  3. Battery booster / voltage regulator
4 Posts 3 Posters 2.3k Views 3 Watching
  • xydixX
    xydixX
    xydix
    Hi guys.
    On my battery powered sensors, pro minis with voltage regulator removed, with battery booster i have a problem.
    My battery booster give about 3,6V-3,8V.
    With Mysensors 2.0 this cause a problem under presentation. I don't know why.
    Is there a way to get my boosters closer to 3,3V without replacing them?
    I guess a resistor is a bad idea? Would probably cause unstable voltage when the power consumption changes?
    Any thouhts on this.
    This is the booster i use:
    http://www.ebay.com/itm/181612513907?rmvSB=true
    • scalzS
      scalzS
      wrote on last edited by scalz
      hi, you can use a diode. drop voltage would be 0.7v depending of the ref (you can try with 1n4148 depending of current drawn by your circuit, but there are lot of ref). or a schottky diode for low drop voltage (0.3v).
      • xydixX
        xydixX
        xydix
        Thank you for answer @scalz
        While the node sleep it consumes 0,2uA. Transmitting is around 20mA when it try to present itself.
        0,7V will give me 3-3,1V for this node i measring right now.
        Isn't that a little low? What do you think?
        I dont know how sensitive the pro mini and nrf-radio is if the voltage drop under 3.3V.
        Will the diode consume power?
        Looked at schottky diode on eBay. Any specific i should choose?
        Nca78N 1 Reply Last reply
        • xydixX xydix
          Nca78N
          Nca78N
          @xydix no worries with voltage below 3.3V. On the pro mini the BOD (which will reset arduino if voltage is too low) is set at 2.7v so you have a lot of margin. I use some sensor with CR2032 cell battery which has a maximum voltage of 3.1 and it's not a problem. You need to be over the BOD voltage that's your only limit. If you are using a 8MHz pro mini it can run at this frequency down to 2.4V at least. NRF24 will run as low as 1.9V.
