  3. irlz44n not fully open using 3.3V Arduino
5 Posts 5 Posters 6.1k Views 5 Watching
    I have a project with a 3.3V sensor. To avoid trouble with logic levels, I use a 3.3V Pro Mini.
    In addition to reading the sensor, the Pro Mini handles dimming of a RGBW led stripe through irlz44n MOSFETs. However, the mosfets do not fully open at analogWrite(PIN, 255), nor at digitalWrite(PIN, HIGH).
    According to the datasheet, VGS(th) / Gate Threshold Voltage is 2V max. I thought that meant that the mosfet would be fully open at >2V?
    The mosfets do open fully if I use a 5V Pro Mini. They also open fully if I use a 3.3->5V logic level converter for the pwm pins.
    Does anyone know why this happens?
    Can anyone recommend a mosfet that works better for 3.3V (preferable as cheap and low on-resistance as the irlz44n)? I need to handle 2A at 12V.
      Mrlynx
      Many mosfet does not open fully on 3,3V. You have to check graph in datasheet when choosing mosfet.
      You can pull gate high with a resistor to 12v and use a npn transistor to pull it low.
      But that makes it default on. If sensor node fails all leds will be at 100%.
      My ledmodule uses IRLR2905 and is powered by a 5v promini.
      http://www.sa2avr.se
      • KoreshK
        KoreshK
        Koresh
        I tested this n-channel mosfet. It works fine (3.3v),
        • rollercontainerR
          rollercontainerR
          rollercontainer
          Nice... Ordered yesterday some IRLZ34n for my project... D'Oh!
          • L
            L
            LastSamurai
            I think I was using some of these for my rgbw controller and they seem to work just fine for me. As I switched to smd parts I can't really help you though :( My only idea would be to control them via some (smaller) transistor(s) that can be fully opened with 3.3V (or just redesign).
