  2. Announcements
  • E ericvdb
    Would it be possible to connect a I2C display to display some information, and drive that display from within mysGatway.cpp ?
    marceloaqno
    Code Contributor
    @ericvdb I2C is the next thing I'll do as soon as I finished adding support for signing.
    • jerseyguy1996J
      jerseyguy1996J
      jerseyguy1996
      @marceloaqno Amazing....adding the short delay fixed it! I'm curious why that is the case. Do you have an explanation for that?
      M 1 Reply Last reply
      • jerseyguy1996J jerseyguy1996
        marceloaqno
        Code Contributor
        #23
        @jerseyguy1996 It's probaly related to this: https://www.mysensors.org/build/raspberry#improving-throughput-for-nrf24
        jerseyguy1996J 1 Reply Last reply
        • Patrik SöderströmP
          Patrik SöderströmP
          Patrik Söderström
          Just installed MySensors on one of my Raspberry. Works really great! :) Picks up the other node I have over NRF without trouble. Next I will try and add some sensors directly on the Raspberry.
          Big thanks for this!
          • M marceloaqno
            jerseyguy1996J
            jerseyguy1996J
            jerseyguy1996
            wrote on last edited by jerseyguy1996
            #25
            @marceloaqno Oh that makes sense :-) I'm wondering if that is also what is causing my problem with reconnecting when the node loses contact with the gateway. The node connects perfectly when the gateway is running but if it loses the connection for any reason it can't seem to be able to reconnect and just goes into a loop of attempts. Here is the debug info from the node:
            This is the initialization output
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=3)
            TSM:FPAR
            TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSP:MSG:PAR OK (ID=0, dist=1)
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=3)
            TSM:UPL
            TSP:PING:SEND (dest=0)
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
            TSP:MSG:PONG RECV (hops=1)
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
            TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
            TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=ok:Sensor Node
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
            TSP:MSG:SEND 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
            TSP:MSG:SEND 3-3-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
            TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
            TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
            TSP:MSG:SEND 3-3-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
            Request registration...
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
            TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
            Node registration=1
            Init complete, id=3, parent=0, distance=1, registration=1
            TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:32.00
            TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=0,st=ok:0
            TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:39
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:76
            So far so good!
            Next I shutdown the gateway to simulate a lost connection:
            !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=fail:1
            !TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=1,st=fail:1
            !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=2,st=fail:74
            !TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=3,st=fail:32.00
            !TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=4,st=fail:0
            !TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=5,st=fail:1
            !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=6,st=fail:1
            !TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=7,st=fail:1
            !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=8,st=fail:72
            Its still doing what I expect it to do. It begins attempting to reconnect:
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            Fixing Transport Layer
            TSM:FPAR
            TSM:FPAR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            Still working as intended. Next I start the gateway back up to see if it will reconnect. Here is where I have problems.
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=3)
            TSM:UPL
            !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
            TSP:CHKUPL:FAIL (hops=255)
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=3)
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            It looks like the first few messages to initialize the reconnect go through okay and then it misses everything afterwards. If I reset the node it will connect again with no problems.
            What do you think might be happening here?
            • ysinhY
              ysinhY
              ysinh
              A tiny hint for the users of domoticz :
              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
              make
              sudo ./examples_linux/mysGateway -d
              :) i hope this helps
              then in the hardware setup
              MySensors Gateway USB
              serial port: /dev/ttyUSB20
              carlylerC 1 Reply Last reply
              • G
                G
                gvorster
                I'm a bit confused about gateway and controller. Can I use a Pi as both gateway and controller?
                  Yes!
                  • jerseyguy1996J
                    jerseyguy1996J
                    jerseyguy1996
                    I'm using the virtual serial port option and one of the things that I notice is that the port gets created where the tty group only has write access.
                    pi@raspberrypi:/dev/pts $ ls -l
                    total 0
                    crw--w---- 1 root tty  136, 0 Oct 10 18:49 0
                    I can change it manually but if I reboot the raspberry pi it goes back to write access only. How do I get it to be created with 'rw' access?
                    • jerseyguy1996J
                      jerseyguy1996J
                      jerseyguy1996
                      Nevermind....When I set "--my-serial-groupname=tty" in ./configure it works.
                      • NiklasON
                        NiklasON
                        NiklasO
                        Where do I put the security stuff for the signing?
                        • NiklasON NiklasO
                          GertSandersG
                          GertSandersG
                          GertSanders
                          wrote on last edited by GertSanders
                          #32
                          @NiklasO
                          Signing is not yet supported in the current Raspi Gateway.
                          NiklasON 1 Reply Last reply
                          • GertSandersG GertSanders
                            @NiklasO
                            NiklasON
                            NiklasON
                            NiklasO
                            wrote on last edited by NiklasO
                            #33
                            @GertSanders said:
                            @NiklasO
                            Ok, thanks.
                            I now see that in this thread. Did not see the earlier discussion in the comments on the main page. Hope to see support soon.
                            I have disabled signing for the time being but I want it on ofc. ;)
                            • b0rmannB
                              b0rmannB
                              b0rmann
                              what's about RS485 transport on raspberry pi? especially from wired RS485 mysensors network to MQTT
                              • R
                                R
                                raulandresmoch
                                Can you use the RP as gateway and also as controller?
                                • R raulandresmoch
                                  NiklasON
                                  NiklasON
                                  NiklasO
                                  #36
                                  @raulandresmoch
                                  Sure. I use this with Domoticz on my Pi.
                                  "MySensors Gateway with LAN interface" as hardware pointing to 127.0.0.1:5003
                                  Also, I can connect with other controller software like MYSController from my other computers to my Pi-IP at port 5003.
                                  • b0rmannB b0rmann
                                    marceloaqno
                                    Code Contributor
                                    @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
                                    b0rmannB 1 Reply Last reply
                                    • DrJeffD
                                      DrJeffD
                                      DrJeff
                                      The line above
                                      ./examples_linux/mysGatewaymsyGateway -h
                                      needs to be corrected to
                                      ./examples_linux/mysGateway -h
                                      Thanks for all the hard work! Awesome!
                                      • DrJeffD DrJeff
                                        The line above
                                        @DrJeff Thanks for noticing. It should be fixed now.
                                        • M marceloaqno
                                          b0rmannB
                                          b0rmannB
                                          b0rmann
                                          @marceloaqno
                                          i am ready. after compiled and upload example node sketch i have on rs485 to usb convertor (/dev/ttyUSB0) output nice mysensors data:
                                          01 FF 00 58 07 02 FF FF - FF 02 03 07 FF 03 66 04
                                          testing playground photo: 0_1476563966730_playground.jpg
