💬 Building a Raspberry Pi Gateway
just download the image and do the same as a Raspian image. I haven't tried mqtt gateway yet, so I don't know if it may be a gateway bug or else.
@gohan I had another sd card and tried a ready image of DietPi with Mosquitto pre-installed.
I tried it without user/password and mosquitto accepting anonymous but:/var/log/mosquitto/mosquitto.log:
1521141160: Socket error on client <unknown>, disconnecting.
1521141160: New connection from 127.0.0.1 on port 1883.
..keeps repeating......and sudo ./bin/mysgw -d:
mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: GWT:RMQ:MQTT RECONNECT mysgw: connected to 127.0.0.1 mysgw: GWT:RMQ:MQTT RECONNECT mysgw: connected to 127.0.0.1 mysgw: GWT:RMQ:MQTT RECONNECT``` -
1st patch is still working good for me. have had no issues since applying it.
question. is it normal/correct for the gateway to ping or spam? every 10 seconds i see the gateway announce it's version.
its not doing the full restart or anything.. just giving the 2.2.0 every 10 seconds. -
@gohan I configured:
./configure --my-transport=nrf24 --my-gateway=ethernet --my-controller-ip-address=127.0.0.1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-signing=password --my-signing-password=ZZZZZZ./bin/mysgw -d:
mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: connect: Connection refused mysgw: failed to connect mysgw: GWT:TIN:ETH OK mysgw: connect: Connection refused mysgw: failed to connect mysgw: GWT:TPS:ETH OK mysgw: connect: Connection refused mysgw: failed to connect mysgw: GWT:TPS:ETH OKThe controller doesn't exist on the DietPi card yet but I'm not sure if that's causing the problem.
@masmat I did a test with the following configuration:
Raspberry Pi 1 with Raspbian (2017-11-29-raspbian-stretch-lite)
pi@raspberrypi:~/MySensors $ lsb_release -a No LSB modules are available. Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.1 (stretch) Release: 9.1 Codename: stretch -
MySensors master branch - Protocol version - 2.2.0
./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=m ygateway1 --my-mqtt-user=rpi --my-mqtt-password=password -
Mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) [installed from apt-get]
pi@raspberrypi:~/MySensors $ cat /etc/mosquitto/mosquitto.conf # Place your local configuration in /etc/mosquitto/conf.d/ # # A full description of the configuration file is at # /usr/share/doc/mosquitto/examples/mosquitto.conf.example pid_file /var/run/mosquitto.pid persistence true persistence_location /var/lib/mosquitto/ log_dest file /var/log/mosquitto/mosquitto.log allow_anonymous false password_file /etc/mosquitto/passwordfile include_dir /etc/mosquitto/conf.dAdded the mosquitto user (user=rpi, password=password) with:
sudo mosquitto_passwd -c /etc/mosquitto/passwordfile rpi
It didn't show any error to connect to the MQTT broker:
pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: GWT:RMQ:MQTT RECONNECT mysgw: connected to 127.0.0.1 mysgw: GWT:RMQ:MQTT CONNECTED mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 mysgw: TSF:MSG:PINGED,ID=5,HP=1 mysgw: TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1 mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/32,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=33,pt=5,l=4,sg=0:4951 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/33,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=37,pt=4,l=4,sg=0:36053 mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/37,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/32,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=33,pt=5,l=4,sg=0:5000 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/33,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=37,pt=4,l=4,sg=0:36055 mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/37,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/32,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=33,pt=5,l=4,sg=0:5000 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/33,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=37,pt=4,l=4,sg=0:36055 mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/37,MSG SENT -
@gohan said in 💬 Building a Raspberry Pi Gateway:
@masmat have you tried with ethernet gateway? If I have time I'll try the mqtt this weekend
@mvader I never noticed that.... is it the mqtt GW?
I'm not using mqtt.
for debug purposes i use MYSController
every 10 seconds on the dot. it shows me the version of the gateway.201 3/15/2018 20:47:15 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.2.0 202 3/15/2018 20:47:25 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.2.0 203 3/15/2018 20:47:35 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.2.0 204 3/15/2018 20:47:45 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.2.0 205 3/15/2018 20:47:55 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.2.0 206 3/15/2018 20:48:05 RX 0 - Gateway INTERNAL C_INTERNAL NO I_VERSION 2.2.0@marceloaqno any ideas about that?
I'm not using mqtt.
Yesterday I cloned the latest version on a recent raspbian (9.3) and I applied the first patch of @marceloaqno .
We will see. So long there were no problems. I will send an update in a few days...
As a last help I could switch to mqtt and do a restart after a defined amount of time (if no events are received)....Cheers,
Otto -
@marceloaqno I got my gw rfm69 gateway suddenly stopped communicating with nodes. I tried everything to reinstall it but without luck. I was able to have it running on my test rpi with a complete OS reinstall. Is there anything else I need need to clean up from my install to reset every settings? (besides the mysensors folder and mysensors.dat file I already deleted)
How can I monitor the traffic data between the raspberry and RF module (NRF24L01) on a Ethernet gateway ??
My gateway is built for Ethernet. I start the gateway with "service mysgw start"
Now, I would like to get the same data output than output debug (./bin/mysgw -d) but without stop mysgw service.
I need to use MYSController as Ethernet client at the same time.Thanks
pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.2.0 mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: GWT:RMQ:MQTT RECONNECT mysgw: connected to 127.0.0.1 mysgw: GWT:RMQ:MQTT CONNECTED mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 mysgw: TSF:MSG:PINGED,ID=5,HP=1 mysgw: TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1 mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/32,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=33,pt=5,l=4,sg=0:4951 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/33,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=37,pt=4,l=4,sg=0:36053 mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/37,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/32,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=33,pt=5,l=4,sg=0:5000 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/33,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=37,pt=4,l=4,sg=0:36055 mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/37,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/32,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=33,pt=5,l=4,sg=0:5000 mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/33,MSG SENT mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=37,pt=4,l=4,sg=0:36055 mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/37,MSG SENT@marceloaqno What does your mosquitto.log show?
I did a fresh install of DietPi (stretch), Mosquitto and MySensors --branch master. I left out everything and pretty much did the configure command as you did. I get the same result, but mosuiqtto log shows:1521584708: New connection from 127.0.0.1 on port 1883. 1521584708: New client connected from 127.0.0.1 as mygateway1 (c1, k15, u'masi'). 1521584733: Socket error on client mygateway1, disconnecting. 1521584778: New connection from 127.0.0.1 on port 1883.So is this normal?
I have one sensors built that's not connecting (its log shows it just trying and trying..). I would like to user simple password and the LEDs, I will build one extra sensors just to help testing. -
@romeo01 see instructions at https://www.mysensors.org/build/raspberry#troubleshooting
@mfalkvidd Thanks fer info, now I can see the serial protocol as well in the syslog. Next step should be to have a logfile dedicated to mysgw.
@otto001
Syslog:Mar 21 20:06:05 DietPi systemd[1]: Started MySensors Gateway daemon. Mar 21 20:06:05 DietPi mysgw: Starting gateway... Mar 21 20:06:05 DietPi mysgw: Protocol version - 2.2.0 Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0 Mar 21 20:06:05 DietPi mysgw: TSF:LRT:OK Mar 21 20:06:05 DietPi mysgw: TSM:INIT Mar 21 20:06:05 DietPi mysgw: TSF:WUR:MS=0 Mar 21 20:06:05 DietPi mysgw: TSM:INIT:TSP OK Mar 21 20:06:05 DietPi mysgw: TSM:INIT:GW MODE Mar 21 20:06:05 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0 Mar 21 20:06:05 DietPi mysgw: MCO:REG:NOT NEEDED Mar 21 20:06:05 DietPi mysgw: MCO:BGN:STP Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT OK,TSP=1 Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT RECONNECT Mar 21 20:06:05 DietPi mysgw: connected to 127.0.0.1 Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT CONNECTED Mar 21 20:06:05 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENTWhere is mysgw.log?
Was pointed here from another post, having serious issues with high CPU utilization op the gateway, is there any workaround and the moment?
top:
asks: 157 total, 2 running, 155 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.5 us, 23.0 sy, 0.0 ni, 74.3 id, 0.1 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem : 949580 total, 448732 free, 146912 used, 353936 buff/cache KiB Swap: 102396 total, 102396 free, 0 used. 737656 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 337 root 20 0 20492 1060 932 R 100.0 0.1 28:54.55 mysgw 3947 pi 20 0 8248 3324 2736 R 1.6 0.4 0:00.82 top 447 homeass+ 20 0 340112 63684 9916 S 1.0 6.7 3:28.71 hass 7 root 20 0 0 0 0 S 0.3 0.0 0:04.18 rcu_sched 767 root 20 0 126572 8628 6544 S 0.3 0.9 0:00.95 piplight-daemonPRETTY_NAME="Raspbian GNU/Linux 9 (stretch)" NAME="Raspbian GNU/Linux" VERSION_ID="9" VERSION="9 (stretch)" Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/LinuxRebooting the pi sometimes helps, sometimes freezes the pi
seeing nothing strange in the mysensors log what so ever
running MySensors Version 2.2.0
and Home Assistant Version 0.64.0
Anyone can point me in the direction where to troubleshoot this further ?
its not a high traffic gateway (around 10 sensors connected of which 5 updating every 15 minutes)
