💬 Real Time Clock Module, LCD Display and Controller Time
  • Admin
    This thread contains comments for the article "Real Time Clock Module, LCD Display and Controller Time" posted on MySensors.org.
  • Thank you for this nice write up.
    I have some "low power" questions:
    • Will the RTC continue to work when the Arduino is set to Sleep?
    • Is there a way to save battery and wake up the Arduino using the RTC?
    • What is the power consumption of a get time request?
    • What is the autonomy of the RTC?
  • Admin
    Yes, the RTC will continue to function while the Arduino is sleeping.
    On the DS3232RTC you can set alarm (which triggers the INT pin of the module). See more info here:
    https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/DS3232RTC
  • I was modify code to Present temp to controller .
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to request time from controller which is stored in RTC module
     * The time and temperature (DS3231/DS3232) is shown on an attached Crystal LCD display
     * Wiring (radio wiring on www.mysensors.org)
     * Arduino   RTC-Module     I2C Display
     * GND       GND            GND
     * +5V       VCC            VCC
     * A4        SDA            SDA
     * A5        SCL            SCL
     * http://www.mysensors.org/build/display
    #include <TimeLib.h>
    #include <DS3232RTC.h>  // A  DS3231/DS3232 library
    #include <Wire.h>
    //#include <LCD_1602_RUS.h>
    bool timeReceived = false;
    unsigned long lastUpdate=0, lastRequest=0;
    int numSensors=0;
    #define CHILD_ID_TEMP 15
    #define COMPARE_TEMP 1                            // Send temperature only if changed? 1 = Yes 0 = No
    MyMessage msg(0,V_TEMP);
    float lastTemperature;
    // Initialize display. Google the correct settings for your display.
    // The follwoing setting should work for the recommended display in the MySensors "shop".
    LiquidCrystal_I2C lcd(0x3F, 16, 2);
    //LCD_1602_RUS lcd(0x3F, 16, 2);
      // the function to get the time from the RTC
      setSyncProvider(RTC.get);
      // Request latest time from controller at startup
      requestTime();
      // initialize the lcd for 16 chars 2 lines and turn on backlight
      lcd.begin(16,2);
      lcd.init();                    // Инициализируем экран
      lcd.clear();
      lcd.backlight();               //включаем подсветку
    void presentation()  {
      sendSketchInfo("RTC Clock + Temp", "1.1.1");
      present(0, S_TEMP);
      numSensors = 1 ;
    // This is called when a new time value was received
    void receiveTime(unsigned long controllerTime) {
      // Ok, set incoming time
      Serial.print("Time value received: ");
      Serial.println(controllerTime);
      RTC.set(controllerTime); // this sets the RTC to the time from controller - which we do want periodically
      timeReceived = true;
      unsigned long now = millis();
      // If no time has been received yet, request it every 10 second from controller
      // When time has been received, request update every hour
      if ((!timeReceived && (now-lastRequest) > (10UL*1000UL))
        || (timeReceived && (now-lastRequest) > (60UL*1000UL*60UL))) {
        // Request time from controller.
        Serial.println("requesting time");
        requestTime();
        lastRequest = now;
      // Update display every second
      if (now-lastUpdate > 1000) {
        updateDisplay();
        lastUpdate = now;
    void updateDisplay(){
      tmElements_t tm;
      RTC.read(tm);
      // Print date and time
      lcd.home();
      lcd.print(tm.Day);
      lcd.print("/");
      lcd.print(tm.Month);
      lcd.print("/");
      lcd.print(tmYearToCalendar(tm.Year)-2000);
      lcd.print(" ");
      printDigits(tm.Hour);
      lcd.print(":");
      printDigits(tm.Minute);
    //  lcd.print(":");
    //  printDigits(tm.Second);
      // Go to next line and print temperature
      lcd.setCursor ( 0, 1 );
      lcd.print("Temp: ");
      lcd.print(RTC.temperature()/4);
      lcd.write(223); // Degree-sign
      lcd.print("C");
      float temperature = (RTC.temperature()/4);
      #if COMPARE_TEMP == 1
        if (lastTemperature != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msg.setSensor(0).set(temperature, 1));
          lastTemperature=temperature;
    void printDigits(int digits){
      if(digits < 10)
        lcd.print('0');
      lcd.print(digits);
  • @cadet
    Hi all
    Can I display Temp from other sensor ?
    Thank you
    Andrey
  • Hi, I wanted to know if it was possible to create a node in each room with a temperature sensor and display and send it all to the controller
  • Mod
    @cadet sure you can, in the send() function you can specify a destination ID of the node with the display
    @exagon_46 of course is possible, just add some code to display the temperature (use the examples of the LiquidCrystal_I2C library as reference)
  • good evening
    again a new sketch for the "void receiveTime" function
    (without RTC clock)
    • start synchronization with the controller and regularly for the drift of the arduino.
    • display time and date on an OLED screen
    • error message when a loss of communication with the controller occurs
    a video "https://www.casimages.com/v/RSWTNb-vokoscreen-2022-05-24-19-33-49.mp4.html"
     * LIBRAIRIE:
     *  MySensors v2    : https://github.com/mysensors/MySensors
     *  TimeLib.h       : https://github.com/PaulStoffregen/Time
     *  SSD1306Ascii.h  : https://github.com/greiman/SSD1306Ascii
     * MATERIEL:
     *    Arduino Uno
     *    -Afficheur OLED 0,96" I2C TF052 / circuit SSD1306.
     *    bus TTLModule RS485
     *  base de Henrik Ekblad 2013-2015 et autres :)
     *  ajout bus RS485 et OLED
     *  demander Date et Heure au  contrôleur et l'affiche sur ecran OLED
     *  Request date and time from the controller and display it on OLED screen
     *  Connectique i2c:
    *   Arduino :  A4   A5
    *   OLED    :  SDA  SCL
    //-- The sketch uses 11932 bytes (36%) ----global variables use 839 bytes (40%)-----------
    //------------ 2022 ----------------------- Fonctionnelle avec MyC et MyS-------------------
      //#define MY_DEBUG                  /*Enable debug prints to serial monitor*/
      #define MY_TRANSPORT_WAIT_READY_MS 3000  /*Timeout (ms) pour mis en Com.(0 pour aucun)*/
      #define MY_NODE_ID 22          /*Node en ID static*/
    /* ----- Module RS485 ----*/
      #define MY_RS485                  /*Apl du transport RS485 (protocol?)*/
      #define MY_RS485_DE_PIN 2         /*Cmd DE pin*/
      #define MY_RS485_BAUD_RATE 9600   /*Set RS485 baud rate to use*/
    //#define MY_RS485_HWSERIAL Serial1 /*pour port Serial autre*/
      #include "SSD1306Ascii.h"
      #include "SSD1306AsciiAvrI2c.h"
      #define CHILD_ID 22       /* MyS numero du Node*/
      #define I2C_ADDRESS 0x3C                        /*i2c adresse*/
      #define RST_PIN -1  // Define proper RST_PIN if required.(oled)
      SSD1306AsciiAvrI2c oled;  //type de com oled
    //----- MyS ------
        bool stateCom = false;
        unsigned long lastUpdate=0, lastRequest=0 , lastmillis = 0;
        unsigned long newTime = 0, oldTime = 0, ComTime = 6000;
    //---------------- SETUP ----------------------------
      void setup()  {
    //--- OLED ----
      #if RST_PIN >= 0
        oled.begin(&Adafruit128x32, I2C_ADDRESS, RST_PIN);
      #else // RST_PIN >= 0
        oled.begin(&Adafruit128x32, I2C_ADDRESS);
      #endif // RST_PIN >= 0
        oled.setFont(Adafruit5x7);         /*font Oled*/
        // oled.setFont(font8x8);             //bien
        // oled.setFont(Verdana12);           //grand
        // oled.setFont(fixed_bold10x15);     //tres grand
        // oled.setFont(Arial_bold_14);       //grand sympa
        oled.clear();
    //--------------MySensors-------------
        sendSketchInfo("Clock", "2.0");
    //------------------ LOOP -----------------------
    // ---- MyS time --------
       if (now-lastRequest > (ComTime)) {
          requestTime(receiveTime);   // Request time from controller.
          lastRequest = now;
    //----- Tempo Display Oled ----------
      if (now-lastUpdate > 10000) {  //10secondes
        lastUpdate = now;
       // Serial.print(" test lastmillis------------ display : ");
       // Serial.println(timeReceived);
        updateDisplay();
        lastmillis = millis();
    //----- Stat Com ---
        if (timeReceived == 1) {   //En Com Controller stateCom
          ComTime = 480UL*1000UL;    // 480=8 minutes cycles for Control presence controller
        else  {           // Erreur Com Controller
          stateCom = false;
          ComTime = 60UL*1000UL;    // secondes for attempted reconnection to the controller
         // Serial.println(" ----*** Erreur Com Controller *** ---- ");
       } //---Loop
     // -------------------- MyS --------------------------------
       if (receiveTime) stateCom = true ; else stateCom = false;
        newTime = controllerTime;
        setTime(controllerTime); // apl pour TimeLib.h
    //------------Gestion de l'affichage OLED---------------
      void updateDisplay() {
        oled.set1X();           //ligne Message
        oled.setCursor(2, 0);
        printStatDay () ;       // affiche jour de la semaine/poster day of the week
        //oled.print(day());
        oled.set2X();           //ligne Heures
        oled.setCursor(18,1);
        oled.print(hour());
        printDigits(minute());
        printDigits(second());
        oled.set1X();           // ligne jour mois Année / day month year
        oled.setCursor(35,3);
        oled.print(day());
        printDigitsDay(month());
        printDigitsDay(year());
    //-------- Day displaying-------
      void printDigitsDay(int digitday) { //function for Day displaying "0" and separator "/" for day/month/year values
        oled.print("/");
          if(digitday < 10)
            oled.print('0');
            oled.print(digitday);
    //-------- Time displaying-------
      void printDigits(int digits) {  //function for Time displaying "0" and separator ":" for hour:minute:sec values
        oled.print(":");
          if(digits < 10)
            oled.print('0');
            oled.print(digits);
    //------ conversion date en texte (fonction weekday) et statu Com Controller -----------
      void printStatDay () {   //function for display Day texte
        oled.invertDisplay(!(stateCom)); // inverse N/B Oled sur erreur Com
        if(stateCom == true) { oled.print("com  "); }    //com okai
        if(stateCom == false){ oled.print("Error"); }    //com Error
          // oled.print(stateCom);
            oled.print("  ");
        if(weekday() == 1) { oled.print("dimanche"); }  //Sunday
        if(weekday() == 2) { oled.print("lundi"); }     //Monday
        if(weekday() == 3) { oled.print("mardi"); }     //Tuesday
        if(weekday() == 4) { oled.print("mercredi"); }  //Wednesday
        if(weekday() == 5) { oled.print("jeudi"); }     //Thursday
        if(weekday() == 6) { oled.print("vendredi"); }  //Friday
        if(weekday() == 7) { oled.print("samedi"); }    //Saturday
         oled.print(" ");
         oled.print(day());
    //-------------------FIN PGM --------------------------
    //------------------- INFO -------------------
    why open a new post, there is still some space here 🙂
  • For your information, RTC ... DS323x
    the library provided with Mysensors can be blocking on loss of Com or lack of power supply of DS3231 module.
    new features are added to wire
    https://github.com/Makuna/Rtc/discussions/151
    ... the most with the makuna version, it gives error messages, and restarts after a loss of Communication or Power.
    the terminal test is copied.
    compiled: Jan 27 202312:42:11
    01/27/2023 12:42:11
    RTC lost confidence in the DateTime!
    RTC is the same as compile time! (not expected but all is fine)
    01/27/2023 12:42:11
    19.25C
    01/27/2023 12:42:14
    19.25C
    -------- power loss -----
    RTC communications error = 4
    01/01/2000 00:00:00
    0.00C
    RTC communications error = 5
    01/01/2000 00:00:00
    0.00C..
    ------------- return power supply +5v ----
    01/01/2000 00:00:12
    19.50C
    01/01/2000 00:00:15
    19.50C
    https://forum.arduino.cc/t/librairie-makuna-freez/1081415/34
1 out of 10
  • Bug Reports   28 Mar 2014, 18:20
  • Announcements   24 Jul 2024, 05:25
    164
  • Announcements   4 Feb 2023, 20:02
    109
  • Announcements   30 Nov 2022, 20:23
    110
  • Announcements   23 Jan 2025, 00:08
  • Announcements   3 Jan 2023, 15:35
11.5k
112.8k
