  2. Announcements
    @macvictor
    That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
    marceloaqno
    Code Contributor
    @gohan You can also set mqtt username and password in examples_linux/mysgw.cpp
    gohanG 1 Reply Last reply
    • M marceloaqno
      @marceloaqno
      I'm trying to understand where is the best place to avoid file gets overwritten in case of upgrades
      M 1 Reply Last reply
        @marceloaqno
        marceloaqno
        Code Contributor
        @gohan There is a open github pull request very similar to what @macvictor proposed, but for now I recommend using the examples_linux/mysgw.cpp file.
        • M marceloaqno
          @marceloaqno
          Ok I can you that file, but where is the best place to set Power Level and channel ?
            @marceloaqno
            marceloaqno
            Code Contributor
            @gohan There isn't exactly the best place to set things, it really depends on your preferences.
              I just copied the myconfig file from the arduino and set the rest from the command line and from debug it looks like it's working, the problem is now to get domoticz talk to the mqtt.
                After updating domoticz to beta version I finally have the MQTT working with controller and I can see the sensor node seding in data: my question now is how to I debug the gateway if it is running as a service on the RPI without messing things up?
                • M marceloaqno
                  @hawk_2050 same for you guys who helped, thank you for all the feedback.
                  @jerseyguy1996 I don't see anything wrong with your config.Try to add a small delay() after the first send() and before the sendBattery().
                  @annegerben This looks like a wire problem. I updated the guide, check the wire section again.
                  marlin
                  @marceloaqno I am trying to get a Pi 3 working with MySensors 2.1.1 and nrf24l01 and using your updated wire guide, but all I get as output is the following:
                  mysgw: Starting gateway...
                  mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.1
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: !TSM:INIT:TSP FAIL
                  mysgw: TSM:FAIL:CNT=1
                  mysgw: TSM:FAIL:PDT
                  [The output repeats itself, increasing the CNT every time, while at the same time one of the cores on the Pi 3 is running at full CPU utilization.]
                  By reading earlier comments I assume this is a wiring problem. One possible cause is inconsistency between
                  0_1488723559852_upload-e3165792-1f42-4663-8e68-efd96bd275f8
                  and
                  0_1488723638471_upload-d7048ef8-8a33-4214-9935-0356cf9291c2
                  where the first picture indicates that pin 24 and pin 26 should be used, while the second indicates pins 22 and 24 should be used. However, I have tried both options but I still get the same output (I used different nrf24's for the different setups, in case the nrf24 got burned from the first setup).
                  I have VCC from nrf24 connected to pin 17 on the Pi 3 and GND connect to pin 25.
                  Any suggestions on what to try next?
                  [The Pi 3 is running Raspbian with Pixel. For information, I already have a running Arduino with MySensors MQTT GW and a simple node with MySensors and DHT22. From this I know that by nrf24 chips works when being fed with 3.3V.]
                  G keldandorinK 2 Replies Last reply
                    I have connected my nrf24 like the secon table you posted and it is working but I am using an "adapter" for nrf24 with a socket and has voltage regulator + capacitors, so if you don't have any cap on the radio module, I'd suggest you put one on (try from a 4.7 uF up to 47 and see if anything changes)
                      marlin
                      @gohan Thanks! You were correct. I also had one of those "adapters" lying around which I did not need for my Arduino nodes with MySensors, though it came into use for the Rp3.
                        G
                        G
                        Grubstake
                        @gohan said in 💬 Building a Raspberry Pi Gateway:
                        I have my gateway on a headless pi 3, no monitor, GUI or keyboard. (I don't care for the nest of wires connection to the pi.) I also use MQTT which is very reliable.
                        An easy way to see the full MQTT traffic is to not start (or kill if it starts on boot) the MQTT server in the background, and start it in the console you can monitor. This won't impact Domotics one bit. In my case I do this by invoking "mosquitto -d" in the terminal
                        A simple way to monitor MQTT once its up and running is to look at the Domotics Log on the Setup menu.
                        Another way to watch it is to, in a terminal window such as running ssh from your computer, use MQTT "sub" in your terminal to see the MQTT traffic both ways to and from Domotics. If this isn't familiar, you need to learn it, (read the MQTT docs) and it's quite simple. Example might be "ssh pi@rpi.local" or "ssh <IP address>" from a computer on the local network, assuming the user is named pi and the pi is named "rpi"
                        Your MQTT topic must match what is in the sensor node sketch, the gateway sketch, and the domotics MQTT config. In my case I use "mosquitto_sub -d -v -t domoticz" and everything starts showing in real time in the terminal window.
                        MQTT is a bit more fiddly to set up but it's nice that different environments can push sensor data into the same MQTT server, in my case MySensors and ESP Easy.
                        Tim
                        • M marlin
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:FAIL:PDT
                          and
                          G
                          G
                          Grubstake
                          @marlin said in 💬 Building a Raspberry Pi Gateway:
                          Be careful because the wiring page shows two pinout diagrams, one for the Pi 1, another for the Pi 2&3, but which is which is not inside the graphic itself. Please don't ask how I know. ;-)
                          Tim
                          • G Grubstake
                            Tim
                            @Grubstake
                            I am using mqtt fx from pc and subscribing to topic # so I get the full traffic of what is going on, but I haven't had time lately to compare if you get same log details as the myscontroller connected to ethernet gateway or starting the gateway on rpi with debug flag
                            • M marlin
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:FAIL:PDT
                              and
                              keldandorinK
                              keldandorinK
                              keldandorin
                              @marlin Got the same issue, Did you solve yours and if so how?
                              M gohanG 2 Replies Last reply
                              • keldandorinK keldandorin
                                marlin
                                @keldandorin Yes. See the response by @gohan. I used a "adapter" with a voltage regulator on it etc. Though, at the moment I don't recall the model number.
                                  @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
                                  • C
                                    C
                                    ccy
                                    wrote on last edited by ccy
                                    #377
                                    I am trying to connect NRF24L01+ and Raspberry Pi 2 (Model B+). I am confuse about pin 22/24 too. In the diagram it shows "SPI0 CS0" and "SPI0 CS1" but these two pins aren't exist in NRF24L01+. How should I connect the pin? I connect Pi2 pin 24 to CS and Pi2 pin 26 to CE (Not sure it is correct)? Here is the message from mysgw:
                                    [root@alarmpi bin]# ./mysgw -d
                                    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:FAIL:RE-INIT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:CNT=2
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:CNT=3
                                    mysgw: TSM:FAIL:PDT
                                    • C ccy
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      mysgw: TSM:INIT
                                      mysgw: TSM:FAIL:PDT
                                      G
                                      G
                                      Grubstake
                                      wrote on last edited by Grubstake
                                      #378
                                      @ccy Look at the chart below "NRF24L01+ Radio". That shows the PIN numbers on the Pi and the pin labels on the radio to interconnect. Pay no attention to the labels on the RPi generic pinout diagram except the PIN numbers. The RPi SPIO labels are not what you are looking for. And be sure to use the chart for the correct RPi model.
                                        Exactly, I was about to write pretty much the same 😀
                                          G
                                          G
                                          Grubstake
                                          @gohan I beat you to it! :smiley:
