  2. Announcements
  3. 💬 Soil Moisture Sensor
99 Posts 33 Posters 49.2k Views 32 Watching
  • I Ihor
    I mean, in sketch: A0, A1: alternative resistance measuring. In MySensors usually, A0 input battery level.
    @ihor I see. Thanks for explaining. Easiest way is probably to use some other analog pin for the battery measurement. Any of A2 to A6 should work.
    • I
      I
      Ihor
      I understood. Thank you
      • I
        I
        Ihor
        How to use:
        Required to interface the sensor: 2 * 4.7kOhm + 2 * 1N4148 (DESCRIPTION in skech)
        And: D6, D7: alternative powering to avoid sensor degradation
        • A0, A1: alternative resistance measuring
        • I Ihor
          How to use:
          #84
          @ihor A6 and A7 can not be used for alternating power. They can do analog read only.
          hekH 1 Reply Last reply
          • I
            I
            Ihor
            understandably. but I asked about D6 (D7). what is the sensor connection?
              @mfalkvidd
              I think they can actually.
                @mfalkvidd
                @hek not according to this https://github.com/arduino/Arduino/issues/6297
                • I Ihor
                  @ihor oh. Sorry. Yes, D6 and D7 are fine.
                    @mfalkvidd
                    Ok, didn't know that these two had a special thing going. Thanks.
                    • I
                      I
                      Ihor
                      I use A0, A1
                      2018-08-12 01:31:11.969 [vent.ItemStateChangedEvent] - MoistHum changed from 11 to 964
                      2018-08-12 01:31:42.386 [vent.ItemStateChangedEvent] - MoistHum changed from 964 to 121
                      2018-08-12 01:31:42.440 [vent.ItemStateChangedEvent] - MoistBat changed from 42 to 43
                      2018-08-12 01:32:13.860 [vent.ItemStateChangedEvent] - MoistHum changed from 121 to 299
                      2018-08-12 01:32:45.300 [vent.ItemStateChangedEvent] - MoistHum changed from 299 to 129
                      2018-08-12 01:33:16.717 [vent.ItemStateChangedEvent] - MoistHum changed from 129 to -11
                      2018-08-12 01:33:48.132 [vent.ItemStateChangedEvent] - MoistHum changed from -11 to -101
                      2018-08-12 01:34:19.528 [vent.ItemStateChangedEvent] - MoistHum changed from -101 to 514
                      2018-08-12 01:34:50.943 [vent.ItemStateChangedEvent] - MoistHum changed from 514 to 1478
                      2018-08-12 01:35:22.355 [vent.ItemStateChangedEvent] - MoistHum changed from 1478 to -265
                      What do I connect wrongly? the results are not true
                      • I
                        I
                        Ihor
                        any ideas?
                        • A
                          A
                          atzohy
                          Hi, I'm trying to get my first sensor to work and I followed this guide https://www.mysensors.org/build/moisture
                          I got my gateway to work and the sensor got discovered in openhab. But I think the values I'm getting are quite odd and I don't think it's working as intended for me.
                          That's my setup, just like on the guide. When I put the sensor it into water, 2 LED start to light up on the small blue board.
                          I decreased the SLEEP_TIME for testing purpose and here's what I'm getting:
                          https://pastebin.com/e93P86aY (too many characters to post it directly here)
                          while this measuring, I put it several times into a cup with water and I dried it. Should negative values even happen? I'm not sure how to work with those values.
                          It feels like, it's just giving me random numbers without actually measuring something.
                            manutremo
                            Hi @atzohy
                            The info in the page is confusing. The small board between the sensor and the arduino is an on-off level switcher. It provides a digital binary singnal so can't be connected to an analog pin on the arduino.
                            If you wish to measure the moisture level with an analogic scale, you need to eliminate that board and then use a voltage divider and an analog pin. The sketch will be also different. Everything in explained above in the thread.
                            You may want to read the full thread and then don't hesitate to come back with your questions.
                            • D
                              D
                              Diazovitch69
                              I have this message :
                              16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
                              26 TSM:INIT
                              28 TSF:WUR:MS=0
                              34 !TSM:INIT:TSP FAIL
                              36 TSM:FAIL:CNT=1
                              37 TSM:FAIL:DIS
                              39 TSF:TDI:TSL
                              10041 TSM:FAIL:RE-INIT
                              10043 TSM:INIT
                              10049 !TSM:INIT:TSP FAIL
                              10051 TSM:FAIL:CNT=2
                              10053 TSM:FAIL:DIS
                              10055 TSF:TDI:TSL
                              What is the problem please ?
                              I'm noob.
                              Thank you
                              E TheoLT 2 Replies Last reply
                              • D Diazovitch69
                                26 TSM:INIT
                                28 TSF:WUR:MS=0
                                36 TSM:FAIL:CNT=1
                                37 TSM:FAIL:DIS
                                39 TSF:TDI:TSL
                                10043 TSM:INIT
                                10053 TSM:FAIL:DIS
                                10055 TSF:TDI:TSL
                                I'm noob.
                                Thank you
                                E
                                E
                                evb
                                @Diazovitch69 You can use the log parser : https://www.mysensors.org/build/parser
                                16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2	Core initialization of NODE, with capabilities RNNNA---, CPU frequency 16 MHz, library version 2.3.2, release 255
                                26 TSM:INIT	Transition to Init state
                                28 TSF:WUR:MS=0	Wait until transport ready, timeout 0
                                34 !TSM:INIT:TSP FAIL	Transport device initialization failed
                                36 TSM:FAIL:CNT=1	Transition to Failure state, consecutive failure counter is 1
                                37 TSM:FAIL:DIS	Disable transport
                                39 TSF:TDI:TSL	Set transport to sleep
                                10041 TSM:FAIL:RE-INIT	Attempt to re-initialize transport
                                10043 TSM:INIT	Transition to Init state
                                10049 !TSM:INIT:TSP FAIL	Transport device initialization failed
                                10051 TSM:FAIL:CNT=2	Transition to Failure state, consecutive failure counter is 2
                                10053 TSM:FAIL:DIS	Disable transport
                                10055 TSF:TDI:TSL	Set transport to sleep
                                The initialization of the transport is failing. So there is a problem between your arduino? and your radio module.
                                You should check your wirings!
                                • D Diazovitch69
                                  26 TSM:INIT
                                  28 TSF:WUR:MS=0
                                  36 TSM:FAIL:CNT=1
                                  37 TSM:FAIL:DIS
                                  39 TSF:TDI:TSL
                                  10043 TSM:INIT
                                  10053 TSM:FAIL:DIS
                                  10055 TSF:TDI:TSL
                                  I'm noob.
                                  Thank you
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  wrote on last edited by TheoL
                                  #96
                                  @Diazovitch69 I have a hard time zooming in the provided wiring, so I can't check it. But as evb says, it looks like the radio isn't connected right. So either it's not wired correctly or you could have a broken radio.
                                  The things I normally do when I encounter this, is first check and double check the wiring. I also measure the individual cables in the dupont cable. It happened to me once I had bought a broken cable. Or another problem I once had, was that the power and ground rail of the bread board weren't connected from the left to the right section. Some broad boards have them connected others don't have that so you need to connect them in the middle.
                                  I even got a free arduino once. Because I was convinced everything was correct so I contacted the supplier and he send me a new Arduino. I replaced it and still the same problem lol. Then I measured and found the cause.
                                  If you're sure the wiring is correct. I'd try out another radio. Be sure that power radio with 3.3v and not 5V.
                                  • N
                                    N
                                    Newzwaver
                                    I see in the pictures of the connection that the soil sensor is attached to 3.3V, GND and D3 but I can't see where D3 is named. How do you obtain a read from D3 if it isn't named in the code?
                                    TheoLT 1 Reply Last reply
                                    • N Newzwaver
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @Newzwaver d3 is called just 3 in the arduino IDE for atmel boards. Only the analog pins have an A suffix. But pin 14 is also A0.
                                      Not sure if it answers your question. I'm on a lunch break :)
                                      • N
                                        N
                                        Newzwaver
                                        Hi
                                        Thank you for your reply and I understand that, if you look at the code you will see that pin 3 isn't named/defined in the coed. Unless I am missing something
