  3. Raindrops Detection under v2
raindropsrainsensor
5 Posts 2 Posters 2.7k Views 4 Watching
  • D
    D
    davedeluxe
    I hope someone can help me.
    I used the example of Soil & Moist sensor v1.5.x to read a rain sensor.
    After I upgraded to v2 the setch no longer works. Does anyone have such a sensor already in use and has a sample code for me?
    I'm not so good at programming :(
    I use such a sensor: http://goo.gl/WywReQ
    Thank you!
    Dave
    • tlpeterT
      tlpeterT
      tlpeter
      wrote on last edited by tlpeter
      Hi Dave,
      Funny as i had the same problem.
      I tried using the digital pin with i could not get to work so i am using the A0 port now so have more than on and off.
      This is the sketch i am using and i use moisture as output to Domoticz:
       * Version 1.0 - Felix Haverkamp
       * Example sketch sending soil moisture in percentage alarm to controller
      // Enable debug prints
      //#define MY_RS485
      #define CHILD_ID 0   // Id of the sensor child
      int mostureSensor = 0;   // ANALOG Pin for Soil sensor, usally A0
      MyMessage msg(CHILD_ID, V_LEVEL);
      int lastSoilValue = -1;
        sendSketchInfo("Regensensor", "1.0");
        present(CHILD_ID, S_MOISTURE);
        int soilValue = map(analogRead(mostureSensor), 0, 1024, 100, 0);
        if (soilValue != lastSoilValue) {
          Serial.println(soilValue);
          send(msg.set(soilValue));
          lastSoilValue = soilValue;
      sleep(3000);
      • D
        D
        davedeluxe
        Hey,
        sounds great, I´ll test it as soon as possible.
        thank you!!!
        • D
          D
          davedeluxe
          It´s working and it´s better than before!
          Thank you so much, you´re the man of the day!
          • tlpeterT
            tlpeterT
            tlpeter
            You're welcome.
            It was for me also a struggle to get it working.
