  2. Announcements
  • A
    A
    aglock
    Hello all!
    I'm trying to build a gateway with a Raspberry pi2, ethernet and Domoticz.
    It looks like the gateway is beeing built ok and seems to run fine but nodes can not communicate with it.
    I have read most of the postings here but I can not find any solution.
    Hope you guys can help? Please!
    I run raspbian (Jessie)
    pi@raspberrypi:~/MySensors/bin $ uname -a
    Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
    Using master branch
    https://www.mysensors.org/build/raspberry
    git clone https://github.com/mysensors/MySensors.git --branch master
    Configuring like this
    pi@raspberrypi:~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
    [SECTION] Detecting target machine.
      [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.
    [SECTION] Checking GPIO Sysfs.
      [OK] /sys/class/gpio/export found
    [SECTION] Detecting SPI driver.
      [OK] SPI driver detected:SPIDEV.
    [SECTION] Detecting init system.
      [OK] init system detected: systemd.
    [SECTION] Saving configuration.
    [SECTION] Cleaning previous builds.
    [OK] Finished.
    Obs! No Raspberry identification, why not? Maybe that is the culprit?
    After make I start the gateway and get this:
    pi@raspberrypi:~/MySensors $ cd bin
    pi@raspberrypi:~/MySensors/bin $ sudo ./mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: New connection from 127.0.0.1
    mysgw: Client 0 connected
    mysgw: Client 0: 0;0;3;0;2;
    mysgw: Client 0: 0;0;3;0;2;Get Version
    mysgw: Client 0: 0;0;3;0;18;PING
    Seems nice and dandy and Domoticz connecting fine.
    Trying with this example node:
    #define MY_NODE_ID 42
    //#define MY_DEBUG_VERBOSE_RF24
    #define MY_BAUD_RATE 9600
    #include<Arduino.h>
    #define OPEN 1
    #define CLOSE 0
    #define CHILD_ID 1
    uint8_t value = OPEN;
      Serial.print("setup()\n");
      sendSketchInfo("Door", "2.1.1");
      present(CHILD_ID, S_DOOR);
      Serial.print("presentation()\n");
      value = value == OPEN ? CLOSE : OPEN;
      send(msg.set(value));
      Serial.print("message sent");
      Serial.print(value + "\n");
      sleep(1000);
    And recieve this when running:
    --- Miniterm on /dev/ttyUSB0 9600,8,N,1 ---
    --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
    40 TSM:INIT
    55 TSF:WUR:MS=0
    77 TSM:INIT:TSP OK
    96 TSM:INIT:STATID=42
    120 TSF:SID:OK,ID=42
    141 TSM:FPAR
    190 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2267 !TSM:FPAR:NO REPLY
    2291 TSM:FPAR
    2340 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4417 !TSM:FPAR:NO REPLY
    4442 TSM:FPAR
    4491 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6569 !TSM:FPAR:NO REPLY
    6594 TSM:FPAR
    6643 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8720 !TSM:FPAR:FAIL
    8740 TSM:FAIL:CNT=1
    8761 TSM:FAIL:PDT
    And no output in gateway either.
    Both radio modules using capacitors.
    What have I missed?
    Thanks, Andreas!
    gohanG 1 Reply Last reply
    • skywatchS
      skywatchS
      skywatch
      I tried for months to get a stable working nrf24 attached to pi to act as a gw and controller.
      In the end I gave up and now have a 3.3V 8MHz pro mini gw attached to the pi. I took 0v and 5v from the pi (via a 3.3v buck converter) and serial tx and rx. Only 4 wires needed and has been as stable as can be for over a week now.
      Maybe help someone with the same unsolveable problems?
      • A aglock
        Hello all!
        Using master branch
        [OK] Finished.
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        #include<Arduino.h>
        #define OPEN 1
        #define CLOSE 0
        #define CHILD_ID 1
          sleep(1000);
        40 TSM:INIT
        55 TSF:WUR:MS=0
        77 TSM:INIT:TSP OK
        141 TSM:FPAR
        2291 TSM:FPAR
        4442 TSM:FPAR
        6594 TSM:FPAR
        8720 !TSM:FPAR:FAIL
        8740 TSM:FAIL:CNT=1
        8761 TSM:FAIL:PDT
        What have I missed?
        Thanks, Andreas!
        @aglock I put a note on the raspberry gateway page to use latest development in case of problems with stable. Did you try?
        A 2 Replies Last reply
          A
          A
          aglock
          @gohan yes. Interesting though when I used git to switch between branches it said all files where the same?
          Do you think the fault is in the gateway somehow?
            A
            A
            aglock
            @gohan Tried it again
            configure now recognizes the rpi:
            pi@raspberrypi:~/mys_dev $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
              [OK] machine detected: SoC=BCM2836, Type=rpi2, CPU=armv7l.
              [OK] SPI driver detected:BCM.
            [OK] Finished.
            But make fails with the following error:
            -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
            drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
            drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
               printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
            drivers/BCM/bcm2835.c:441:40: warning: spurious trailing ‘%’ in format [-Wformat=]
            Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
            make: *** [build/drivers/BCM/bcm2835.o] Error 1
            What to do about it?
            • A aglock
              [OK] Finished.
              @aglock see https://forum.mysensors.org/post/79403
              A 1 Reply Last reply
                A
                A
                aglock
                @mfalkvidd Wow, thanks that works! :D
                • WoekaW
                  WoekaW
                  Woeka
                  Got mysensors gateway working on gpio of my Pi again using ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-gateway=ethernet --my-port=5003
                  However on tx or tx always the two leds connected to pin 16 and 18 are lit. More people with the same problem?
                  S 1 Reply Last reply
                  • WoekaW Woeka
                    sineverba
                    @Woeka There is (on Arduino Gateway) a function named "DEFINE INVERSE BLINK". Try to search for same for PI....
                    • R
                      R
                      romeo01
                      wrote on last edited by romeo01
                      #690
                      Can we use the "debug ota log" features with the raspberryPi gateway ??
                      My node is not accessible and runs MYSBootloader.
                      My gateway is raspberryPI.
                      Now, I need to update the firmware on my node. Via MYSController, no problems, upload runs like a charm.
                      But how to do for debugging my sketch ? Some bugs appear...... , I need to take a look on some vars values.
                      Usually, I use the serial port with serial.print(some vars).
                      Which alternative I have to use without serial port, only OTA features ?
                      Thanks for the great work !!
                        Unless you are using an esp8266, I don't think you can remote debug a pro mini. @sundberg84 is working on a serial logger to microsd card, maybe it could help you in some way
                        • R
                          R
                          romeo01
                          In fact, I do not need to log, but need to look what's happen in my sketch.
                          The new "OTALog" function, MY_OTA_LOG_SENDER_FEATURE or MY_DEBUG_OTA seems to be the good way.
                          From the docs, it allows to send a debug message to another node or gateway via OTA.
                          But how to got the debug message from OTA node, on the gateway side (RaspberryPi) ?
                            @romeo01 said in 💬 Building a Raspberry Pi Gateway:
                            MY_DEBUG_OTA
                            I'd start reading from here https://www.mysensors.org/apidocs-beta/group__SerialDebugGrpPub.html#ga6bd5956352d3a184a0cb02783b8d35ff
                            R 1 Reply Last reply
                              MY_DEBUG_OTA
                              R
                              R
                              romeo01
                              @gohan said in 💬 Building a Raspberry Pi Gateway:
                              MY_DEBUG_OTA
                              Well, you found the starting point !
                              MY_OTA_LOG_SENDER_FEATURE & MY_DEBUG_OTA are enabled on my OTA node.
                              Again the same question: What I have to do on the gateway side ?
                              Is it possible with the raspberry Gateway ?
                              I'm still looking for debugging my sketch in remote. I need to have a look on the debug messages. I reminder, the node is not accessible and runs MYSbootloader.
                                If I understood well, you need to set a target node ID that will receive the debug and then make a node with that ID in order to get the debug messages
                                • R
                                  R
                                  romeo01
                                  Exactly, but I would like to use the gateway (raspberry) as target.
                                  Is that possible ?
                                  If yes, how to display the debug message on the gateway.
                                  I have an access to my gateway only via SSH.
                                    I have no idea if can do it, but you could just have a node connected to USB port of the rpi and do a "cat" on the USB port and you can read the debug from the node
                                    • signal15S
                                      signal15S
                                      signal15
                                      Is it possible to build a gateway that is MQTT, but also listens on port 5003? I want to send my data up to AWS IoT, but I also need port 5003 for Vera integration.
                                        You can use node-red to bridge the ethernet gateway and the aws service. Are you sure vera plug in doesn't support mqtt?
                                        • signal15S
                                          signal15S
                                          signal15
                                          @gohan, there are two MQTT plugins for the Vera with varying capabilities. But, the mysensors plugin for Vera doesn't appear to support MQTT at all. I could probably get one of those MQTT plugins working, but I'm not sure how stable they are. I hate installing unstable plugins and having them crash LUUP. I need to maintain a positive WAF (Wife Acceptance Factor), and broken HA doesn't help with that. :)
