  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 54.4k Views 32 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    I'll see if I can replicate it ...been nusy trying to sork out a controller now Heheh.....Not fun!
    • skywatchS Offline
      skywatchS Offline
      skywatch
      I just uploaded the sketch again without the define and it is working - I didn't clear the eeprom before uploading so maybe that would have made a difference? Is there a list of what is held in eeprom anywhere?
      • J Offline
        J Offline
        joseyapor
        Hi instead of using a arduino nano can i use esp8266 for a sensor
        mfalkviddM E 2 Replies Last reply
        • J joseyapor
          @joseyapor yes you can but the esp8266 has very few usable io pins so connecting a radio and sensor at the same time might be difficult.
          • J joseyapor
            E Offline
            E Offline
            Ed1500
            @joseyapor Yes no problem. 8 digital I/O. One of them a bit problematic as input (used for program mode)
            • EuromirE Offline
              EuromirE Offline
              Euromir
              Another newbie sorry.
              Trying to use this as a simple doorbell, just to send a trigger to Domoticz.
              I connect doorbell button to digital pin 3, the Node appears in Domoticz ok as a "security sensor" but shows as state "ON". However pressing the button appears to do nothing sadly, switch status stays as on, and log shows no activity at all?
              Using a Uno (clone) and wondering if somethings up with it? :(
              • L Offline
                L Offline
                LastSamurai
                What does the nodes and/or the gateways log say?
                It might not change in domoticz if you just send on but no off signals but it should still be visible in the nodes log (arduino and in domotizc)
                • EuromirE Offline
                  EuromirE Offline
                  Euromir
                  wrote on last edited by Euromir
                  #48
                  Hold that thought, embarrassingly it might just be a bad connection! Oops
                  Just took it all apart in frustration, had a cuppa and put it back together.
                  And something is triggering now, need to play some more, but first hurdle looks like possibly a simply connection maybe.
                  I'll let you know.
                  • B Offline
                    B Offline
                    bluezr1
                    Not sure what I'm doing wrong but I tried to add more than one sensor and didn't get very far. Was hoping to do a motion and a door sensor from the same arduino.
                    • skywatchS Offline
                      skywatchS Offline
                      skywatch
                      As doors and windows are usually not near power sources would it not be better to have this sketch with a SLEEP function and trigger on interupt?
                      • P Offline
                        P Offline
                        Psilin
                        wrote on last edited by Psilin
                        #51
                        what is the logic of the variable "V_TRIPPED"to use? I just messed a little with the MyController application, and by using the V_TRIPPED the value changes from off to on,and stays on,even if the button is released? ( simular to close an opened door)
                        Should the variable not be of a binary type with according sensor type?
                        • S Offline
                          Slimz
                          I have my sensor working well, Arduino pro mini with an Ethernet gateway using Home Assistant. .This is the first sensor I'm actually using a battery, so I've never really needed it, I see the battery level in HA as 0, how do I turn that on and use the battery level? Any pointers?
                          Thanks!
                          Jim
                          • Steve HadleyS Offline
                            Steve Hadley
                            Dumb question, but how would I set this sketch to have an array of 5 switches? I’ve tried a couple of things but I’m lost
                            • Mitja BlazinsekM Offline
                              Mitja Blazinsek
                              https://forum.mysensors.org/topic/7249/simple-binary-switch-example-trying-to-add-second-switch
                              • R Offline
                                R Offline
                                rodaman
                                wrote on last edited by rodaman
                                #55
                                I rewrite sketch for doors/window/buttons to work with multiple buttons (no rellays) .It shows up in Domoticz but it did not change status buttons if pressed.
                                Can someone look for the skech what I am doing wrong
                                  The MySensors Arduino library handles the wireless radio link and protocol
                                  between your home built sensors/actuators and HA controller of choice.
                                  The sensors forms a self healing radio network with optional repeaters. Each
                                  repeater and gateway builds a routing tables in EEPROM which keeps track of the
                                  network topology allowing messages to be routed to nodes.
                                  Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                                  Copyright (C) 2013-2015 Sensnology AB
                                  Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                                  Documentation: http://www.mysensors.org
                                  Support Forum: http://forum.mysensors.org
                                  This program is free software; you can redistribute it and/or
                                  modify it under the terms of the GNU General Public License
                                  version 2 as published by the Free Software Foundation.
                                  DESCRIPTION
                                  Simple binary switch example updated  for 2 switches
                                  Connect button or door/window reed switch between
                                  digitial I/O pin 3 (BUTTON_PIN below) and GND.
                                  http://www.mysensors.org/build/binary
                                //#define MY_DEBUG
                                //#define MY_RADIO_NRF24
                                #define MY_GATEWAY_SERIAL
                                //#include <SPI.h>
                                #include <Bounce2.h>
                                #define FIRST_PIN  8  // Arduino Digital I/O pin for button/reed switch
                                #define noButtons 4
                                const int buttonPin[noButtons];
                                Bounce debouncer[noButtons] = Bounce();
                                int oldValue[noButtons];
                                MyMessage msg[noButtons];
                                 for (int i = 0; i < noButtons; i++) {
                                   msg[i].sensor = i;                                   // initialize messages
                                   msg[i].type = V_TRIPPED; //
                                   pinMode(buttonPin[i + FIRST_PIN], INPUT_PULLUP);
                                   digitalWrite(buttonPin[i + FIRST_PIN], HIGH);
                                   debouncer[i] = Bounce();                        // initialize debouncer
                                   debouncer[i].attach(buttonPin[i + FIRST_PIN]);
                                   debouncer[i].interval(30);
                                void presentation() {
                                 sendSketchInfo("Doors", "1.0");
                                   present(i, S_DOOR);                               // present sensor to gateway
                                   debouncer[i].update();
                                   int value = debouncer[i].read();
                                   if (value != oldValue[i]) {
                                     // Send in the new value
                                     send(msg[i].set(value == HIGH ? 1 : 0));
                                     oldValue[i] = value;
                                • R rodaman
                                    DESCRIPTION
                                  //#define MY_DEBUG
                                  //#include <SPI.h>
                                  #define noButtons 4
                                  #56
                                  @rodaman 0_1474354717994_upload-0e56e228-365f-4d94-90b3-5cf1305c6fae
                                  I fixed it for you.
                                  R 1 Reply Last reply
                                    I fixed it for you.
                                    R Offline
                                    R Offline
                                    rodaman
                                    @mfalkvidd
                                    thank you, i hope will be good soul who fix my sketch itself to work... :-)
                                    • hekH Offline
                                      hekH Offline
                                      @rodaman said in 💬 Door, Window and Push-button Sensor:
                                      What is the purpose of the buttonPin-array?
                                      E.g.
                                      This will fetch a random (probably 0-initialised) value from the array and set pinmode on that value...
                                      R 2 Replies Last reply
                                        E.g.
                                        R Offline
                                        R Offline
                                        rodaman
                                        @hek
                                        That part was in original sketch for establish internal pullup as I understand. I used array to do it for each pins.
                                          E.g.
                                          R Offline
                                          R Offline
                                          rodaman
                                          @hek
                                          I have changed
                                          to
                                          pinMode(buttonPin[i + FIRST_PIN], INPUT);
                                          thanks, but sadlly still does not work...
