  3. Multisensor PIR and Lux
2 Posts 2 Posters 2.9k Views 2 Watching
  • kchestK
    kchestK
    kchest
    I was finally able to combine the two example sketches (BH1750 Lux sensor and the HC-SR501. I thought I would share it in case it might help out another newbie like me ;-)
     *Light/Motion sensor using sketches from idefix and Henrik Ekblad
     * Arduino BH1750FVI Light sensor
     * communicate using I2C Protocol
     * this library enable 2 slave device addresses
     * Main address  0x23
     * secondary address 0x5C
     * connect the sensor as follows :
     *   VCC  >>> 5V
     *   Gnd  >>> Gnd
     *   ADDR >>> NC or GND
     *   SCL  >>> A5
     *   SDA  >>> A4
     * http://www.mysensors.org/build/light
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    #include <BH1750.h>
    #include <Wire.h>
    #define CHILD_ID_LIGHT 0
    #define CHILD_ID_Motion 1   // Id of the sensor child
    BH1750 lightSensor;
    // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
    // If your controller supports the new V_LEVEL variable, use this instead for
    // transmitting LUX light level.
    MyMessage msgLight(CHILD_ID_LIGHT, V_LEVEL);
    // Initialize motion message:
    MyMessage msgMotion(CHILD_ID_Motion, V_TRIPPED);
    uint16_t lastlux;
      lightSensor.begin();
    void presentation()  {
      sendSketchInfo("Lux/Motion Sensor", "1.0");
      present(CHILD_ID_Motion, S_MOTION);
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      Serial.println(lux);
      if (lux != lastlux) {
          send(msgLight.set(lux));
          lastlux = lux;
     // Read digital motion value
      Serial.println(tripped);
      send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    • T
      tomrask
      Hey Kcest
      Nice work!
      Can you help me if I would like two PIR sensors in the same sketches.
      thank you in advance, Tom
