  2. Announcements
  • lakshmcL
    lakshmcL
    lakshmc
    @marceloaqno After installing broker and gateway fresh, seems to be working. Thanks for your help.
    • M marceloaqno
      @pete1450 Could you send the debug log with the connection errors?
      P
      P
      pete1450
      @marceloaqno
      Ran as root and made sure I didn't have mysgw already running:
      rm -r MySensors/
      git clone https://github.com/mysensors/MySensors.git --branch master
      cd MySensors/
      ./configure --my-controller-ip-address=192.168.1.136 --my-port=5003 --my-rf24-irq-pin=15
      make
      root@raspberrypi:~/downloads/MySensors# ./bin/mysgw -d
      mysgw: Starting gateway...
      mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.1
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:INIT:TSP OK
      mysgw: TSM:INIT:GW MODE
      mysgw: MCO:REG:NOT NEEDED
      mysgw: connect: Connection refused
      mysgw: failed to connect
      mysgw: Eth: connect
      M 1 Reply Last reply
      • b0rmannB
        b0rmannB
        b0rmann
        every few days mysgw randomly dies :(
        Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:READ,5-5-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
        Jan 19 06:40:01 pi mysgw[17960]: Sending message on topic: mysensors/out/1/5/255/3/0/21
        Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:READ,0-5-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
        Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:BC
        Jan 19 06:40:01 pi systemd[1]: mysgw.service: main process exited, code=killed, status=11/SEGV
        Jan 19 06:40:01 pi systemd[1]: Unit mysgw.service entered failed state.
        • P pete1450
          @marceloaqno
          rm -r MySensors/
          cd MySensors/
          make
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: Eth: connect
          marceloaqno
          Code Contributor
          @pete1450 If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
          P 1 Reply Last reply
          • AndurilA
            AndurilA
            Anduril
            @marceloaqno what is the correct configure option to make this gatway connect to an ethernet gateway and let a serial-only-controller connect to it. I suppose to use the pty option, but didn't got this working. As said above, socat and nodered are no option.
            • M marceloaqno
              P
              P
              pete1450
              wrote on last edited by pete1450
              #326
              @marceloaqno Well that fixed the connection issue. Now I'm just back to square one where pressing start doesn't do anything. Why do I not need to specify my controllers ip? That is the ip for my veralite. Whats the use case for that option.
              • b0rmannB b0rmann
                marceloaqno
                Code Contributor
                @b0rmann Could you provide the following information?
                • Your RPi model and which linux distribution you are using.
                • gcc version
                • The version and options you used to build the gateway (./configure --option)
                • The number of nodes on your network that sends messages to the gateway.
                • The broker you are using for MQTT and its version
                • AndurilA Anduril
                  marceloaqno
                  Code Contributor
                  @Anduril Sorry, the gateway does not support what you're trying to do.
                  • P pete1450
                    marceloaqno
                    Code Contributor
                    @pete1450
                    I can't help you with this, I've never used the Vera controller. You need to search in the Vera settings where you set this option. If Vera supports being a server and opening a port for the gateway to connect, then you use the --my-controller-ip-address option.
                      Michael Curtis
                      Does anyone know if the Raspberry implementation have a UserPassword option for ./configure MQTT
                      • M Michael Curtis
                        Michael Curtis
                        @Michael-Curtis Nevermind, I fixed it.... you ned to add :
                        --my-mqtt-password=<PASS>   MQTT password
                        --my-mqtt-client-id=<ID>    MQTT client id.
                        Under "cat"
                        And for the actual options under "opt do"
                        --my-mqtt-user=*)
                            CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
                        --my-mqtt-password=*)
                            CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
                        then just add those option flags to the ./configure and run make
                        • Roberto Mo CaR
                          Roberto Mo CaR
                          Roberto Mo Ca
                          what means "5VReg -> 3.3V" in raspberry? can connect directly to 3.3V or if requied connecto to 5V with regulator to obtain 3.3v?
                            macvictor
                            Hi :) Does anybody know how to use MY_SIGNING_NODE_WHITELISTING in gateway raspbery pi? Where I must create/edit white list with my nodes?
                            • OliverDogO
                              OliverDogO
                              OliverDog
                              first sorry about the basics question but I think many people have the same questions and can't find the answers:
                              After connecting the radio (including IRQ on 15pin) and the info LEDs to the GPIO, how to config it?
                              1. Do I need to configure all the info on the same command, or can I send the command "./configure --" many times for different configs?
                              2. Do I need to configure it as a MQTT gateway?
                              3. Where did the 127.0.0.1 IP come from?
                              4. Does MQTT use internet connection?
                              5. Why do you talk about Serial Gateway here, once we have a specific type for it? this type is about using GPIO only, isn't it? That is confusing!!!
                              • OliverDogO
                                OliverDogO
                                OliverDog
                                trying to config on a Home Assistant Rpi.
                                Sorry again for the newbie questions...!!!
                                • Erik TammingaE
                                  Erik TammingaE
                                  Erik Tamminga
                                  Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
                                  If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
                                  I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
                                  Regards,
                                  Erik
                                  • Roberto Mo CaR Roberto Mo Ca
                                    marceloaqno
                                    Code Contributor
                                    @Roberto-Mo-Ca If you are using the nrf24 PA/LNA version you need to use a 5V->3.3V regulator otherwise you can connect to the 3.3v pin.
                                    S 1 Reply Last reply
                                    • M macvictor
                                      marceloaqno
                                      Code Contributor
                                      #338
                                      @macvictor For the MY_SIGNING_NODE_WHITELISTING, you can uncomment and edit it in MyConfig.h or add it to the examples/mysgw.cpp.
                                      • OliverDogO OliverDog
                                        marceloaqno
                                        Code Contributor
                                        @OliverDog
                                        You execute ./configure once with all your options to set your gateway.
                                        You need to decide what type of gateway you want to build: ethernet, serial or mqtt:
                                        https://www.mysensors.org/build/select_gateway
                                        Take a look at the link and let me know if you still have any questions.
                                        • OliverDogO
                                          OliverDogO
                                          OliverDog
                                          thaks @marceloaqno but I was wondering there was a new type of gateway named Raspberry Gateway, were we could connect the radio directly on the GPIO and config it locally, without internet, because of that I also would like to know if MQTT uses internet connection.
                                          I actually use a serial gateway connected to Pi USG and it works without internet...
                                          I just want to have only one device...
