  2. Announcements
  • pepsonP
    pepsonP
    pepson
    But how i can build MySensors Gateway on serial with radio RFM69HW but on old version 2.1.1 ?
    • pepsonP
      pepsonP
      pepson
      And have next problem... i build sketch on version 2.2.0-rc2 but after write to Arduino Mini Pro he is not connected to my Gateway on RPI3.
      This is sketch. What is wrong ?
         Relay with button sketch
         modified to work with no uplink
         to gateway and try to maintain sync to controller
      #define MY_DEBUG                               // Enable debug prints to serial monitor
      #define MY_RADIO_RFM69
      #define MY_RFM69_FREQUENCY 868
      #define MY_IS_RFM69HW
      #define MY_RFM69_NEW_DRIVER
      //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
      #define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
      #define MY_REPEATER_FEATURE                    // Enabled repeater feature for this node
      #include <Bounce2.h>
      #define RELAY_PIN  5      // Arduino Digital I/O pin number for relay
      #define BUTTON_PIN  3     // Arduino Digital I/O pin number for button
      #define CHILD_ID 1        // Id of the sensor child
      #define RELAY_ON 1
      #define RELAY_OFF 0
      Bounce debouncer = Bounce();
      int oldValue = 0;
      bool uplinkAvailable = true;
      bool state = false;
      bool requestState;
      bool firstStart = true;
      unsigned long uplinkCheckTime ;                // holder for uplink checks
      unsigned long uplinkCheckPeriod = 30*1000;     // time between checks for uplink in milliseconds
      unsigned long returnWait = 1000;               // how long to wait for return from controller in milliseconds.. adjust as needed
      unsigned long oldTime = 0;
      unsigned long newTime = 0;
      MyMessage msg(CHILD_ID, V_STATUS);
      void setup(){
        pinMode(BUTTON_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
        debouncer.attach(BUTTON_PIN);                // After setting up the button, setup debouncer
        debouncer.interval(5);
        pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
        digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
      void presentation()  {
        sendSketchInfo("1xRelay & Button", "2.2.0-rc2");
        present(CHILD_ID, S_BINARY);
      void loop(){
        if (firstStart) {                            // this code is only run once at startup
          Serial.println("First run started");
          requestTime();                             // get time from controller
          wait (returnWait);                         // delay to allow time to return
          if (oldTime == 0){                         // check to see if there was a return from the time request
            Serial.println("uplink not available");
            uplinkAvailable = false;                 // no uplink established
            uplinkCheckTime = millis();
           else{
            Serial.println("uplink available");
            request( CHILD_ID, V_STATUS);            // get status of switch on controller
            wait (returnWait);                       //wait needed to allow request to return from controller
            Serial.print("controller state --- ");
            Serial.println(requestState);
            if (requestState != state) {             // check that controller is corectly showing the current relay state
              send(msg.set(state), false);           // notify controller of current state
        firstStart = false;                                          // set firstStart flag false to prevent code from running again
        debouncer.update();
        int value = debouncer.read();                               // Get the update value
        if (value != oldValue && value == 0) {                      // check for new button push
          state =  !state;                                          // Toggle the state
          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
          requestTime();
          if (oldTime != newTime){                                  // if times are different then uplink is available
            oldTime = newTime;
          else{                                                    // if times are the same no uplink is available
            uplinkAvailable = false;                                // no uplink available, set flag false
            uplinkCheckTime = millis();                             // start the timer from now
        oldValue = value;
        if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) {       // test to see if function should be called
          uplinkCheck();        // call uplink checking function
      /*-------------------start of functions--------------------------*/
        if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
          switch (message.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
            case C_SET:                                                   //message is a set command  from controller to update relay state
              state = message.getBool();                                  // get the new state
              digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
              uplinkAvailable = true;                                     //  uplink established
              /*---- Write some debug info----*/
              Serial.print(message.sensor);
              break;
            case C_REQ:                                               // message is a returning request from controller
              requestState = message.getBool();                       // update requestState with returning state
              break;
      void uplinkCheck() {
          requestTime();
          wait (returnWait);                       // wait for time return.. this may need to be varied for your system
           Serial.println("uplink re-established");
            send(msg.set(state), false);            // notify controller of current state no ack
            oldTime = newTime;
        uplinkCheckTime = millis();                // reset the checktime
        Serial.println("uplinkchecktime reset");
      void receiveTime(unsigned long time)
        if (firstStart){
          oldTime = time;
          newTime = time;
        else{
        newTime = time;
        Serial.print("time received---- " );
        Serial.println(time);
      • pepsonP pepson
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValue = 0;
        bool state = false;
        bool requestState;
        void setup(){
        void loop(){
             else{
          debouncer.update();
            requestTime();
              oldTime = newTime;
          oldValue = value;
                break;
                break;
            requestTime();
              oldTime = newTime;
          if (firstStart){
            oldTime = time;
            newTime = time;
          else{
          newTime = time;
        zboblamontZ
        zboblamontZ
        zboblamont
        @pepson Try walking in little steps trying each stage rather than running into new walls then expressing surprise at broken nose, no offence intended ;)
        Gateway and nodes, same platform, same version..... Otherwise they are speaking Chinese and Swedish hoping for somebody to explain the meaning of fubar...
        • pepsonP
          pepsonP
          pepson
          wrote on last edited by pepson
          #724
          I use the same version now 2.2.0-rc2 but when i programmed sketch to node it not connection to Gateway... That i want come back to version 2.1.1 gateway but i dont know how ? Or resolved problem Node 2.2.0-rc2 i stay on this.
          But when run debug gateway show this:
          pi@domoticz:~/MySensors $ sudo ./bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: Protocol version - 2.2.0-rc.2
          mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          mysgw: !TSF:SAN:FAIL
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:DIS
          mysgw: TSF:TDI:TSL
          mysgw: TSM:FAIL:RE-INIT
          mysgw: TSM:INIT
          This is sketch 2.2.0-rc2
          #define RFM69_868MHZ
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue = 0;
          bool state = false;
          bool requestState;
          void setup(){
          void loop(){
               else{
            debouncer.update();
              requestTime();
                oldTime = newTime;
            oldValue = value;
                  break;
                  break;
              requestTime();
                oldTime = newTime;
            if (firstStart){
              oldTime = time;
              newTime = time;
            else{
            newTime = time;
          • pepsonP pepson
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: MCO:BGN:STP
            mysgw: TSM:FAIL:DIS
            mysgw: TSF:TDI:TSL
            mysgw: TSM:INIT
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValue = 0;
            bool state = false;
            bool requestState;
            void setup(){
            void loop(){
                 else{
              debouncer.update();
                requestTime();
                  oldTime = newTime;
              oldValue = value;
                    break;
                    break;
                requestTime();
                  oldTime = newTime;
              if (firstStart){
                oldTime = time;
                newTime = time;
              else{
              newTime = time;
            zboblamontZ
            zboblamontZ
            zboblamont
            @pepson Let's try the baby steps I referred to earlier.
            The current stable version of MySensors is 2.1. Those using 2.2 tend to be experienced people versed in programming and experimenting and problem solving, hence it is not an official release.... yet you are using it and asking for solutions... Hello ?
            I am and have been for the last few months using a Pro-Mini with RFM69 as nodes and gateway using 2.1 attached to a Pi3 running Domoticz.... No problems, but slowly coming to understand most of what I am doing...
            I am still on baby steps, I don't mind at all, it works.....
            • pepsonP
              pepsonP
              pepson
              Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
              • pepsonP pepson
                zboblamontZ
                zboblamontZ
                zboblamont
                @pepson As in this page? 2.1.1 - Latest Release ?
                https://www.mysensors.org/download
                • pepsonP
                  pepsonP
                  pepson
                  I found bug in Domoticz BETA 8796. No reconized version gateway in HARDWARE. On stable 8153 works with no problem and correct reconized version gateway 2.2.0-rc2...
                  And again problem with this:
                  CODE: SELECT ALL
                  2017-12-28 20:01:32.587 MySensors: retrying in 30 seconds...
                  2017-12-28 20:02:08.752 MySensors: Using serial port: /dev/serial0
                  2017-12-28 20:02:08.752 MySensors: Gateway Version: 2.2.0-rc.2
                  2017-12-28 20:02:08.752 Error: Serial Port closed!... Error: End of file
                  2017-12-28 20:02:09.752 MySensors: retrying in 30 seconds...
                  2017-12-28 20:02:38.755 MySensors: Using serial port: /dev/serial0
                  2017-12-28 20:02:38.755 Error: Serial Port closed!... Error: End of file
                  2017-12-28 20:02:39.755 MySensors: retrying in 30 seconds...
                  2017-12-28 20:03:08.757 MySensors: Using serial port: /dev/serial0
                  2017-12-28 20:03:08.761 Error: Serial Port closed!... Error: End of file
                  2017-12-28 20:03:09.758 MySensors: retrying in 30 seconds...
                  On beta is problem.
                  On stable works correct.
                  • M macvictor
                    @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                    Gateway:
                    1. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-mqtt-password=PASS --my-mqtt-user=USER --my-rf24-encryption-enabled --my-signing=software --my-signing-request-signatures --my-signing-request-gw-signatures-from-all
                    2. make
                    3. sudo make install
                    4. sudo systemctl enable mysgw.service
                    5. sudo systemctl start mysgw.service
                    6. sudo mysgw --gen-soft-hmac-key
                    7. sudo mysgw --set-soft-hmac-key=02417628BC1573CC380...
                    8. sudo mysgw --gen-soft-serial-key
                    9. sudo mysgw --set-soft-serial-key=00762CD152B868F7EB
                    10. sudo mysgw --gen-aes-key
                    11. sudo mysgw --set-aes-key= A790AD78B2D8B4DBBB5B2C4B9DD6DAF3
                    Node:
                    1. Load script SecurityPersonalizer.ino
                    2. Uncomment and send sketch to arduino
                    #define USE_SOFT_SIGNING
                    #define STORE_SOFT_KEY
                    #define USER_SOFT_KEY
                    #define STORE_SOFT_SERIAL
                    #define STORE_AES_KEY
                    #define USER_AES_KEY
                    #define MY_SOFT_HMAC_KEY 0X2,0X41,0X76,0X28,0XBC,0X15,0X73,0XCC,0X38...
                    #define MY_AES_KEY 0XA7,0X90,0XAD,0X78,0XB2,0XD8...
                    1. Read all value from EPROM (test save):
                    Personalization sketch for MySensors usage.
                    EEPROM configuration:
                    SOFT_HMAC_KEY | 02417628BC1573CC380DE0FADF7C87D7D3C77272A783E6E438786A07C3A8C6CF
                    SOFT_SERIAL   | 39BB1370C289643251
                    AES_KEY       | A790AD78B2D8B4DBBB5B2C4B9DD6DAF3
                    Personalization is now complete.
                    1. Send sample sketch to arduino:
                    //!< Enable debug prints to serial monitor
                    //!< Enable signing related debug prints to serial monitor
                    #define MY_DEBUG_VERBOSE_SIGNING
                    // Enable NRF24L01 radio type
                    // Select soft signing
                    #define MY_SIGNING_SOFT
                    // Enable lockdown of node if suspicious activity is detected
                    //-->> #define MY_NODE_LOCK_FEATURE
                    // Enable node whitelisting
                    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
                    // Enable this if you want destination node to sign all messages sent to this node.
                    // SETTINGS FOR MY_SIGNING_SOFT
                    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
                    // Add repeater function to this sensor
                    #define RELAY_PIN  4    // Arduino Digital I/O pin number for relay
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue = 0;
                    bool state;
                    MyMessage msg(CHILD_ID, V_LIGHT);
                      // Setup the button
                      pinMode(BUTTON_PIN, INPUT);
                      // Activate internal pull-up
                      digitalWrite(BUTTON_PIN, HIGH);
                      state = loadState(CHILD_ID);
                      sendSketchInfo("Relay & Button", "1.0");
                      present(CHILD_ID, S_LIGHT, "Switch Secure Sensor", false);
                       Example on how to asynchronously check for new messages from gw
                      debouncer.update();
                    //  if (value != oldValue && value == 0) {
                        send(msg.set(state ? false : true), true); // Send new state and request ack back
                    //  oldValue = value;
                      delay(5000);
                      if (message.isAck()) {
                        // Change relay state
                        // Store state in eeprom
                        // saveState(CHILD_ID, state);
                        // Write some debug info
                    And finally in Arduino Serial Monitor I see:
                    0 MCO:BGN:INIT REPEATER,CP=RNNRAS-,VER=2.1.1
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    13 TSF:SID:OK,ID=105
                    15 TSM:FPAR
                    16 Will not sign message for destination 255 as it does not require it
                    58 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2065 !TSM:FPAR:NO REPLY
                    2067 TSM:FPAR
                    2068 Will not sign message for destination 255 as it does not require it
                    2110 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4117 !TSM:FPAR:NO REPLY
                    4119 TSM:FPAR
                    4120 Will not sign message for destination 255 as it does not require it
                    4162 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6169 !TSM:FPAR:NO REPLY
                    6171 TSM:FPAR
                    6172 Will not sign message for destination 255 as it does not require it
                    6214 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8221 !TSM:FPAR:FAIL
                    8222 TSM:FAIL:CNT=1
                    8224 TSM:FAIL:PDT
                    and in gateway i see:
                    sudo mysgw -d
                    mysgw: MCO:BGN:INIT GW,CP=RNNG-S-,VER=2.1.1
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    mysgw: Attempting MQTT connection...
                    mysgw: connected to 127.0.0.1
                    mysgw: MQTT connected
                    mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
                    mysgw: TSF:MSG:READ,171-107-54,s=221,c=2,t=131,pt=4,l=25,sg=0:-1418183441
                    mysgw: !TSF:MSG:PVER,3=2
                    mysgw: TSF:MSG:READ,135-23-172,s=20,c=3,t=200,pt=7,l=25,sg=0:-0.00000178
                    mysgw: !TSF:MSG:PVER,1=2
                    mysgw: TSF:MSG:READ,34-66-89,s=168,c=1,t=9,pt=1,l=25,sg=0:56
                    mysgw: TSF:MSG:READ,223-46-240,s=112,c=5,t=192,pt=5,l=11,sg=1:1407647670
                    mysgw: TSF:MSG:REL MSG
                    mysgw: !TSF:RTE:240 UNKNOWN
                    mysgw: !TSF:MSG:SEND,223-0-240-240,s=112,c=5,t=192,pt=5,l=11,sg=1,ft=0,st=NACK:1407647670
                    mysgw: TSF:MSG:READ,183-139-129,s=37,c=6,t=155,pt=1,l=21,sg=0:48
                    mysgw: !TSF:MSG:PVER,0=2
                    mysgw: TSF:MSG:READ,139-214-233,s=61,c=3,t=193,pt=7,l=0,sg=1:0.00000000
                    mysgw: !TSF:RTE:233 UNKNOWN
                    mysgw: !TSF:MSG:SEND,139-0-233-233,s=61,c=3,t=193,pt=7,l=0,sg=1,ft=0,st=NACK:0.00000000
                    mysgw: TSF:MSG:READ,83-33-7,s=179,c=2,t=27,pt=4,l=25,sg=1:-2057270722
                    mysgw: TSF:MSG:READ,110-148-67,s=113,c=0,t=158,pt=1,l=9,sg=1:251
                    mysgw: TSF:MSG:READ,75-209-102,s=204,c=7,t=25,pt=1,l=11,sg=1:52
                    mysgw: TSF:MSG:READ,184-209-235,s=58,c=1,t=140,pt=6,l=23,sg=1:1DC404A5401119FACF0000000000000000000000000000
                    mysgw: TSF:MSG:READ,172-203-51,s=140,c=2,t=173,pt=0,l=1,sg=1:?
                    mysgw: !TSF:RTE:51 UNKNOWN
                    mysgw: !TSF:MSG:SEND,172-0-51-51,s=140,c=2,t=173,pt=0,l=1,sg=1,ft=0,st=NACK:?
                    Where is problem?
                    pepsonP
                    pepsonP
                    pepson
                    This post is deleted!
                    • M macvictor
                      Gateway:
                      2. make
                      Node:
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue = 0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                        delay(5000);
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      15 TSM:FPAR
                      2067 TSM:FPAR
                      4119 TSM:FPAR
                      6171 TSM:FPAR
                      8221 !TSM:FPAR:FAIL
                      8222 TSM:FAIL:CNT=1
                      8224 TSM:FAIL:PDT
                      sudo mysgw -d
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      Where is problem?
                      pepsonP
                      pepsonP
                      pepson
                      @macvictor said in 💬 Building a Raspberry Pi Gateway:
                      Gateway:
                      2. make
                      Node:
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue = 0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                        delay(5000);
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      15 TSM:FPAR
                      2067 TSM:FPAR
                      4119 TSM:FPAR
                      6171 TSM:FPAR
                      8221 !TSM:FPAR:FAIL
                      8222 TSM:FAIL:CNT=1
                      8224 TSM:FAIL:PDT
                      sudo mysgw -d
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      Where is problem?
                      @macvictor
                      But how use itn on RFM69HW ? I dont see to be available #define MY_RFM69_ENABLE_ENCRYPTION... Only for #define MY_RF24_ENABLE_ENCRYPTION...
                      • pepsonP pepson
                        Gateway:
                        2. make
                        Node:
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValue = 0;
                        bool state;
                          // Setup the button
                          debouncer.update();
                          delay(5000);
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        15 TSM:FPAR
                        2067 TSM:FPAR
                        4119 TSM:FPAR
                        6171 TSM:FPAR
                        8221 !TSM:FPAR:FAIL
                        8222 TSM:FAIL:CNT=1
                        8224 TSM:FAIL:PDT
                        sudo mysgw -d
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        Where is problem?
                        @macvictor
                        #731
                        @pepson are you asking how to enable encryption on rfm69? (it is a bit unclear what you mean by "itn")
                        In that case, see https://www.mysensors.org/apidocs-beta/group__RFM69SettingGrpPub.html#ga17a7a919994e569f078e3787c2c4ecd2
                        pepsonP 1 Reply Last reply
                          pepsonP
                          pepsonP
                          pepson
                          @mfalkvidd
                          Yes :) Thanks
                          BTW
                          MySensors gateway as you see is problem with latest beta domoticz.
                          • pepsonP pepson
                            @mfalkvidd
                            Yes :) Thanks
                            BTW
                            #733
                            @pepson yes I saw that. Thanks for checking. Have you reported the problem to the Domoticz team?
                              pepsonP
                              pepsonP
                              pepson
                              @mfalkvidd
                              Yes write on forum Domoticz in section BUG
                              • pepsonP pepson
                                @mfalkvidd
                                @pepson great!
                                The report is at https://www.domoticz.com/forum/viewtopic.php?f=6&t=21125&sid=e414507bb1ca4596e93cf885047275a9 in case someone needs to find it in the future.
                                • G
                                  G
                                  ghiglie
                                  Hello!
                                  I'm trying to "make" on Alpine Linux in a Docker (ok, maybe it's useless, but way interesting!).
                                  With a Debian image it's ok, but I'd like to use Alpine.
                                  I get this error:
                                  g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DSPI_SPIDEV_DEVICE=\"/dev/spidev0.0\"  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                  In file included from /usr/include/sys/ioctl.h:7:0,
                                                   from drivers/Linux/SPIDEV.cpp:27:
                                  drivers/Linux/SPIDEV.cpp: In static member function 'static uint8_t SPIDEVClass::transfer(uint8_t)':
                                  drivers/Linux/SPIDEV.cpp:153:18: error: '_IOC_SIZEBITS' was not declared in this scope
                                    ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
                                  drivers/Linux/SPIDEV.cpp: In static member function 'static void SPIDEVClass::transfernb(char*, char*, uint32_t)':
                                  drivers/Linux/SPIDEV.cpp:175:18: error: '_IOC_SIZEBITS' was not declared in this scope
                                  make: *** [Makefile:99: build/drivers/Linux/SPIDEV.o] Error 1
                                  root@local-mysgw-alpine:/opt/MySensors3$ make
                                  eIn file included from /usr/include/sys/ioctl.h:7:0,
                                  I'm surely missing a package... but can't state one. Any help?
                                  @macvictor thanks for your post, it will help me a lot, I'm trying the same way.
                                  atmega328p serial killer
                                  HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                                  • G ghiglie
                                    Hello!
                                    I get this error:
                                    @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
                                    #include <asm/ioctl.h>
                                    would solve the problem. Could you try that?
                                    G 1 Reply Last reply
                                    • S
                                      sineverba
                                      wrote on last edited by sineverba
                                      #738
                                      Was my fault!
                                      **When copy and past command from word, for example, pay attention that software doesn't substitute the single "-" with a "-" longer. :dizzy_face:
                                      I have a word with all commands, to replicate installation very fast. Was my fault (errr... Word fault.... but you understand). Have a nice day!
                                      I cannot go over the initialization of command.
                                      RPI3 + Amplified antenna by GertSander (https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01). Power from 5v/3A and power for antenna taken from both 5V via the 3.3v stepper down.
                                      RPI3 is new, has about 12h (got yesterday).
                                      Yesterday it did work at first attempt. Today I would replicate so I did delete the uSD and restart over. No way to get the gateway on work.
                                      I did try 3 amplified antenna + 2 normal. No way.
                                      I did enable from raspi-config the SPI (and only it).
                                      It hangs on second line of output.
                                      These are the logs:
                                      sineverba@raspberrypi:~/MySensors $ ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                      [SECTION] Detecting target machine.
                                        [OK] machine detected: SoC=BCM2837, Type=rpi3, CPU=armv7l.
                                      [SECTION] Detecting SPI driver.
                                        [OK] SPI driver detected:BCM.
                                      [SECTION] Detecting init system.
                                        [OK] init system detected: systemd.
                                      [SECTION] Saving configuration.
                                      [SECTION] Cleaning previous builds.
                                      [OK] Finished.
                                      sineverba@raspberrypi:~/MySensors $ make
                                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                      g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                      g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                      g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                      g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                      gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                                      g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                                      g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                                      g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                                      g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                                      g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                                      sineverba@raspberrypi:~/MySensors $ sudo ./bin/mysgw –d
                                      [sudo] password for sineverba:
                                      • S
                                        sineverba
                                        Hi to all,
                                        I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
                                        I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
                                        I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
                                        Cannot find in documentation how do it on PI3. Thank you very much!
                                        • S sineverba
                                          Hi to all,
                                          G
                                          G
                                          ghiglie
                                          @sineverba said in 💬 Building a Raspberry Pi Gateway:
                                          Hi to all,
                                          Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
                                          S 1 Reply Last reply
