  2. Announcements
  • OliverDogO OliverDog
    thaks @marceloaqno but I was wondering there was a new type of gateway named Raspberry Gateway, were we could connect the radio directly on the GPIO and config it locally, without internet, because of that I also would like to know if MQTT uses internet connection.
    I actually use a serial gateway connected to Pi USG and it works without internet...
    I just want to have only one device...
    marceloaqno
    Code Contributor
    @OliverDog You can configure the RPi to be any of the 3 types: ethernet, serial or mqtt, with the nrf24 attached to it.
    OliverDogO 1 Reply Last reply
    • M marceloaqno
      OliverDogO
      OliverDogO
      OliverDog
      @marceloaqno WOWWW
      now I understood... but I think this is not clear on the build steps...
      I choose a Serial Gateway, but on that lines, they say:
      "If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:"
      So I assumed the serial gateway is the same I already use...
      So, where do I get directions to config a serial gateway with the radio attached to the GPIO?
      M 1 Reply Last reply
        @marceloaqno WOWWW
        marceloaqno
        Code Contributor
        @OliverDog Which controller are you using(or are planning to use)?
        • Erik TammingaE Erik Tamminga
          Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
          If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
          I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
          Regards,
          Erik
          marceloaqno
          Code Contributor
          @Erik-Tamminga Some pins may have some restrictions, I couldn't find any good info about that. Try using another pin (GPIO 25).
          • M marceloaqno
            OliverDogO
            OliverDogO
            OliverDog
            @marceloaqno I already use Home Assistant with a Serial Gateway connected on pi USB.
              marceloaqno
              Code Contributor
              @OliverDog Home Assistant supports ethernet gateways, I recommend you go with that.
              ./configure --my-gateway=ethernet --my-transport=nrf24
              (The default settings is to use ethernet and nrf24, so you could omit them)
              and add to it any of your custom options.
              • MadhiasM
                MadhiasM
                Madhias
                wrote on last edited by Madhias
                #347
                I have a question regarding the --my-serial-groupname option: since I start the gateway under an user account with sudo, the gateway device ([EDIT] symlink) will be created with ownership root:root. Shouldn't it be created with root:dialout (as I chose dialout as group in my case)?
                [DELETED]
                • MadhiasM Madhias
                  [DELETED]
                  marceloaqno
                  Code Contributor
                  @Madhias /dev/pts/2 it's the one who holds the specified group ownership
                  MadhiasM 1 Reply Last reply
                  • M marceloaqno
                    MadhiasM
                    MadhiasM
                    Madhias
                    @marceloaqno OK, many thanks for that hint!
                    I was wrong from the beginning on, since I thought my configuration for the gateway was correct because of --my-serial-groupname=dialout - but that was not compiled. I edited now the mysgw.cpp manually (there was tty instead of dialout; and of course there was all the time the warning when compiling...). Now it works! Without chmod, or chowning anything later!
                      macvictor
                      @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                      Gateway:
                      1. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-mqtt-password=PASS --my-mqtt-user=USER --my-rf24-encryption-enabled --my-signing=software --my-signing-request-signatures --my-signing-request-gw-signatures-from-all
                      2. make
                      3. sudo make install
                      4. sudo systemctl enable mysgw.service
                      5. sudo systemctl start mysgw.service
                      6. sudo mysgw --gen-soft-hmac-key
                      7. sudo mysgw --set-soft-hmac-key=02417628BC1573CC380...
                      8. sudo mysgw --gen-soft-serial-key
                      9. sudo mysgw --set-soft-serial-key=00762CD152B868F7EB
                      10. sudo mysgw --gen-aes-key
                      11. sudo mysgw --set-aes-key= A790AD78B2D8B4DBBB5B2C4B9DD6DAF3
                      Node:
                      1. Load script SecurityPersonalizer.ino
                      2. Uncomment and send sketch to arduino
                      #define USE_SOFT_SIGNING
                      #define STORE_SOFT_KEY
                      #define USER_SOFT_KEY
                      #define STORE_SOFT_SERIAL
                      #define STORE_AES_KEY
                      #define USER_AES_KEY
                      #define MY_SOFT_HMAC_KEY 0X2,0X41,0X76,0X28,0XBC,0X15,0X73,0XCC,0X38...
                      #define MY_AES_KEY 0XA7,0X90,0XAD,0X78,0XB2,0XD8...
                      1. Read all value from EPROM (test save):
                      Personalization sketch for MySensors usage.
                      EEPROM configuration:
                      SOFT_HMAC_KEY | 02417628BC1573CC380DE0FADF7C87D7D3C77272A783E6E438786A07C3A8C6CF
                      SOFT_SERIAL   | 39BB1370C289643251
                      AES_KEY       | A790AD78B2D8B4DBBB5B2C4B9DD6DAF3
                      Personalization is now complete.
                      1. Send sample sketch to arduino:
                      //!< Enable debug prints to serial monitor
                      //!< Enable signing related debug prints to serial monitor
                      #define MY_DEBUG_VERBOSE_SIGNING
                      // Enable NRF24L01 radio type
                      // Select soft signing
                      #define MY_SIGNING_SOFT
                      // Enable lockdown of node if suspicious activity is detected
                      //-->> #define MY_NODE_LOCK_FEATURE
                      // Enable node whitelisting
                      //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
                      // Enable this if you want destination node to sign all messages sent to this node.
                      // SETTINGS FOR MY_SIGNING_SOFT
                      #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
                      // Add repeater function to this sensor
                      #define MY_REPEATER_FEATURE
                      #include <Bounce2.h>
                      #define RELAY_PIN  4    // Arduino Digital I/O pin number for relay
                      #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
                      #define CHILD_ID 1      // Id of the sensor child
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      Bounce debouncer = Bounce();
                      int oldValue = 0;
                      bool state;
                      MyMessage msg(CHILD_ID, V_LIGHT);
                        // Setup the button
                        pinMode(BUTTON_PIN, INPUT);
                        // Activate internal pull-up
                        digitalWrite(BUTTON_PIN, HIGH);
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                        pinMode(RELAY_PIN, OUTPUT);
                        state = loadState(CHILD_ID);
                        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
                      void presentation()  {
                        sendSketchInfo("Relay & Button", "1.0");
                        present(CHILD_ID, S_LIGHT, "Switch Secure Sensor", false);
                         Example on how to asynchronously check for new messages from gw
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                      //  if (value != oldValue && value == 0) {
                          send(msg.set(state ? false : true), true); // Send new state and request ack back
                      //  oldValue = value;
                        delay(5000);
                        if (message.isAck()) {
                          // Change relay state
                          state = message.getBool();
                          // Store state in eeprom
                          // saveState(CHILD_ID, state);
                          // Write some debug info
                          Serial.print(message.sensor);
                      And finally in Arduino Serial Monitor I see:
                      0 MCO:BGN:INIT REPEATER,CP=RNNRAS-,VER=2.1.1
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSF:SID:OK,ID=105
                      15 TSM:FPAR
                      16 Will not sign message for destination 255 as it does not require it
                      58 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2065 !TSM:FPAR:NO REPLY
                      2067 TSM:FPAR
                      2068 Will not sign message for destination 255 as it does not require it
                      2110 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      4117 !TSM:FPAR:NO REPLY
                      4119 TSM:FPAR
                      4120 Will not sign message for destination 255 as it does not require it
                      4162 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6169 !TSM:FPAR:NO REPLY
                      6171 TSM:FPAR
                      6172 Will not sign message for destination 255 as it does not require it
                      6214 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8221 !TSM:FPAR:FAIL
                      8222 TSM:FAIL:CNT=1
                      8224 TSM:FAIL:PDT
                      and in gateway i see:
                      sudo mysgw -d
                      mysgw: Starting gateway...
                      mysgw: MCO:BGN:INIT GW,CP=RNNG-S-,VER=2.1.1
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:INIT:TSP OK
                      mysgw: TSM:INIT:GW MODE
                      mysgw: MCO:REG:NOT NEEDED
                      mysgw: MCO:BGN:STP
                      mysgw: MCO:BGN:INIT OK,TSP=1
                      mysgw: Attempting MQTT connection...
                      mysgw: connected to 127.0.0.1
                      mysgw: MQTT connected
                      mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
                      mysgw: TSF:MSG:READ,171-107-54,s=221,c=2,t=131,pt=4,l=25,sg=0:-1418183441
                      mysgw: !TSF:MSG:PVER,3=2
                      mysgw: TSF:MSG:READ,135-23-172,s=20,c=3,t=200,pt=7,l=25,sg=0:-0.00000178
                      mysgw: !TSF:MSG:PVER,1=2
                      mysgw: TSF:MSG:READ,34-66-89,s=168,c=1,t=9,pt=1,l=25,sg=0:56
                      mysgw: TSF:MSG:READ,223-46-240,s=112,c=5,t=192,pt=5,l=11,sg=1:1407647670
                      mysgw: TSF:MSG:REL MSG
                      mysgw: !TSF:RTE:240 UNKNOWN
                      mysgw: !TSF:MSG:SEND,223-0-240-240,s=112,c=5,t=192,pt=5,l=11,sg=1,ft=0,st=NACK:1407647670
                      mysgw: TSF:MSG:READ,183-139-129,s=37,c=6,t=155,pt=1,l=21,sg=0:48
                      mysgw: !TSF:MSG:PVER,0=2
                      mysgw: TSF:MSG:READ,139-214-233,s=61,c=3,t=193,pt=7,l=0,sg=1:0.00000000
                      mysgw: !TSF:RTE:233 UNKNOWN
                      mysgw: !TSF:MSG:SEND,139-0-233-233,s=61,c=3,t=193,pt=7,l=0,sg=1,ft=0,st=NACK:0.00000000
                      mysgw: TSF:MSG:READ,83-33-7,s=179,c=2,t=27,pt=4,l=25,sg=1:-2057270722
                      mysgw: TSF:MSG:READ,110-148-67,s=113,c=0,t=158,pt=1,l=9,sg=1:251
                      mysgw: TSF:MSG:READ,75-209-102,s=204,c=7,t=25,pt=1,l=11,sg=1:52
                      mysgw: TSF:MSG:READ,184-209-235,s=58,c=1,t=140,pt=6,l=23,sg=1:1DC404A5401119FACF0000000000000000000000000000
                      mysgw: TSF:MSG:READ,172-203-51,s=140,c=2,t=173,pt=0,l=1,sg=1:?
                      mysgw: !TSF:RTE:51 UNKNOWN
                      mysgw: !TSF:MSG:SEND,172-0-51-51,s=140,c=2,t=173,pt=0,l=1,sg=1,ft=0,st=NACK:?
                      Where is problem?
                      M pepsonP rajeev2301R 5 Replies Last reply
                      • M macvictor
                        Gateway:
                        2. make
                        Node:
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValue = 0;
                        bool state;
                          // Setup the button
                          debouncer.update();
                          delay(5000);
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        15 TSM:FPAR
                        2067 TSM:FPAR
                        4119 TSM:FPAR
                        6171 TSM:FPAR
                        8221 !TSM:FPAR:FAIL
                        8222 TSM:FAIL:CNT=1
                        8224 TSM:FAIL:PDT
                        sudo mysgw -d
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        Where is problem?
                        marceloaqno
                        Code Contributor
                        @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
                          macvictor
                          @marceloaqno Thanks for help :+1: This was my problem 😀
                            how do I set user and password to access the mqtt broker? I tried do add --my-mqtt-password=PASS --my-mqtt-user=USER other parameters but they get ignored
                              macvictor
                              @gohan edit configure file and add this code:
                              --my-mqtt-user=*)
                                  CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
                              --my-mqtt-password=*)
                                  CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
                              after this code:
                              --my-signing-request-gw-signatures-from-all*)
                                      signing_request_signatures=true
                                      CPPFLAGS="-DMY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL $CPPFLAGS"
                              this is about 408 number line and use flag --my-mqtt-password and --my-mqtt-client-id when you run configure, thats all. =)
                              blaceyB gohanG 2 Replies Last reply
                              • M macvictor
                                --my-mqtt-user=*)
                                after this code:
                                blaceyB
                                blaceyB
                                blacey
                                wrote on last edited by blacey
                                #355
                                @macvictor It would be great if you would submit this as a GitHub Pull Request. If you aren't comfortable with that, then I would encourage you to at least open a MySensors issue to add these RPI configuration options.
                                • TeknorT
                                  TeknorT
                                  Teknor
                                  wrote on last edited by Teknor
                                  #356
                                  When using RPI as a GW for MySensors, the CPU load increases from 18% to around 80 %. I am using a RPI II model B. I'd love the have the GW running on the Raspberry, and avoid a USB connected Arduino.
                                  Does somebody else experience the same?
                                  M carlylerC 2 Replies Last reply
                                  • TeknorT Teknor
                                    macvictor
                                    @Teknor I use RPI III as GW and all node connect with gw used nRF24L01. My CPU now usage 5-10%, but I installed "Home Assistance" + homebridge + some plugins.
                                    TeknorT 1 Reply Last reply
                                    • M macvictor
                                      TeknorT
                                      TeknorT
                                      Teknor
                                      #358
                                      @macvictor Thanks. My RPI 2 is running Domoticz, RFXcom GW and 2x 3MP cameras with motion detection using Motioneye. Might be something wrong with my MySensors GW setup...
                                      • TeknorT Teknor
                                        carlylerC
                                        carlylerC
                                        carlyler
                                        @Teknor I tend to agree something is wrong, but I think it really on depends how many nodes and how often you're sending data.
                                        rpi3 + GPIO nrf24l01 + openhab2 + 8 nodes + packet received, on average 1 / 5s :
                                        top - 06:29:37 up 2 days, 22:33,  2 users,  load average: 0.26, 0.24, 0.19
                                        KiB Mem:    947732 total,   903420 used,    44312 free,   175364 buffers
                                        KiB Swap:   102396 total,     4496 used,    97900 free.   391360 cached Mem
                                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                                          681 root      20   0  208840  56532  23684 S   8.9  6.0 214:23.60 Xorg
                                          527 root      20   0   39448  21532  11264 S   4.3  2.3  69:34.28 vncserver-x11-c
                                         1154 pi        20   0   50548  17628  12196 S   3.0  1.9  64:05.96 lxterminal
                                        30426 openhab   20   0  441764 197592  14960 S   1.6 20.8 284:18.70 java
                                         2467 root      20   0   20024   2456   2300 S   1.3  0.3  62:55.17 mysgw
                                        25634 root      20   0       0      0      0 S   1.0  0.0   0:00.21 kworker/u8:0
                                          688 root      20   0   13720   9432   8828 S   0.7  1.0   2:04.96 vncagent
                                        25855 pi        20   0    5232   2584   2140 R   0.7  0.3   0:00.49 top
                                            7 root      20   0       0      0      0 S   0.3  0.0   9:15.35 rcu_sched
                                           78 root     -51   0       0      0      0 S   0.3  0.0   5:16.50 irq/92-mmc1
                                          967 pi        20   0   95656  17716  12028 S   0.3  1.9   6:41.87 lxpanel
                                            1 root      20   0   24620   4688   2716 S   0.0  0.5   0:13.08 systemd
                                            2 root      20   0       0      0      0 S   0.0  0.0   0:00.27 kthreadd
                                        • M macvictor
                                          --my-mqtt-user=*)
                                          after this code:
                                          @macvictor
                                          That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
