  2. Bug Reports
  3. RelayWithButtonActuator
9 Posts 7 Posters 5.9k Views 2 Watching
    maglo18
    wrote on last edited by maglo18
    I try to use Relay With Button Actuator 1.4 but I have problem. When i press button everything working well. Problem is when I restart node and want to change status form gateway, it doesn't work then. When i press button only once then i can remote from getaway.
    My code:
    #include <Bounce2.h>
    #define RELAY_PIN_2  8
    #define RELAY_PIN  7 // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN_2  4
    #define BUTTON_PIN  3 // Arduino Digital I/O pin number for button
    #define CHILD_ID_2 2
    #define CHILD_ID 1 // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    Bounce debouncer2 = Bounce();
    int oldValue2=0;
    bool state2;
    MyMessage msg(CHILD_ID,V_LIGHT);
    MyMessage msg2(CHILD_ID_2,V_LIGHT);
      gw.sendSketchInfo("Double Relay & Button", "0.1");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
       // Setup the button
      pinMode(BUTTON_PIN_2,INPUT);
      digitalWrite(BUTTON_PIN_2,HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.attach(BUTTON_PIN_2);
      debouncer2.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      gw.present(CHILD_ID_2, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      digitalWrite(RELAY_PIN_2, RELAY_OFF);
      pinMode(RELAY_PIN_2, OUTPUT);
      state = gw.loadState(CHILD_ID);
      state2 = gw.loadState(CHILD_ID_2);
      digitalWrite(RELAY_PIN_2, state2?RELAY_ON:RELAY_OFF);
      gw.process();
      debouncer.update();
      debouncer2.update();
      // Get the update value
      int value = debouncer.read();
      int value2 = debouncer2.read();
      if (value != oldValue && value==0) {
          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (value2 != oldValue2 && value2==0) {
          gw.send(msg2.set(state2?false:true), true); // Send new state and request ack back
      oldValue2 = value2;
      if (message.isAck()) {
      if (message.type == V_LIGHT && message.sensor == 1 && strlen(msg.getString()) != 0) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
      else if(message.type == V_LIGHT && message.sensor == 2 && strlen(msg.getString()) != 0){
         state2 = message.getBool();
         gw.saveState(CHILD_ID_2, state2);
         // Write some debug info
         Serial.print(message.sensor);
      maglo18
      I prepare sketch with 2 x button and 2 x relays and 8 x dallas. Could some one look at if it right, because i have problem remote relays after restart node. I don't know it is problem witch sketch or server software.
      Log from gataway:
      12-10-2014 18:57:55: 0;0;3;0;9;send: 0-0-2-2 s=11,c=1,t=2,pt=0,l=1,st=ok:0
      12-10-2014 18:57:55: 0;0;3;0;9;send: 0-0-2-2 s=11,c=1,t=2,pt=0,l=1,st=ok:1
      12-10-2014 18:57:54: 0;0;3;0;9;send: 0-0-2-2 s=12,c=1,t=2,pt=0,l=1,st=ok:0
      12-10-2014 18:57:54: 0;0;3;0;9;send: 0-0-2-2 s=12,c=1,t=2,pt=0,l=1,st=ok:1
      12-10-2014 18:57:53: 0;0;3;0;9;send: 0-0-2-2 s=11,c=1,t=2,pt=0,l=1,st=ok:0
      12-10-2014 18:57:52: 0;0;3;0;9;send: 0-0-2-2 s=11,c=1,t=2,pt=0,l=1,st=ok:1
      12-10-2014 18:54:39: 0;0;3;0;9;read: 2-2-0 s=0,c=1,t=0,pt=7,l=5:22.6
      12-10-2014 18:54:26: 0;0;3;0;9;send: 0-0-203-2 s=11,c=1,t=2,pt=0,l=1,st=fail:0
      12-10-2014 18:54:26: 0;0;3;0;9;send: 0-0-203-2 s=12,c=1,t=2,pt=0,l=1,st=fail:0
      12-10-2014 18:54:26: 0;0;3;0;9;send: 0-0-203-2 s=12,c=1,t=2,pt=0,l=1,st=fail:1
      12-10-2014 18:54:25: 0;0;3;0;9;send: 0-0-203-2 s=11,c=1,t=2,pt=0,l=1,st=fail:1
      Code:
      #include <OneWire.h>
      #define CHILD_ID_2 12
      #define CHILD_ID 11 // Id of the sensor child
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
      int oldValue2=0;
      bool state2;
      //temp
      #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
      #define MAX_ATTACHED_DS18B20 8
      unsigned long SEND_FREQUENCY = 30000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
      unsigned long lastSend;
      unsigned long sendTime;
      OneWire oneWire(ONE_WIRE_BUS);
      //temp
      int numSensors=0;
      boolean metric = true;
      MyMessage msg3(0,V_TEMP);
         // Startup OneWire
        sensors.begin();
        gw.sendSketchInfo("Double Relay & Button, Temp", "0.1");
           gw.present(i, S_TEMP);
       // Setup the button
         // Setup the button
        gw.process();
        debouncer.update();
        oldValue = value;
        oldValue2 = value2;
        unsigned long now = millis();
        if ((now - lastSend) > SEND_FREQUENCY) {
           Serial.print("dziala wysylanie temp");
            if (lastTemperature[i] != temperature && temperature != -127.00) {
              gw.send(msg3.setSensor(i).set(temperature,1));
        lastSend=now;
        if (message.type == V_LIGHT && message.sensor == 11) {
        else if(message.type == V_LIGHT && message.sensor == 12){
      • K
        K
        kanchana
        I have the same problem even with the one button . I can't control the light from Vera unless I have push the button after the restart . Also I noticed when i use the button to switch the light on and off from the button in Vera i can't see the status being updated . Any one experiencing the same problem ?
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          it is hard to read your code.
          edit it putting it between three back ticks (```)
          usually to the left of the 1 key on a USA keyboard
          • K
            K
            kunall
            I second that. I have exactly the same issue. I have to physically toggle the switch before operating it from OpenHab.
            • K
              K
              kimnguu204
              Hello All,
              i got the same problem, node can send information to gateway but can't receive command from controller.
              do you know how to test communication between Gateway and Nodes?
              I used Serial Gateway, i connected to gateway COM port and send command like 10;2;1;0;1;1;1\n to turn on relay but my node can't turn relay on.
              When i press the button from NODE, it sent the update status to gateway,
              • Ivan ZI
                Ivan ZI
                Ivan Z
                Gateway not see ACK flag. Please fix this bag
                Lib version 1.5, Node & gate = 1.5
                RelayButton log
                send: 42-42-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=fail:0
                Button value:0
                Button value:1
                send: 42-42-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=fail:1
                Button value:0
                Button value:1
                Button value:0
                Button value:1
                Button value:0
                Button value:1
                Button value:0
                Button value:1
                Gateway log
                2015-08-04 18:52:07 Set: Node:42; Sensor:1; Type:1; Ack:0; Sub:2; Msg:0
                2015-08-04 18:52:07 Set: Node:42; Sensor:1; Type:1; Ack:0; Sub:2; Msg:1
                2015-08-04 18:52:08 Set: Node:42; Sensor:1; Type:1; Ack:0; Sub:2; Msg:0
                2015-08-04 18:52:08 Set: Node:42; Sensor:1; Type:1; Ack:0; Sub:2; Msg:1
                  That's not a gateway log...
                  • Ivan ZI
                    Ivan ZI
                    Ivan Z
                    Sory. Bad NRF transmitter
