  3. Node-RED
  4. How to add a serial device to use in node-red
Scheduled Pinned Locked Moved Node-RED
23 Posts 9 Posters 31.3k Views 9 Watching
  • AndurilA
    AndurilA
    Anduril
    wrote on last edited by Anduril
    Hey there,
    I successfully installed node-red and have it working. I want to build a flow the connects to my ESP gateway and relays all the information to a serial port without any logic. To my thought it should look like this:
    But as you can see, the serial port does not connect. Do I have to add the serial device manually before using it in node-red?
    And btw, how can I copy this one line of code with the complete flow?
    update: found the way to export the whole flow. Here the flow for the upper line:
    [{"id":"6172181f.bb6c88","type":"tcp in","z":"4e8861e9.29fed8","name":"","server":"client","host":"192.168.38.19","port":"5003","datamode":"stream","datatype":"buffer","newline":"","topic":"","base64":false,"x":259.5,"y":148,"wires":[["1c4e836e.cda87d"]]},{"id":"1c4e836e.cda87d","type":"serial out","z":"4e8861e9.29fed8","name":"","serial":"8c0eff27.9accc","x":581.5,"y":147,"wires":[]},{"id":"8c0eff27.9accc","type":"serial-port","z":"4e8861e9.29fed8","serialport":"/dev/ttyMySensors-nodered","serialbaud":"57600","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false}]
    • FotoFieberF
      FotoFieberF
      FotoFieber
      Does the use, you run node-red have permission to use the serial port?
      Maybe you can find a hint in you nodered-Logfile?
      • AndurilA
        AndurilA
        Anduril
        well that might be... it is not existing upto now. I thought node-red would create a device like socat is doing (the only programm connecting to serial devices I used so far). But seems not to be that way. How do I create a new serial device to then connect node-red to?
        • FotoFieberF
          FotoFieberF
          FotoFieber
          A serial device is usually automatically created by the OS when it detects serial hardware. On most linux systems they can be found in /dev/serial/....
          It seems, you want to create a serial device without hardware?
          You can use a pseudo-teletype on linux like /dev/ptyp5
          What is the exact use case for your need of a serial device?
          • AndurilA
            AndurilA
            Anduril
            I use a controller not capable of using ethernet gateways. By having a serial device connected to an ethernet stream via node-red would circumvent this limitation for me and also in future make it possible to use multiple controller at once (connecting additional controllers also to node-red and filter the messages).
            I tried socat some time ago, which is stated to have exactly this functionality: connecting a device to a tcp stream. But it came out that this tunnel is not stable and disconnects from time to time, causing a disconnect of my controller from MyS network.
            • tbowmoT
              tbowmoT
              tbowmo
              @Anduril
              You have to throw socat into the equation. It can mimic a serial port with two endpoints. One end you connect to in node-red, while the other you connect to from the controller.
              I use the following line to start socat:
              socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB21,mode=666,group=dialout,raw &
              this sends the command to the background (&). now you should be able to connect to /dev/ttyS81 in node-red, and use /dev/ttyUSB21 in your controller
              (they are named like this, because some controllers wants their serial ports to be ttyUSBxx)
              Now that you have thrown node-red into the mix, you can do all kinds of cool things, like change message content on the fly, between your controller, and the GW. (f.ex. I use node-red to invert lock state to domoticz, as it's the opposite of what is documented in mysensors). Or you can use node-red to inject test messages into the stream to your controller
              • AndurilA
                AndurilA
                Anduril
                @tbowmo @FotoFieber thank you both for your help. Hope a socat with 2 serial devices is more stable then a network based socat tunnel. That gave me disconnects after max 1-2 days. Now I will automate socat, node-red and all the other stuff, but it's too late to do that today :sleepy:
                • AndurilA
                  AndurilA
                  Anduril
                  ok things are running ok, but not perfect. I put all things into init.d scripts and works. But when not transfering any data over long periods (>1 day) connection seems to crash. I don't see new messages in my ttyUSB interface and in the debug node. When changing something (position of a node) and redeploying it works again. I will try with continous messages being sent and report. Does the ESP8266 somehow goes to sleep when nithing is happening and node-red loses connection then?
                  • S
                    shabba
                    I just spent an hour trying to figure this out and I'm not much wiser! I have a serial GW on a RPI-2. Domoticz is connected to ttyUSB0.
                    sudo socat PTY,link=/dev/ttySOCAT1,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB0,mode=666,group=dialout,raw &
                    so I have the socat link but I want to be able to run mycontroller just to test OTA on my anarduino that I flashed dualoptiboot on.
                    I thought I might be able to allow mycontroller to inject OTA messages onto the mysensors network via ttySOCAT1.
                    What have I misunderstood?
                    • FotoFieberF
                      FotoFieberF
                      FotoFieber
                      wrote on last edited by FotoFieber
                      I have written a simple serial/mqtt gateway for node.js to solve the problem of docker with serial devices. I then use MQTT Input and Output nodes in node-red. (This solution requires an mqtt-broker.)
                      var PORT = "/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0";
                      var PUB_TOPIC = "mysensors/1/out";
                      var SUB_TOPIC = "mysensors/1/in";
                      var mqtt    = require('mqtt');
                      var client  = mqtt.connect('mqtt://localhost');
                      client.on('connect', function () {
                        client.subscribe(SUB_TOPIC);
                      var serialport = require("serialport");
                      var SerialPort = serialport;
                      var serialPort = new SerialPort(PORT, {
                        baudrate: 115200,
                        parser: serialport.parsers.readline("\n")
                      serialPort.on("open", function () {
                        console.log('open');
                        serialPort.on('data', function(data) {
                          console.log(data);
                          client.publish(PUB_TOPIC,data);
                      client.on('message', function (topic, message) {
                        // message is Buffer
                        console.log(message.toString());
                        serialPort.write(message.toString());
                      • H
                        H
                        hiddenuser
                        wrote on last edited by hiddenuser
                        I have added
                        socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB026,mode=666,group=dialout,raw &
                        to /etc/rc.local
                        pi@Host-I:~ $ ls -l /dev/ttyU*
                        lrwxrwxrwx 1 root root 10 Mar 13 16:27 /dev/ttyUSB020 -> /dev/pts/1
                        lrwxrwxrwx 1 root root 10 Mar 13 16:27 /dev/ttyUSB026 -> /dev/pts/3
                        On /dev/ttyUSB020 I have my NRF24 module connected and Domoticz and use it with no issues. I want to bring Nod-Red into the equation so I created /dev/ttyUSB026
                        for some reason I cant connect Node-Red to /dev/ttyUSB020
                        Node-Red keeps saying
                        Error: Permission denied, cannot open /dev/ttyUSB020
                        petewillP 1 Reply Last reply
                        • H hiddenuser
                          I have added
                          to /etc/rc.local
                          petewillP
                          petewillP
                          petewill
                          @hiddenuser I know this is really late but I just ran into this problem and thought I'd post the solution in case any other people run into it. Thanks go to @mfalkvidd for providing the solution. You need to add this line:
                          sudo chmod 666 /dev/ttyUSB020
                          to /etc/rc.local
                          Here is a link on how to do that (and for more info): https://www.raspberrypi.org/documentation/linux/usage/rc-local.md
                          H 1 Reply Last reply
                          • petewillP petewill
                            to /etc/rc.local
                            H
                            H
                            hiddenuser
                            @petewill Thanks Pete!!! .. I shall give it a try.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @petewill @hiddenuser
                              The correct method is to add the user running node-red to the correct group on the system.. Probably the dialout group.
                              try
                              ls -l /dev/ttyUSB*
                              And note the group / user that is allowed to use the port. (as mentioned earlier, the group is probably dialout)
                              then issue the following command:
                              sudo usermod -a -G dialout <userName that node-red runs under>
                              then restart your rpi/computer/(whatever you are running on :))
                              Now you should have access to the ttyUSB20.
                              (I do not have access to a linux box right now, so I can not make screenshots / shell dumps of actual displayed data.. Can do this later today, when I'm at my private machine)
                              • tbowmoT tbowmo
                                try
                                ls -l /dev/ttyUSB*
                                petewillP
                                petewillP
                                petewill
                                @tbowmo Thanks! I just had a chance to go through this. I ran the command and looks like root has access?
                                pi@rpi:~ $ lrwxrwxrwx 1 root root 10 Nov  8 21:07 /dev/ttyUSB020 -> /dev/pts/1
                                Also it appears that my user that I think is running node-red (still called pi) already has access to the dialout group?
                                pi@rpi:~ $ awk -F':' '/dialout/{print $4}' /etc/group
                                pi
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @petewill
                                  when you run socat, you specify access rights with the mode option, which is set to 666.. So USB20 should already be read/writeable by all..
                                  The original problem by @hiddenuser was the "real" serialport for the arduino, which should help with the adding the user to dialout group.
                                  Normally you have to add your own user to the dialout group, as it is not added per default..
                                  • tbowmoT tbowmo
                                    @petewill
                                    petewillP
                                    petewillP
                                    petewill
                                    @tbowmo Ah, ok. That makes sense. My USB20 was created by the MySensors Raspberry Pi Gateway so that's where the disconnect is here. Sorry for clogging up this thread...
                                    • S
                                      smilvert
                                      wrote on last edited by smilvert
                                      I thought that it should be quite easy to use Node-red but I struggle with it and especially the serial port.
                                      I have created a passive node:
                                      // Enable debug prints
                                      #define MY_GATEWAY_SERIAL
                                      // Enable passive mode
                                      #define MY_PASSIVE_NODE
                                      #define MY_REPEATER_FEATURE
                                      // Passive mode requires static node ID
                                      #define MY_NODE_ID 0
                                      // #define MY_RADIO_NRF24
                                      //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
                                      //#define MY_RADIO_NRF5_ESB
                                      //#define MY_RADIO_RFM95
                                      #define CHILD_ID_HUM 0
                                      #define CHILD_ID_TEMP 1
                                      #define CHILD_ID_BINARY 2
                                      // Initialize general message
                                      MyMessage msgBinary(CHILD_ID_BINARY, V_STATUS);
                                      int counter = 0;
                                      float temperature = 0;
                                      float humidity = 0;
                                      int binary = 0;
                                        // Send the sketch version information to the gateway and controller
                                        sendSketchInfo("Passive node", "1.0");
                                        present(CHILD_ID_HUM, S_HUM);
                                        present(CHILD_ID_BINARY, S_BINARY);
                                        // generate some random data
                                        counter ++;
                                        if (counter == 20 ){
                                          temperature = 0;
                                          humidity = 0;
                                          counter = 0;
                                        else
                                          temperature = 25.0 + random(0,30)/10.0;
                                          humidity = 55.0 + random(-20,20);
                                        if (binary == 0){
                                          send(msgBinary.set(binary,2));
                                          binary = 1;
                                        }else {
                                          binary = 0;
                                        send(msgTemp.set(temperature,2));
                                        send(msgHum.set(humidity,2));
                                        wait(1000);
                                      To generate some data and I get the data in to Node-Red and can send the data to Influx/Grafana but the output to a socat serial port is strange. I have tested and I got the best result when I use a baudrate of 9600.
                                      When I look to the output data in a terminal a lot of messages are missing or has the format of:
                                      0;1;1;0;0;26.00^J^M0;0;1;0;1;67.00^J^M0;1;1;0;0;27.40^J^M0
                                      Have the most simple flow at the moment:
                                      with this properties 0_1510606605539_Screenshot from 2017-11-13 21-56-13.png
                                      sudo socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB026,mode=666,group=dialouraw
                                      How should I configure the serial output?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        looks like your socat line is wrong..
                                        It should be
                                        sudo socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB026,mode=666,group=dialout,raw
                                        Also, try and connect node-red to ttyS81 instead, as it's the "source". (probably doesn't matter much, but it makes more sense to me :) )
                                        • sburlotS
                                          sburlotS
                                          sburlot
                                          I had the same problem: I have a serial GW on the PI that outputs data on /tty/USB20, and is used by Domoticz.
                                          I want to test MQTT via node-red, so I need to read this serial port from node-red.
                                          I tried:
                                          sudo socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB20,mode=666,group=dialout,raw
                                          But nothing appears on ttyS81: I tried with
                                          sudo screen /dev/ttyS81 115200
                                          and of course on node-red, I set up a node that reads from ttyS81 and outputs to debug: the serial port is opened successfully, but nothing appears on debug.
                                          If I use
                                          sudo screen /dev/ttyUSB20 115200
                                          I can see some data coming
                                          I'm no expert with socat (I learned its existence via this forum post), so any help is appreciated.
                                          Thanks,
                                          Stephan
