  2. Announcements
  • AnticimexA Anticimex
    @gohan have you verified your communications are actually encrypted?
    @anticimex I guess you were right... the gw and node aren't using the AES key. So where am I supposed to add it in the gateway?
    AnticimexA 1 Reply Last reply
      AnticimexA
      AnticimexA
      Anticimex
      @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
      gohanG 1 Reply Last reply
        @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
          AnticimexA
          AnticimexA
          Anticimex
          @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
          • M macvictor
            @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
            Gateway:
            1. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-mqtt-password=PASS --my-mqtt-user=USER --my-rf24-encryption-enabled --my-signing=software --my-signing-request-signatures --my-signing-request-gw-signatures-from-all
            2. make
            3. sudo make install
            4. sudo systemctl enable mysgw.service
            5. sudo systemctl start mysgw.service
            6. sudo mysgw --gen-soft-hmac-key
            7. sudo mysgw --set-soft-hmac-key=02417628BC1573CC380...
            8. sudo mysgw --gen-soft-serial-key
            9. sudo mysgw --set-soft-serial-key=00762CD152B868F7EB
            10. sudo mysgw --gen-aes-key
            11. sudo mysgw --set-aes-key= A790AD78B2D8B4DBBB5B2C4B9DD6DAF3
            Node:
            1. Load script SecurityPersonalizer.ino
            2. Uncomment and send sketch to arduino
            #define USE_SOFT_SIGNING
            #define STORE_SOFT_KEY
            #define USER_SOFT_KEY
            #define STORE_SOFT_SERIAL
            #define STORE_AES_KEY
            #define USER_AES_KEY
            #define MY_SOFT_HMAC_KEY 0X2,0X41,0X76,0X28,0XBC,0X15,0X73,0XCC,0X38...
            #define MY_AES_KEY 0XA7,0X90,0XAD,0X78,0XB2,0XD8...
            1. Read all value from EPROM (test save):
            Personalization sketch for MySensors usage.
            EEPROM configuration:
            SOFT_HMAC_KEY | 02417628BC1573CC380DE0FADF7C87D7D3C77272A783E6E438786A07C3A8C6CF
            SOFT_SERIAL   | 39BB1370C289643251
            AES_KEY       | A790AD78B2D8B4DBBB5B2C4B9DD6DAF3
            Personalization is now complete.
            1. Send sample sketch to arduino:
            //!< Enable debug prints to serial monitor
            //!< Enable signing related debug prints to serial monitor
            #define MY_DEBUG_VERBOSE_SIGNING
            // Enable NRF24L01 radio type
            // Select soft signing
            #define MY_SIGNING_SOFT
            // Enable lockdown of node if suspicious activity is detected
            //-->> #define MY_NODE_LOCK_FEATURE
            // Enable node whitelisting
            //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
            // Enable this if you want destination node to sign all messages sent to this node.
            // SETTINGS FOR MY_SIGNING_SOFT
            #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
            // Add repeater function to this sensor
            #define MY_REPEATER_FEATURE
            #include <Bounce2.h>
            #define RELAY_PIN  4    // Arduino Digital I/O pin number for relay
            #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
            #define CHILD_ID 1      // Id of the sensor child
            #define RELAY_ON 1
            #define RELAY_OFF 0
            Bounce debouncer = Bounce();
            int oldValue = 0;
            bool state;
            MyMessage msg(CHILD_ID, V_LIGHT);
              // Setup the button
              pinMode(BUTTON_PIN, INPUT);
              // Activate internal pull-up
              digitalWrite(BUTTON_PIN, HIGH);
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              pinMode(RELAY_PIN, OUTPUT);
              state = loadState(CHILD_ID);
              digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
            void presentation()  {
              sendSketchInfo("Relay & Button", "1.0");
              present(CHILD_ID, S_LIGHT, "Switch Secure Sensor", false);
               Example on how to asynchronously check for new messages from gw
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
            //  if (value != oldValue && value == 0) {
                send(msg.set(state ? false : true), true); // Send new state and request ack back
            //  oldValue = value;
              delay(5000);
              if (message.isAck()) {
                // Change relay state
                state = message.getBool();
                // Store state in eeprom
                // saveState(CHILD_ID, state);
                // Write some debug info
                Serial.print(message.sensor);
            And finally in Arduino Serial Monitor I see:
            0 MCO:BGN:INIT REPEATER,CP=RNNRAS-,VER=2.1.1
            4 TSM:INIT
            5 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSF:SID:OK,ID=105
            15 TSM:FPAR
            16 Will not sign message for destination 255 as it does not require it
            58 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2065 !TSM:FPAR:NO REPLY
            2067 TSM:FPAR
            2068 Will not sign message for destination 255 as it does not require it
            2110 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4117 !TSM:FPAR:NO REPLY
            4119 TSM:FPAR
            4120 Will not sign message for destination 255 as it does not require it
            4162 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6169 !TSM:FPAR:NO REPLY
            6171 TSM:FPAR
            6172 Will not sign message for destination 255 as it does not require it
            6214 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8221 !TSM:FPAR:FAIL
            8222 TSM:FAIL:CNT=1
            8224 TSM:FAIL:PDT
            and in gateway i see:
            sudo mysgw -d
            mysgw: Starting gateway...
            mysgw: MCO:BGN:INIT GW,CP=RNNG-S-,VER=2.1.1
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            mysgw: MCO:BGN:STP
            mysgw: MCO:BGN:INIT OK,TSP=1
            mysgw: Attempting MQTT connection...
            mysgw: connected to 127.0.0.1
            mysgw: MQTT connected
            mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
            mysgw: TSF:MSG:READ,171-107-54,s=221,c=2,t=131,pt=4,l=25,sg=0:-1418183441
            mysgw: !TSF:MSG:PVER,3=2
            mysgw: TSF:MSG:READ,135-23-172,s=20,c=3,t=200,pt=7,l=25,sg=0:-0.00000178
            mysgw: !TSF:MSG:PVER,1=2
            mysgw: TSF:MSG:READ,34-66-89,s=168,c=1,t=9,pt=1,l=25,sg=0:56
            mysgw: TSF:MSG:READ,223-46-240,s=112,c=5,t=192,pt=5,l=11,sg=1:1407647670
            mysgw: TSF:MSG:REL MSG
            mysgw: !TSF:RTE:240 UNKNOWN
            mysgw: !TSF:MSG:SEND,223-0-240-240,s=112,c=5,t=192,pt=5,l=11,sg=1,ft=0,st=NACK:1407647670
            mysgw: TSF:MSG:READ,183-139-129,s=37,c=6,t=155,pt=1,l=21,sg=0:48
            mysgw: !TSF:MSG:PVER,0=2
            mysgw: TSF:MSG:READ,139-214-233,s=61,c=3,t=193,pt=7,l=0,sg=1:0.00000000
            mysgw: !TSF:RTE:233 UNKNOWN
            mysgw: !TSF:MSG:SEND,139-0-233-233,s=61,c=3,t=193,pt=7,l=0,sg=1,ft=0,st=NACK:0.00000000
            mysgw: TSF:MSG:READ,83-33-7,s=179,c=2,t=27,pt=4,l=25,sg=1:-2057270722
            mysgw: TSF:MSG:READ,110-148-67,s=113,c=0,t=158,pt=1,l=9,sg=1:251
            mysgw: TSF:MSG:READ,75-209-102,s=204,c=7,t=25,pt=1,l=11,sg=1:52
            mysgw: TSF:MSG:READ,184-209-235,s=58,c=1,t=140,pt=6,l=23,sg=1:1DC404A5401119FACF0000000000000000000000000000
            mysgw: TSF:MSG:READ,172-203-51,s=140,c=2,t=173,pt=0,l=1,sg=1:?
            mysgw: !TSF:RTE:51 UNKNOWN
            mysgw: !TSF:MSG:SEND,172-0-51-51,s=140,c=2,t=173,pt=0,l=1,sg=1,ft=0,st=NACK:?
            Where is problem?
            rajeev2301R
            rajeev2301R
            rajeev2301
            @macvictor
            I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
            import RPi.GPIO as GPIO
            from lib_nrf24 import NRF24
            import time
            import spidev
            GPIO.setmode(GPIO.BCM)
            pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
            radio = NRF24(GPIO, spidev.SpiDev())
            radio.begin(0,8)
            radio.setPayloadSize(32)
            radio.setChannel(0x76)
            radio.setDataRate(NRF24.BR_1MBPS)
            radio.setPALevel (NRF24.PA_MAX)
            radio.setAutoAck(True)
            radio.enableDynamicPayloads()
            radio.enableAckPayload()
            radio.openReadingPipe(1 ,pipes[1])
            radio.printDetails()
            radio.startListening()
            radio.GPIO.cleanup()
            Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
            • rajeev2301R rajeev2301
              @macvictor
              import time
              import spidev
              radio.begin(0,8)
              @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
              • wesW
                wesW
                wes
                To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
                Blog: https://www.wes.id.au/
                Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                Gateway & Controller: Raspberry Pi 3 + Home Assistant
                • wesW wes
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
                  S 1 Reply Last reply
                  • M macvictor
                    Gateway:
                    2. make
                    Node:
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue = 0;
                    bool state;
                      // Setup the button
                      debouncer.update();
                      delay(5000);
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    15 TSM:FPAR
                    2067 TSM:FPAR
                    4119 TSM:FPAR
                    6171 TSM:FPAR
                    8221 !TSM:FPAR:FAIL
                    8222 TSM:FAIL:CNT=1
                    8224 TSM:FAIL:PDT
                    sudo mysgw -d
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    Where is problem?
                    pepsonP
                    pepsonP
                    pepson
                    @macvictor
                    Hi
                    Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
                    • pepsonP pepson
                      @macvictor
                      Hi
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @pepson signing is radio agnostic. It has nothing to do with the radio.
                        sineverba
                        @anticimex @wes Can I please ask how to update? I mean, the right command to type.
                        I have the folder "MySensors" on documents of my user in Pi:
                        /home/sineverba/MySensors
                        Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
                        I need also to relaunch the ./config command?
                        Thank you to both and all!
                        • S sineverba
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @sineverba https://www.mysensors.org/download
                          • S
                            Syna
                            Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
                            Here is my arduino code : https://pastebin.com/YKi4EAad
                            The RasperryPI3 config & logs : https://pastebin.com/Kjn8CC8A
                            The MQTT Client logs : https://pastebin.com/ZP8GrkTj
                            M 1 Reply Last reply
                            • Sergio RiusS
                              Sergio RiusS
                              Sergio Rius
                              Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
                                Go for stable now, I need to remove that line from the page
                                Sergio RiusS 1 Reply Last reply
                                  Sergio RiusS
                                  Sergio RiusS
                                  Sergio Rius
                                  @gohan Thank you verys muchos. :+1:
                                  • S Syna
                                    marceloaqno
                                    Code Contributor
                                    #797
                                    @syna It is empty because it's a message of type I_ID_REQUEST that your node is sending. You need to set up a controller to distribute IDs or you can set it manually by adding this to your node's sketch:
                                    #define MY_NODE_ID X
                                    where X is a unique number from 1 to 254.
                                    • S
                                      sineverba
                                      Hi to all,
                                      tonight I made update from 2.2.0 RC2 to 2.2.0 (stable) on my Raspberry PI3.
                                      It is a live system (my heater control).
                                      By the way the update is very simple.
                                      First of all, backup or better CLONE your PI.
                                      1 - Disable the daemon with
                                      sudo systemctl stop mysgw.service && sudo systemctl disable mysgw.service
                                      2 - Make a copy of the MySensors folder ( I made a copy with the name of version coming, so...)
                                      cp -r MySensors MySensorsX.X.X(rc2)/
                                      (the slash at the end means "It's a folder!"
                                      3 - Remove the MySensors folder
                                      sudo rm -r MySensors
                                      4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                                      • O
                                        O
                                        otto001
                                        I am running the current version (2.2.0) on a RPi 1.
                                        I noticed that sometimes the cpu usage of the service is increasing dramatically (around 90% and more) - and then the service stops working.
                                        As I am not a C-Pro, I wrote a little python-script, which is called every minute by cron and restarts the service, if it uses more than 50% cpu.
                                        Maybe someone will find it useful:
                                        # -*- coding: utf-8 -*-
                                        import psutil, sys, os, datetime
                                        PY3 = sys.version_info[0] == 2
                                        LOOKFOR = u"mysgw"
                                        for proc in psutil.process_iter():
                                            if proc.name() == "mysgw":
                                                dt = str(datetime.datetime.now()).split('.')[0]
                                                #print(proc)
                                                cpu = proc.cpu_percent(interval=1)
                                                #print(cpu)
                                                #print(proc.cpu_times())
                                                if cpu > 50:
                                                        print(dt + " high CPU-usage! --> restarting service")
                                                        os.system("/bin/systemctl restart mysgw.service")
                                                else:
                                                        if datetime.datetime.now().strftime('%M') == "45":
        print(dt + " everything OK, cpu: " + str(cpu))
                                        and the crontab-entry (as root):
                                        * * * * * /home/pi/pstest.sh >> /var/log/mysgw-logger.log
                                        Cheers,
                                        Pula
                                        Nick WillisN 1 Reply Last reply
                                        • O otto001
                                          LOOKFOR = u"mysgw"
                                                  #print(proc)
                                                  #print(cpu)
                                                  if cpu > 50:
                                                  else:
                                          Cheers,
                                          Pula
                                          Nick WillisN
                                          Nick WillisN
                                          Nick Willis
                                          @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                                          CPU use is almost 100% and the service stops working.
                                          Are there any logs I can check? I'd prefer to know what's wrong although I'll go with the auto restart on high cpu use to prevent the house from ceasing to function at random!
