  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 225.9k Views 53 Watching
  • T
    tssk
    So I ordered Arduino Uno for programming my Pro Minis. And going to experiment with 2xAA or 3xAA setup without step up booster (they are whining anyway so I will be happy if I get rid of it :)
    Thank everyone for help!
    • N
      N
      nekitoss
      I have a problem: when batteries go around 2.7V radio will stop transmitting. Board still take current, but no messages.
      I'm using own board with barebone 328p (8mHz internal) and SMD/mini nrf24l01 (pretty shure china)
      Did anyone had same issues?
      I've checked programmaticaly (yes, it is possible!) my fuse bits: Low=0xE2, High=0xD2, Extended=0xFE (0x06)
      (BOD = 1.8V)
      I've have three same boards (water leak) and used other not-yet-installed with specially made low-voltage regulated source (with 2200 uF capacitor and resistor load to eliminate voltage drop at transmission) to test - same result.
      Sometimes i can go lower to 2.5V but not guaranteed, sometimes even corrupted messages (i.e. node id 168 instead 8).
      Tests were without UART, only MYSController to monitor messages flooding each 5sec to approve life.
      Did anyone had same problems with nrf24l01 modules? All i see people say the can go to around 2.0 V.
      According to article https://www.gammon.com.au/power (and datasheet)
      at 8mHz i'm safe down to 2.4V (something like that i also measured)
      nrf should go down to 1.9...
      Also it would be great to add into advanced section possible voltages and problems with NiMh, china modules & 2.7V(if not only me), [not]possible currents from coin cells and metioned article.
      • zboblamontZ zboblamont
        @nekitoss Not sure where you got your information but my Gas Node is on it's second year running on the same two Varta AA alkalines and been down to -20 on more than a few occasions last winter, typically 4 months below -10... Currently the temperature is -3 and headed to -8 overnight, voltage is 2.98, will probably need to replace them in autumn 2019...
        N
        N
        nekitoss
        @nekitoss said in 💬 Battery Powered Sensors:
        It would be great to add to this arctle that if you want to be battery powered outdoors with temperature below zero - you have to use lithium batteries (FR6 for AA) (yes, batteries, not li-ion accumulators!) (for example ultimate lithium energizer, also could be found lithium batteries from other vendors), because Alkaline (LR6 for AA) will be frozen and loose their capacity heavily. If i remember it is >50% at -10 C and death at -20 C. Same problem for li-ion accumulators - when liquid is frozen - electrons are stucked...
        Also would be great to add some link about battery/accumulator types, advanteges and disadvantages, but i have no links in english, easy-to-read and in one place...
        But i have very great link about battery-powering that really should be added here, but in advanced section:
        http://www.gammon.com.au/power
        @zboblamont how your alkaline batteries experience after 2 years(temperatures, lasting time)? my freshly installed (yes, it was long develop and test...) Lithium AA - when few weeks ago it was -20 .. stopped transmitting! Fixed resetting power when it become little warmer. Possibly same problem with 2.7V or exactly there may be wrong BOD...
        skywatchS zboblamontZ 2 Replies Last reply
        • N nekitoss
          skywatchS
          skywatchS
          skywatch
          #304
          @nekitoss If I were you I;d reflash the bootloader and chec again. I got my pro mini with ebyte nrf24 to work and register with the gateway all the way down to 1.63V, so somethingi is wrong if you are loosing it at 2.7V (which is also as it happens, a BoD setting for atmel 328p). For the test I used minicore bootloader iwth Bod disabled and 2MHz clock. Bench power supply for the voltage variation.
          N 1 Reply Last reply
          • N nekitoss
            zboblamontZ
            zboblamontZ
            zboblamont
            @nekitoss No problems with alkaline power, 6 - 18 months now on 2xAA down to ca -15c, battery voltage reported ca 2 or 3 times per day.
            I vaguely recall reading an article on lithium and alkaline battery behaviour in extreme cold weather, the alkalines were the better performers.
            Note that the pro-minis here use onboard booster and LDO which provide stable 3.3v all the way down to ca 1.8v battery death, so battery voltage is unrelated to system voltage unlike your setup. They also use rfm69s (433MHz) which are better able to penetrate structural obstacles.
            Bear in mind that if you have comms problems this can substantially reduce battery life as it does not quickly waken, perform the task and go back to deep sleep
            • skywatchS
              skywatchS
              skywatch
              #306
              @mfalkvidd
              Nice job on updating the infor BTW :)
              • Puneit ThukralP
                Puneit ThukralP
                Puneit Thukral
                Adding on to this.. If we use a map function to convert the battery level like this, then it shows up as an attribute in HomeAssistant and Homekit
                Map function works and not the percent. The percent always shows as zero in Homekit.
                Hope this helps someone!
                void battery()
                  long batteryMillivolts = hwCPUVoltage();
                  int batteryV =batteryMillivolts /1000 + 0.5;
                  auto batteryLevel = map(batteryV,EMPTY_BATTERY, FULL_BATTERY, 0, 100);
                  if (batteryLevel > 100)
                  {batteryLevel=100;}
                #ifdef MY_DEBUG
                  Serial.print("Battery voltage: ");
                  Serial.print(batteryMillivolts / 1000.0);
                  Serial.println("V");
                  Serial.print("Battery Level ");
                  Serial.print(batteryLevel);
                  Serial.println(" %");
                  if (oldBatteryLevel != batteryLevel) {
                    sendBatteryLevel(batteryLevel);
                    send(msgV.set(batteryV,2));
                    oldBatteryLevel = batteryLevel;
                ![Home Assistant](812c9e02-8b21-44dc-ab8d-04559bf38462-image.png image url)
                IHomeKit
                • skywatchS skywatch
                  N
                  N
                  nekitoss
                  @skywatch Thank you very much! Your advice helped. Not shure what it was on BOTH devices - my mistake or some corruption of fuses/program.
                  On first device (where i found problem) - there were different fuse bits (but according to my eyes BOD was even disabed, but not shure). On the second (where i tested) fuses were checked and were correct. I tried to play with fuses and erase chip... and something strange happened - or chip memory was broken or i can't verify program when box "erase flash and eeprom" is checked... so i took fresh nano, programmed it and resoldered MCU into the second device.
                  So both devices now are fixed and tested - both work till ~1.9V.
                  Thanks, you saved my brains!
                  skywatchS 1 Reply Last reply
                  • N nekitoss
                    skywatchS
                    skywatchS
                    skywatch
                    @nekitoss Yay! :)
                    Well done on getting it working!
                    • G
                      G
                      Gilles BILLARD
                      Hi from France;
                      I've tried everything I could and no way to put My temp. sensor to deep sleep.
                      so I went back to the very beginning with a bare Pro-Min 3.3v and I tryed this:
                      #include <LowPower.h>
                      pinMode(13, OUTPUT);
                      LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
                      digitalWrite(13, HIGH);
                      delay(1000);
                      digitalWrite(13, LOW);
                      My boad is going to sleep;
                      YEEEESSS ! the pb is NOT comming from the board itself....eating a bunch ou micro amp;
                      Then I've added the minimum requested to make a MySensor extension and I tried this:
                      #define MY_RADIO_NRF24 // Choix du module radio
                      #define MY_RF24_PA_LEVEL (RF24_PA_HIGH) //CHOIX: RF24_PA_MIN; RF24_PA_LOW; RF24_PA_HIGH; RF24_PA_MAX
                      #define RF24_CHANNEL 76
                      #define RF24_DATARATE RF24_250KBPS
                      delay(1000);
                      The boad stays awaken (4 mA current)
                      So may be the problem is comming from LowPower library...
                      I tried this minimal prgm recommended in a tutorial, using MySensors library and SLEEP function:
                      #define MY_RADIO_RF24
                      uint32_t SLEEP_TIME = 900000; // sleep time between reads (in seconds * 1000 )
                      int oldBatteryPcnt = 0;
                      #define FULL_BATTERY 3 // 3V for 2xAA alkaline. Adjust if you use a different battery setup.
                      sendSketchInfo("Battery Meter", "1.0");
                      // get the battery Voltage
                      int batteryPcnt = batteryMillivolts / FULL_BATTERY / 1000.0 * 100 + 0.5;
                      oldBatteryPcnt = batteryPcnt;
                      sleep(SLEEP_TIME);
                      NO WAY AGAIN; The board is still eating 4mA all the way long.
                      I'm lost !!!! Please HELP ME ....
                      E 1 Reply Last reply
                      • G Gilles BILLARD
                        Hi from France;
                        delay(1000);
                        delay(1000);
                        sleep(SLEEP_TIME);
                        E
                        E
                        evb
                        @Gilles-BILLARD Using the lowpower lib and mysensors lib together will probably give conflicts, so you should avoid it. MySensors lib implements the same low power tricks.
                        When doing the latest test sketch, are you doing this also with a bare pro-mini 3.3V?
                        So not connected to anything, no radio, no sensor?
                        Try the same latest sketch, but set everything inside the loop() in comment except the sleep line.
                        • G
                          G
                          Gilles BILLARD
                          Thanks EVB;
                          1. Yes; Last test with a bare pro-mini 3.3v
                          2. I did that...
                          //    // get the battery Voltage
                          //    long batteryMillivolts = hwCPUVoltage();
                          //    int batteryPcnt = batteryMillivolts / FULL_BATTERY / 1000.0 * 100 + 0.5;
                          //    if (oldBatteryPcnt != batteryPcnt) {
                          //      sendBatteryLevel(batteryPcnt);
                          //      oldBatteryPcnt = batteryPcnt;
                            sleep(SLEEP_TIME);
                          Again : 4.2mA (no sleep )
                          So sad ! :disappointed_relieved:
                          • skywatchS
                            skywatchS
                            skywatch
                            #313
                            @Gilles-BILLARD IT took me some time to work it out and get it working.
                            I suggest you install MiniCore library - it is easy to follow simple steps and takes a minute or two.
                            Then burn a bootloader into the atmega, I always use 3.3V, disable BoD and 4MHz or 8MHz internal clock. You can use one arduino to program another or just get a USB programmer from your preferred source (about $2).
                            Once your pro mini is booeloaded and you have your sketch in installed , remove the Power LED (or the series resistor for the LED) and also remove the voltage regulator (or cut the tracks as shown in the battery powered page).
                            You won't get down to <10uA in sleep unless you do all of this.
                            G 1 Reply Last reply
                            • G
                              G
                              Gilles BILLARD
                              wrote on last edited by Gilles BILLARD
                              #314
                              Thanks Skywatch,
                              My Pro-Mini boards are comming from Aliexpress, so, I was also thinking about the bootloader... what else ?
                              I'll do what you explain ASAP and be back to say what...
                              BTW: I already have cut the tracks powering the LED & regulator
                                G
                                G
                                Gilles BILLARD
                                #315
                                @skywatch NO WAY ! So bad !
                                I burned the MiniCore bootloader quite eazily using a second Pro-Mini loaded with Arduino BootLoader ( juste a file name error; looking for optiboot_flash_atmega328p_UART1_115200_16000000L_B5.hex but only optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex on the folder, so I just changed 0-->1 in the file name) and the résult was:
                                avrdude: Version 6.3-20201216
                                Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                Copyright (c) 2007-2014 Joerg Wunsch
                                     System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/avrdude.conf"
                                     Using Port                    : COM7
                                     Using Programmer              : stk500v1
                                     Overriding Baud Rate          : 19200
                                     AVR Part                      : ATmega328P
                                     Chip Erase delay              : 9000 us
                                     PAGEL                         : PD7
                                     BS2                           : PC2
                                     RESET disposition             : dedicated
                                     RETRY pulse                   : SCK
                                     serial program mode           : yes
                                     parallel program mode         : yes
                                     Timeout                       : 200
                                     StabDelay                     : 100
                                     CmdexeDelay                   : 25
                                     SyncLoops                     : 32
                                     ByteDelay                     : 0
                                     PollIndex                     : 3
                                     PollValue                     : 0x53
                                     Memory Detail                 :
                                                              Block Poll               Page                       Polled
                                       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                                     Programmer Type : STK500
                                     Description     : Atmel STK500 Version 1.x firmware
                                     Hardware Version: 2
                                     Firmware Version: 1.18
                                     Topcard         : Unknown
                                     Vtarget         : 0.0 V
                                     Varef           : 0.0 V
                                     Oscillator      : Off
                                     SCK period      : 0.1 us
                                avrdude: AVR device initialized and ready to accept instructions
                                Reading | ################################################## | 100% 0.04s
                                avrdude: Device signature = 0x1e950f (probably m328p)
                                avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                To disable this feature, specify the -D option.
                                avrdude: erasing chip
                                avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex"
                                avrdude: writing flash (0 bytes):
                                Writing | ################################################## | 100% 0.00s
                                avrdude: 0 bytes of flash written
                                avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex:
                                avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex:
                                avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex contains 0 bytes
                                avrdude: reading on-chip flash data:
                                Reading | ################################################## | 100% -0.00s
                                avrdude: verifying ...
                                avrdude: 0 bytes of flash verified
                                avrdude: reading input file "0x0f"
                                avrdude: writing lock (1 bytes):
                                Writing | ################################################## | 100% 0.04s
                                avrdude: 1 bytes of lock written
                                avrdude: verifying lock memory against 0x0f:
                                avrdude: load data lock data from input file 0x0f:
                                avrdude: input file 0x0f contains 1 bytes
                                avrdude: reading on-chip lock data:
                                Reading | ################################################## | 100% 0.01s
                                avrdude: 1 bytes of lock verified
                                avrdude done. Thank you.
                                Then I loaded it with Blink demo...
                                At this point all's OKay. Both Po-Mini are blinking
                                Blink
                                Then I've loaded the 2nd with that:
                                uint32_t SLEEP_TIME = 4000;  // sleep time (in seconds * 1000 )
                                pinMode(LED_BUILTIN, OUTPUT);
                                  sendSketchInfo("Test Prgm", "1.0"); // Send the sketch version information to the gateway and Controller
                                  digitalWrite(LED_BUILTIN, HIGH);
                                delay(1000);
                                  digitalWrite(LED_BUILTIN, LOW);
                                delay(1000);
                                sleep(SLEEP_TIME);
                                and...
                                the result is...
                                No blinking
                                NO BLINK
                                (draining more or less 2mA; Varying quickly from 1600uA to 2000uA; I should put a scope probe on that....)
                                YveauxY T 2 Replies Last reply
                                • G Gilles BILLARD
                                       Using Port                    : COM7
                                       PAGEL                         : PD7
                                       BS2                           : PC2
                                       RETRY pulse                   : SCK
                                       Timeout                       : 200
                                       StabDelay                     : 100
                                       CmdexeDelay                   : 25
                                       SyncLoops                     : 32
                                       ByteDelay                     : 0
                                       PollIndex                     : 3
                                       PollValue                     : 0x53
                                       Memory Detail                 :
                                       Hardware Version: 2
                                       Topcard         : Unknown
                                       Vtarget         : 0.0 V
                                       Varef           : 0.0 V
                                       Oscillator      : Off
                                       SCK period      : 0.1 us
                                  Blink
                                  delay(1000);
                                  delay(1000);
                                  sleep(SLEEP_TIME);
                                  and...
                                  the result is...
                                  No blinking
                                  NO BLINK
                                  YveauxY
                                  YveauxY
                                  @Gilles-BILLARD from the photos it seems you didn't connect a radio. If that is the case, the loop will not be entered and your arduino won't sleep!
                                  • YveauxY Yveaux
                                    G
                                    G
                                    Gilles BILLARD
                                    @Yveaux
                                    YESSSSSS !<
                                    That was the last problèm to solve.
                                    Back with my own MySensors routine all is perfect ! (8uA in sleep mode)
                                    I am very happy now and I thank all those who assisted me.
                                    You've made my day !
                                    Gilles
                                    • G Gilles BILLARD
                                      @Yveaux
                                      YESSSSSS !<
                                      Gilles
                                      skywatchS
                                      skywatchS
                                      skywatch
                                      @Gilles-BILLARD @Yveaux beat me to it! - But I bet you are a very happy person after that - it is easy when you know how! :)
                                      • G Gilles BILLARD
                                             Using Port                    : COM7
                                             PAGEL                         : PD7
                                             BS2                           : PC2
                                             RETRY pulse                   : SCK
                                             Timeout                       : 200
                                             StabDelay                     : 100
                                             CmdexeDelay                   : 25
                                             SyncLoops                     : 32
                                             ByteDelay                     : 0
                                             PollIndex                     : 3
                                             PollValue                     : 0x53
                                             Memory Detail                 :
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                        Blink
                                        delay(1000);
                                        delay(1000);
                                        sleep(SLEEP_TIME);
                                        and...
                                        the result is...
                                        No blinking
                                        NO BLINK
                                        tssk
                                        @Gilles-BILLARD Damn! Why did I order UNO if I could use another Pro Mini for programming... :)
                                        • T tssk
                                          G
                                          G
                                          Gilles BILLARD
                                          @tssk My Pro-Mini's are 3.3V, so this way I avoid the resistors dividers wiring to change 5V (Uno) to 3.3 (Pro-Mini);
                                          May be you love creating problems where there are none ;-)
