  2. Announcements
  • MasMatM MasMat
    @gohan The whole configure-line:
    sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    If anyone can tell what's missing or if there's a typo?
    AnticimexA
    AnticimexA
    Anticimex
    #881
    @masmat you have redundant flags. The password option require no other signing flags. Only if you select software as signing backend you need other options (and none of the simple flags)
    And remember that if you use software signing and not password signing, you need to personalize the GW and/or node.
    MasMatM 1 Reply Last reply
    • AnticimexA Anticimex
      MasMatM
      MasMatM
      MasMat
      wrote on last edited by MasMat
      #882
      @anticimex I thought so too, but I'm grasping at straws to get the signing to work.
      To clarify, is the following enough for simple signing: --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ
      And the arduino code #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
      Any difference where it's placed in the code? Anything else to check for?
      AnticimexA 1 Reply Last reply
      • MasMatM MasMat
        AnticimexA
        AnticimexA
        Anticimex
        @masmat it needs to be defined prior to the inclusion of mysensors.h. That should be it. (on the arduino node that is).
        • alowhumA
          alowhumA
          alowhum
          While on the subject: what would be the flags needed for setting the gateway to only use the simple encryption but not the (simple) signing feature?
          I looked in the documentation and the node commands aren't mirrored for the gateway. I was hoping for something like:
          --MY_SIGNING_SIMPLE_PASSWD=flowerpot77
          --MY_ENCRYPTION_SIMPLE_PASSWD=spiderman41
            It's actually not needed since you can still set signing as optional on gateway
            • alowhumA alowhum
              AnticimexA
              AnticimexA
              Anticimex
              #886
              @alowhum that feature is still only available for beta and is documented here: https://www.mysensors.org/apidocs-beta/group__SecuritySettingGrpPub.html
              EDIT: not yet for rPi
              Pull requests are welcome. I don't have time for this at the moment.
              • alowhumA
                alowhumA
                alowhum
                #887
                Right. So is this correct?
                NODES (arduino nano)
                On all my nodes I will update them to have this code at the top:
                #define MY_ENCRYPTION_SIMPLE_PASSWD spiderman41 // unfortunately Nano hardware doesn't really have enough memory for signing.
                #define MY_RF24_CHANNEL 100 // in EU the default channel 76 overlaps with wifi.
                #define MY_RF24_DATARATE RF24_1MBPS // slower datarate makes the network more stable?
                GATEWAY (Raspberry Pi Zero W)
                On my gateway I will use this configure code:
                --my-security-password=spiderman41
                --my-rf24-encryption-enabled
                --my-rf24-channel=100
                --extra-cxxflags="-DMY_RF24_DATARATE=(RF24_1MBPS)"
                • alowhumA alowhum
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alowhum you will need to enable weak security as well as that will enable both signing and encryption with signature requirements from all nodes on the gw
                  • alowhumA
                    alowhumA
                    alowhum
                    #889
                    @Anticimex thanks!
                    But I don't want signing? Or do you mean that it will remove that requirement?
                    I only need to set that on the gateway, right?
                    I've also added a slower datarate, thinking that will also create a more stable connection. I am in a busy urban environment with lots of RF noise. Is that smart?
                    • alowhumA alowhum
                      @Anticimex thanks!
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alowhum I thought you did not want signing: "but not the (simple) signing feature?"
                      • alowhumA
                        alowhumA
                        alowhum
                        #891
                        Yes, I don't want signing. But what you wrote said that it wil ENABLE signing. Check your sentence. Probably a typo, but I wanted to make sure :-)
                        • alowhumA alowhum
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alowhum the simple security flag enables signing yes.
                          • alowhumA
                            alowhumA
                            alowhum
                            @alowhum said in 💬 Building a Raspberry Pi Gateway:
                            But does the "--my-signing-weak_security" enable signing?
                            I want to disable signing completely. What flags do I need to use when building a gateway that only uses encryption?
                            • alowhumA alowhum
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @alowhum just don't use any flags mentioning signing, personalize the gw according to the documentation and pick the appropriate encryption flag.
                                MasMatM
                                MasMatM
                                MasMat
                                @anticimex I've built a new node, DHT11 that sends temp&hum data. I reconfigured Rpi with this:
                                sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-signing-password=XXXXXX --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=YYYY --my-mqtt-password=ZZZZZ --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                This is what I get in gw syslog:
                                Apr  2 22:53:11 DietPi mysgw: Starting gateway...
                                Apr  2 22:53:11 DietPi mysgw: Protocol version - 2.2.0
                                Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
                                Apr  2 22:53:11 DietPi mysgw: !SGN:BND:PWD<8
                                Apr  2 22:53:11 DietPi mysgw: !SGN:INI:BND FAIL
                                Apr  2 22:53:11 DietPi mysgw: TSF:LRT:OK
                                Apr  2 22:53:11 DietPi mysgw: TSM:INIT
                                Apr  2 22:53:11 DietPi mysgw: TSF:WUR:MS=0
                                Apr  2 22:53:11 DietPi mysgw: TSM:INIT:TSP OK
                                Apr  2 22:53:11 DietPi mysgw: TSM:INIT:GW MODE
                                Apr  2 22:53:11 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                                Apr  2 22:53:11 DietPi mysgw: MCO:REG:NOT NEEDED
                                Apr  2 22:53:11 DietPi mysgw: MCO:BGN:STP
                                Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
                                Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
                                Apr  2 22:53:11 DietPi mysgw: connected to 127.0.0.1
                                Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
                                Apr  2 22:53:11 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                                Apr  2 22:53:23 DietPi mysgw: TSF:MSG:READ,99-99-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                Apr  2 22:53:23 DietPi mysgw: TSF:MSG:BC
                                Apr  2 22:53:23 DietPi mysgw: TSF:MSG:FPAR REQ,ID=99
                                Apr  2 22:53:23 DietPi mysgw: TSF:PNG:SEND,TO=0
                                Apr  2 22:53:23 DietPi mysgw: TSF:CKU:OK
                                Apr  2 22:53:23 DietPi mysgw: TSF:MSG:GWL OK
                                Apr  2 22:53:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=8
                                Apr  2 22:53:23 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                Apr  2 22:53:25 DietPi mysgw: TSF:MSG:READ,99-99-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=24
                                Apr  2 22:53:25 DietPi mysgw: TSF:MSG:PINGED,ID=99,HP=1
                                Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=25
                                Apr  2 22:53:25 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                Apr  2 22:54:18 DietPi mysgw: TSF:MSG:READ,99-99-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
                                Apr  2 22:54:18 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                                Apr  2 22:54:18 DietPi mysgw: !SGN:NCE:GEN
                                Apr  2 22:54:23 DietPi mysgw: TSF:MSG:READ,99-99-0,s=0,c=3,t=16,pt=0,l=0,sg=0:
                                Apr  2 22:54:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                                Apr  2 22:54:23 DietPi mysgw: !SGN:NCE:GEN
                                This is kicking my butt... I cant understand that last part about the nonce :(
                                I will add the code from the node as soon as possible.
                                mfalkviddM AnticimexA 2 Replies Last reply
                                • MasMatM MasMat
                                  @masmat according to the log parser
                                  means the password is too short.
                                  • MasMatM MasMat
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @masmat and this
                                    !SGN:INI:BND FAIL
                                    Means the signing backend failed to initialize. So you need to make the password longer.
                                      MasMatM
                                      MasMatM
                                      MasMat
                                      @mfalkvidd Made the password 10 characters. From looks of the logs, it's working now.
                                      I cant believe I skipped the step of making the password longer... Just got too fixated on the password I came up with.
                                      • MasMatM MasMat
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @masmat the nonce failures is because the backend never initialized so basically any call to the backend that can fail will fail.
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          I just discovered these USB-to-NRF24 devices. Would it be possible to use that instead of connecting to the GPIO pins?
                                          https://www.aliexpress.com/item/USB-wireless-serial-module-serial-to-nRF24L01-digital-communication-remote-control-acquisition-module-nRF2401/32722937957.html
