don't get an IP address
1 Posts 1 Posters 746 Views 1 Watching
  • jonehrJ
    jonehrJ
    jonehr
    I've made a serial gateway 2.0.0 and a binary switch 2.0.0 and this i working with my domotics. Now I'm trying to make an ethernet gateway and it seems to work exept that i don't ge an IP address. I've tried to disable #define MY_IP_ADDRESS but then it stops before I get the row IP:xxxxxxx
    What have I been doing wrong?
    Do I need to say I'm a newbie...
    This is what I see in the serial monitor:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 0.0.0.0
    0;255;3;0;9;TSP:SANCHK:OK
    This is what I uploaded:
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • REVISION HISTORY
    • Version 1.0 - Henrik EKblad
    • Contribution by a-lurker and Anticimex,
    • Contribution by Norbert Truchsess norbert.truchsess@t-online.de
    • Contribution by Tomas Hozza thozza@gmail.com
    • DESCRIPTION
    • The EthernetGateway sends data received from sensors to the ethernet link.
    • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
    • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
    • LED purposes:
      • To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
      • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
      • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
      • ERR (red) - fast blink on error during transmission error or recieve crc error
    • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,0,222 // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 203
    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_BUTTON_PIN 3
    //#define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN 9 // the PCB, on board LED
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
