  2. Announcements
    mvader
    wrote on last edited by mvader
    #41
    I noticed the "improve rf24" section was added. and it mentioned high cpu.
    i set mine up a few weeks ago and am not using an interrupt on my radio.
    my cpu is only 2-3%
    I'm curious if the high cpu problem is seen by many?
    also a 2nd question.
    if i were to add an interrupt. how can i "re-configure" my setup to include that new -switch
    or do i have to remove everything and re-clone from git hub and start over?
    • shfgS
      shfgS
      shfg
      Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
      mysGateway: Starting gateway...
      mysGateway: Protocol version - 2.0.1-beta
      mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
      mysGateway: TSF:LRT:OK
      mysGateway: TSM:INIT
      mysGateway: TSM:INIT:TSP OK
      mysGateway: TSM:INIT:GW MODE
      mysGateway: TSM:READY
      mysGateway: MCO:REG:NOT NEEDED
      mysGateway: MCO:BGN:STP
      mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
      mysGateway: Attempting MQTT connection...
      mysGateway: connected to 127.0.0.1
      ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
      From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
      I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
      Has anyone else had a similar issue?
      M 1 Reply Last reply
      • E
        E
        ericvdb
        @marceloaqno what about gpio interrupts, is that supported?
        I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
        In combination with a I2C display, this could be a nice project ;)
        Greetz,
        Eric
        • Christian SimonsenC
          Christian SimonsenC
          Christian Simonsen
          I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
          • shfgS shfg
            marceloaqno
            Code Contributor
            #45
            @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
            @ericvdb yes, you can attach a function to handle an interruption like this:
            uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
            uint8_t physPin = 16;	// Choose a pin that fits your needs
            void irqHandler(void)
            	// Process the interrupt
            	attachInterrupt(physPin, irqHandler, mode);
            Support for I2C was added in the latest version.
            shfgS 2 Replies Last reply
            • Christian SimonsenC Christian Simonsen
              marceloaqno
              Code Contributor
              @Christian-Simonsen If you are using the default build options for the RPi gateway, in MyController (Resources -> Add gateway) choose Ethernet for the type and enter your RPi ip address in the Host name field.
              Christian SimonsenC 1 Reply Last reply
              • T
                Toyman
                Is it compatible with pre-2.0 versions eg 1.5?
                • M marceloaqno
                  Christian SimonsenC
                  Christian SimonsenC
                  Christian Simonsen
                  Thanks that did the trick
                    Christian SimonsenC
                    Christian Simonsen
                    wrote on last edited by Christian Simonsen
                    #49
                    Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
                    However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
                    If there is I need to monitor this via OSX Terminal.
                    jerseyguy1996J 1 Reply Last reply
                    • E
                      E
                      ericvdb
                      @marceloaqno
                      Today i tried to use the sketch Water Meter Pulse Sensor in mysGateway.cpp but i run into alot of errors, you have any idea?
                      mysGateway.cpp:
                       * Created by Marcelo Aquino <marceloaqno@gmail.org>
                       * Copyleft (c) 2016, Marcelo Aquino
                      #include <iostream>
                      #include <cstdio>
                      #include <unistd.h>
                      // For more options run ./configure --help
                      // Config file
                      //#define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
                      #define MY_GATEWAY_MAX_CLIENTS 10
                      // Serial config
                      // Enable this if you are using an Arduino connected to the USB
                      //#define MY_LINUX_SERIAL_PORT "/dev/ttyACM0"
                      // Enable this if you need to connect to a controller running on the same device
                      //#define MY_IS_SERIAL_PTY
                      // Choose a symlink name for the PTY device
                      //#define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
                      // Grant access to the specified system group for the serial device
                      //#define MY_LINUX_SERIAL_GROUPNAME "tty"
                      // MQTT options
                      //#define MY_PORT 1883
                      //#define MY_MQTT_CLIENT_ID "mysensors-1"
                      //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                      //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                      // Flash leds on rx/tx/err
                      //#define MY_DEFAULT_ERR_LED_PIN 12  // Error LED pin
                      //#define MY_DEFAULT_RX_LED_PIN  16  // Receive LED pin
                      //#define MY_DEFAULT_TX_LED_PIN  18  // Transmit LED pin
                      // Inverse the blinking feature
                      #define DIGITAL_INPUT_SENSOR 26                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                      #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                      #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
                      #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
                      #define CHILD_ID 1                              // Id of the sensor child
                      unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                      MyMessage flowMsg(CHILD_ID,V_FLOW);
                      MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                      MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                      double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
                      volatile double flow = 0;
                      bool pcReceived = false;
                      unsigned long newBlink = 0;
                      double oldflow = 0;
                      double volume =0;
                      double oldvolume =0;
                      unsigned long lastSend =0;
                      unsigned long lastPulse =0;
                      void onPulse()
                        if (!SLEEP_MODE)
                          unsigned long interval = newBlink-lastBlink;
                          if (interval!=0)
                            lastPulse = millis();
                            if (interval<500000L) {
                              // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                              return;
                            flow = (60000000.0 /interval) / ppl;
                          lastBlink = newBlink;
                        pulseCount++;
                        attachInterrupt(DIGITAL_INPUT_SENSOR, onPulse, FALLING);
                      void presentation() {
                        sendSketchInfo("Water Meter", "1.1");
                        // Register this device as Waterflow sensor
                        present(CHILD_ID, S_WATER);
                        unsigned long currentTime = millis();
                        if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
                          lastSend=currentTime;
                          if (!pcReceived) {
                            //Last Pulsecount not yet received from controller, request it again
                            request(CHILD_ID, V_VAR1);
                            return;
                          if (!SLEEP_MODE && flow != oldflow) {
                            oldflow = flow;
                            Serial.print("l/min:");
                            Serial.println(flow);
                            // Check that we dont get unresonable large flow value.
                            // could hapen when long wraps or false interrupt triggered
                            if (flow<((unsigned long)MAX_FLOW)) {
                              send(flowMsg.set(flow, 2));                   // Send flow value to gw
                          // No Pulse count received in 2min
                          if(currentTime - lastPulse > 120000){
                            flow = 0;
                          // Pulse count has changed
                          if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                            oldPulseCount = pulseCount;
                            Serial.print("pulsecount:");
                            Serial.println(pulseCount);
                            send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                            double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                            if ((volume != oldvolume)||(!SLEEP_MODE)) {
                              oldvolume = volume;
                              Serial.print("volume:");
                              Serial.println(volume, 3);
                              send(volumeMsg.set(volume, 3));               // Send volume value to gw
                        if (SLEEP_MODE) {
                          sleep(SEND_FREQUENCY);
                      ./configure --my-debug=enable --my-gateway=ethernet --my-radio=none --my-port=5003
                      [SECTION] Detecting target machine.
                      [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=000e.
                      [OK] init system detected: systemd
                      [SECTION] Saving configuration.
                      [SECTION] Cleaning previous builds.
                      [OK] Finished.
                      make:
                      root@raspberrypi:/downloads/MySensors# make
                      cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                      g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                      examples_linux/mysGateway.cpp: In function âvoid onPulse()â:
                      examples_linux/mysGateway.cpp:96:37: error: âmicrosâ was not declared in this scope
                      examples_linux/mysGateway.cpp: In function âvoid loop()â:
                      examples_linux/mysGateway.cpp:166:41: error: call of overloaded âset(volatile long unsigned int&)â is ambiguous
                      examples_linux/mysGateway.cpp:166:41: note: candidates are:
                      In file included from ./MySensors.h:319:0,
                                       from examples_linux/mysGateway.cpp:60:
                      ./core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
                       MyMessage& MyMessage::set(const char* value) {
                      ./core/MyMessage.cpp:222:12: note:   no known conversion for argument 1 from âvolatile long unsigned intâ to âconst char*â
                      ./core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
                       MyMessage& MyMessage::set(bool value) {
                      ./core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
                       MyMessage& MyMessage::set(uint8_t value) {
                      ./core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
                       MyMessage& MyMessage::set(uint32_t value) {
                      ./core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
                       MyMessage& MyMessage::set(int32_t value) {
                      ./core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
                       MyMessage& MyMessage::set(uint16_t value) {
                      ./core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
                       MyMessage& MyMessage::set(int16_t value) {
                      examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(long unsigned int&)â is ambiguous
                      examples_linux/mysGateway.cpp:180:25: note: candidates are:
                      In file included from examples_linux/mysGateway.cpp:22:0:
                      /usr/include/unistd.h:444:21: note: unsigned int sleep(unsigned int)
                       extern unsigned int sleep (unsigned int __seconds);
                      In file included from ./MySensors.h:320:0,
                      ./core/MySensorsCore.cpp:543:8: note: int8_t sleep(uint32_t, bool)
                       int8_t sleep(const uint32_t sleepingMS, const bool smartSleep) {
                      Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                      make: *** [examples_linux/mysGateway.o] Error 1
                      • E
                        E
                        ericvdb
                        @marceloaqno
                        i was able to get a bit further by replacing all "unsigned long" declarations with "uint"
                        Remains unsolved:
                        examples_linux/mysGateway.cpp:96:28: error: âmicrosâ was not declared in this scope
                             uint newBlink = micros();
                        examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(uint&)â is ambiguous
                        • T
                          Toyman
                          I probably miss something, but why are trying to compile the arduino sketch on Raspberry Pi???
                            @ericvdb
                            As @Toyman implies, we haven't ported the full Arduino environment here. This should mainly be used for running the Serial/Ethernet gateway directly on your RPi.
                            You cannot just run any MySensors example without risking to make heavy adaptations/implementation on your own.
                            • E ericvdb
                              @marceloaqno
                              Remains unsolved:
                              marceloaqno
                              Code Contributor
                              #54
                              @ericvdb micros() hasn't been ported, use:
                              millis() /1000;
                              for sleep(), replace:
                              with
                              sleep(SEND_FREQUENCY, false);
                              Also, if you want to print something don't use Serial.print() or Serial.println(), use printf() or debug().
                              should be:
                              debug("l/min: %f\n", flow);
                              as @hek said, the main focus now is to be used as a gateway, with time adding sensors will become less problematic.
                              • E
                                E
                                ericvdb
                                @marceloaqno
                                I have it almost working. Regarding the interrupt, I have to pull-up to 3.3V the io pin through a resistor of 10k?
                                Right now the interrupt isn't firing
                                • M marceloaqno
                                  shfgS
                                  shfgS
                                  shfg
                                  @marceloaqno thanks, turned on mosquitto logging and am getting this error on mosquitto:
                                  1476724216: Invalid protocol "MQTT" in CONNECT from 127.0.0.1.
                                  1476724216: Socket read error on client (null), disconnecting.
                                  Tried an alternative mosquitto broker on another server too - same error.
                                  • E
                                    E
                                    ericvdb
                                    @marceloaqno
                                    I have it working :smiley: only need to play with the debounce value
                                    • M marceloaqno
                                      shfgS
                                      shfgS
                                      shfg
                                      @marceloaqno I finally have the MQTT gateway working after upgrading mosquitto to the latest build... I had installed mosquitto with apt-get under Wheezy which apparently pulled an older version. In retrospect probably should have just upgraded to Jessie from the outset! Working perfectly now (still under wheezy though FWIW)... thanks!
                                      • b0rmannB
                                        b0rmannB
                                        b0rmann
                                        This post is deleted!
                                          marceloaqno
                                          Code Contributor
                                          @Christian-Simonsen start the gateway with debug enabled:
                                          mysGateway -d
