  3. Water floor heater system
5 Posts 2 Posters 2.0k Views 3 Watching
  • malukoM
    malukoM
    maluko
    wrote on last edited by maluko
    hi,
    since month that i wondering if could built a controller for the water floor heater system,
    i have solar panel with a pump that bring warm water to circulate on floor pipes.
    so my goal was built the controller for this, I started with small code after I added more features and ended up creating a board with components.
    very soon , it is a temperature comparator with LCD , a button to temporarily turn on the LCD and the other to change the summer / winter cycle.
    But when i arrived at finish part i discover a bug, that is when there is a rapid power failure the system does not restart , it is with the LCD turned on but not the system works.
    just as I am a curious coder , having not been able to solve the problem, i am asking for your help in such problem.
    /* Este sketch lê 2 DS18B20 "1-Wire" digital
    com LCD e botao
    #include <Wire.h>
    #include <OneWire.h>
    #include <Bounce2.h>
    // -----------Configurações personalizadas-------------------------
    #define ONE_WIRE_BUS 3         // DS18B20 Ligado ao pin X no arduino
    #define rele 7             // Relé ligado ao pin X no arduino
    #define Tempo_lcd_ligado 2500 // define o tempo do lcd ligado após ligar botão (milisegundos)
    #define Diferenca 1.0          // Define a diferença entre sensores para ativar relé
    #define botao_lcd A3          // Escolher pin de entrada para botão
    #define botao_verao A0         // escolher Modo verao/inverno
    // my sensors --botão
    #define CHILD_ID 7              //
    #define BUTTON_PIN  7
    // configura onewire para comunicar com qq dispositivo OW
    OneWire oneWire(ONE_WIRE_BUS);
    // Envia a referençia oneWire para Dallas Temperature.
    // configura o endereço LCD I2C, descobrir endereço ver outro skecht
    LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
    //definir estado inicial do relé
    int state1 = 0;
    int state2 = digitalRead(botao_verao);
    // defiinir estado inicial do botão
    int buttonState = 0;
    // definir endereço dos sensores de temp 1-Wire, descobrir ver outro sketch .
    DeviceAddress solpainel = { 0x28, 0xFF, 0xEC, 0xDA, 0xA4, 0x15, 0x01, 0x8C };
    DeviceAddress bomba = { 0x28, 0xFF, 0x2D, 0x17, 0x00, 0x16, 0x03, 0x46 };
    // numero de dispositivos 1wire encontrados
    int numberOfDevices;
    //Variaveis para controlo logico
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    //---- mysensors - botão
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msg1(CHILD_ID,V_TRIPPED);
    float   Temp1, Temp2;   //  grava para comparação
    float differential1 = 0.0 ;
    float differential2 = 0.0 ;
    int invalidCount = 0;
    //codigo corre sempre que se inicia.
    void setup(void)
      delay(6000);
      // iniciar serial port
      Serial.begin(9600);
      // Start up the library
      Serial.println ("ligando sensores one wire");
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.1");
         gw.present(i, S_TEMP);
      //---------------------------------------------mysensor botao
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      // locate devices on the one wire bus
      Serial.println("");
      Serial.print("encontrando dispositivos 1-wire...");
      Serial.println ("");
      Serial.print("encontrado ");
      Serial.print(sensors.getDeviceCount(), DEC);
      Serial.println(" dispositivos.");
      lcd.begin(16,2);
      Serial.print("Ligando LCD");
      Serial.print("\n\r");
    // ------- Pisca 3 vezes  -------------
      for(int i = 0; i< 3; i++)
        lcd.backlight();
        delay(250);
        lcd.noBacklight();
        delay(250);
      lcd.backlight(); // finish with backlight on
    //-------- Escreve carateres no LCD ------------------
      lcd.setCursor(0,0);
      lcd.print("Comparador do");
      delay(1000);
      lcd.setCursor(0,1);
      lcd.print("Aquecimento");
      delay(2000);
      lcd.clear();
     // set the resolution to 10 bit (good enough?)
      sensors.setResolution(solpainel, 10);
      sensors.setResolution(bomba, 10);
      //delay (1500);
      lcd.noBacklight();
     //definir pin output
      pinMode(rele, OUTPUT);
      pinMode(botao_lcd, INPUT);
      pinMode(botao_verao, INPUT);
      delay (1000);
    void printTemperature(DeviceAddress deviceAddress)
      float tempC = sensors.getTempC(deviceAddress);
      if (tempC == -127.00) {
        Serial.print("Erro a obter temperatura");
      } else {
        Serial.print("C: ");
        Serial.print(tempC);
    void loop(void)
      gw.process();
      Serial.print("A atualizar temperaturas...\n\r");
      gw.sleep(conversionTime);
         #if COMPARE_TEMP == 1
         #else
      Serial.print("Temp do painel: ");
      printTemperature(solpainel);
      Serial.print("Temp da bomba: ");
      printTemperature(bomba);
      Serial.println("");
      Serial.println("");
      Serial.print ("estado do rele: ");
      Serial.println(state1);
      Serial.println("");
      buttonState = digitalRead(botao_lcd);
        if (buttonState == HIGH){
          // Botao pressionado.
          Serial.println("Botao pressionado - HIGH");
          lcd.on();
          lcd.setCursor(0,0);
          buttonState = digitalRead(botao_verao);
           if (buttonState == HIGH) {
            lcd.print("Modo: Verao");}
           else {
            lcd.print("Modo: Inverno");
          delay (1000);
          lcd.setCursor(0,0);
          lcd.print("T.Painel :");
          lcd.print(sensors.getTempC(solpainel));
          lcd.setCursor(15,1);
          lcd.print("C");
         lcd.backlight();
          lcd.setCursor(0,1);
          lcd.print("T.Entrada:");
          lcd.print(sensors.getTempC(bomba));
          lcd.setCursor(15,0);
          lcd.print("C");
          delay (Tempo_lcd_ligado);
          lcd.clear();
          lcd.off();
        else{
          // botao nao pressionado.
          Serial.println("Botao nao pressionado - LOW");
    //Sensors for logic
    Temp1 = sensors.getTempC(bomba);
    Temp2 = sensors.getTempC(solpainel);
         //diferença entre Solpainel e bomba
          differential1 = Temp2-Temp1;
          differential2 = Temp1-Temp2;
          Serial.print("Diferenca para inverno e:");
          Serial.println(differential1);
          Serial.println("");
          Serial.print("Diferenca para Verao e:");
          Serial.println(differential2);
          Serial.println("");
          //logic1
           if (differential2 >= (Diferenca)) { // comparara temps,
            (state2 = 1);
            digitalWrite(rele, LOW);
            Serial.print("bomba verao ligada");
            Serial.print("\n\r");}
           else {
            (state2 = 0);
            digitalWrite(rele, HIGH);
            Serial.print("bomba verao desligada");
            Serial.println("");
            Serial.print("\n\r");}}
         else {
           if (differential1 >= (Diferenca)) { // comparara temps,
            (state1 = 1);
            Serial.print("bomba inverno ligada");
           else {
            (state1 = 0);
            Serial.print("bomba inverno Desligada");
            Serial.println("");
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg1.set(value==LOW ? 1 : 0));
         oldValue = value;
    delay (1000);
    • K
      K
      koen01
      I've seen this when I set the radio power to max and power the LCD via the nano at the same time. The LCD takes to much so the rest doesn't work....
      malukoM 1 Reply Last reply
      • malukoM
        malukoM
        maluko
        if i delete all mysensor code it work fine, but i want to send at my domoticz server.
        thanks
        • K koen01
          malukoM
          malukoM
          maluko
          @koen01
          what have you done to this not happen?
          • malukoM
            malukoM
            maluko
            the strange think is if i wait a few seconds this goes on with normality.
