  3. Home Assistant
  4. Remove duplicated mysensors in homeassistant front-end
7 Posts 2 Posters 5.6k Views 2 Watching
  • John NguyenJ Offline
    John Nguyen
    Anyone know how to remove duplicated sensors? I created a motion sensor with a CHILD_ID 1, then changed it to 2 during trouble-shooting and can't remove the original one now.
    0_1468785521756_upload-8419300b-ebbb-499e-912d-99c2be90aa30
    My configuration.yaml file:
    mysensors:
    gateways:
    - device: '/dev/ttyUSB0'
    baud_rate: 115200
    debug: true
    persistence: true
    version: '1.5'
    optimistic: false
    I tried clearing the 'mysensors1.pickle' file thinking that's where the sensor was being stored but it didn't work. I also tried using the persistence_file: 'path/mysensors.json' in my yaml file but that just breaks my homeassistant connection - anyone have a similar experience?
    My motion sensor test seems to work but still receiving an error message in the log. Not sure if this has anything to do with it.
    16-07-17 12:45:07 mysensors.mysensors: Error decoding message from gateway, bad data received:
    16-07-17 12:45:08 mysensors.mysensors: Error decoding message from gateway, bad data received: 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
    --- here's my code
    unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds) 120000
    // Initialize motion messagePED);
      Serial.begin(115200);
      gw.begin();
      gw.sendSketchInfo("Motion Sensor", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    Any help would be greatly appreciated.
      John Nguyen
      fixed 1 issue:
      doesn't apply.
      Here's the current log related to the main issue.
      16-07-17 13:13:24 mysensors.mysensors: child_id 1 already exists in children, cannot add child
      16-07-17 13:13:58 homeassistant.core: Home Assistant requested a restart.
      • John NguyenJ John Nguyen
        fixed 1 issue:
        doesn't apply.
        martinhjelmareM Offline
        martinhjelmare
        @John-Nguyen
        Deleting the persistence file and the backup file and restarting home assistant should have removed all sensors.
        I recommend using a json file as persistence file, as you can easily edit that file type and remove individual children etc. A pickle file is not easily editable. Make sure you have the correct path to the persistence file. The path in the example config is not a valid path.
          John Nguyen
          Thanks for the reply Martin.
          To clarify the steps:
          I need to add a persistence file in the .yaml file and ensure the path is a real path.
          persistence_file: 'path/mysensors.json'. Do I need to remove those pickle files? I'm assuming they were automatically created because I did not specify a .json file in my config.
          I actually tried to add persistence_file: 'path/mysensors.json' where path was = to the location of my .yaml file on my rpi3. When i restarted homeassistant, the system wouldn't come up. I tried rebooting the pi to no avail.
          Do I need to create an empty mysensors.json file first?
          Thanks again.
          • martinhjelmareM Offline
            martinhjelmare
            Just specify a valid path to the file in a folder that exists. I usually use the .homeassistant folder. You should not create the file. The file will be created when one of your sensors is first presented.
            Remove all old pickle files if you want to switch to json files. I don't know why home assistant didn't want to start.
              John Nguyen
              hmm. restarting HA/rebooting my pi3 doesn't generate the .json file. I'm pretty sure my config is correct now. Would you mind giving it a once over? I've already done a full re-install with updates and pretty much back to where I started.
              0_1468902123588_upload-80faaa68-12be-4bd0-ab45-1a04f28bdcb2
              0_1468902342951_upload-3390c33c-eb05-43c8-9b40-50dc4d268d27
              What else could I check?
                John Nguyen
                sweet, i got it. Thanks!
                spacing in my config. yaml file. used tab instead of space which is why notepad++ had that line in red.
                also had to move a few lines back under gateways: line.
                0_1468903338643_upload-532b435d-f7d7-4df1-8159-7a0e2c7d2b68
                12.1k
