  3. how add watchdog to my sensors?
10 Posts 4 Posters 5.3k Views 3 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    hi
    for example this code:
    // Enable debug prints
    // #define MY_DEBUG
    // Initialize motion message
    void presentation()  {
      sendSketchInfo("Motion Sensor", "1.0");
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    AWIA 1 Reply Last reply
    • R Reza
      hi
      // #define MY_DEBUG
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @Reza What would be the purpose of the watchdog? To keep the node alive or to make sure the node can make a connection to the gateway?
      (btw Please enclose code in code marks to keep it readable. 0_1474354717994_upload-0e56e228-365f-4d94-90b3-5cf1305c6fae (I did it for you in your posting above)
      R 1 Reply Last reply
      • AWIA AWI
        R
        R
        Reza
        @AWI
        hi ok thank you.
        yes watchdog to keep the node alive and to make sure the node can make a connection to the gateway
        • HonkH
          HonkH
          Honk
          if (!isTransportReady())
                wait(MY_RECONNECT);
          your node just needs to be awake to reconnect to the gateway.
          I've set MY_RECONNECT to 5000 (5sec).
          So far this works for my sleeping battery node.
          isTransportReady could also be isTransportOK. depends on the version you are using.
          R 2 Replies Last reply
          • HonkH Honk
                  wait(MY_RECONNECT);
            R
            R
            Reza
            @Hermann-Kaiser
            hi thank you .
            for this sketch , where put your code?
            #define MY_REPEATER_FEATURE
            #define CHILD_ID_LIGHT 0
            #define LIGHT_SENSOR_ANALOG_PIN 0
            unsigned long SLEEP_TIME = 30000;
            int lastLightLevel;
              sendSketchInfo("Light Sensor", "1.0");
              int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              Serial.println(lightLevel);
                  send(msg.set(lightLevel));
                  lastLightLevel = lightLevel;
              wait(SLEEP_TIME);
            also this is for radio , but for arduino and sensor , how add watchdog ?
            • sundberg84S
              @Reza https://tushev.org/articles/arduino/5/arduino-and-watchdog-timer
              • HonkH Honk
                      wait(MY_RECONNECT);
                R
                R
                Reza
                @Hermann-Kaiser said:
                isTransportOK
                isTransportOK is true , but wait(MY_RECONNECT); have error !
                HonkH 1 Reply Last reply
                • sundberg84S sundberg84
                  R
                  R
                  Reza
                  @sundberg84
                  thank you
                  • R Reza
                    isTransportOK
                    HonkH
                    HonkH
                    Honk
                    @Reza this is a #define MY_RECONNECT 5000
                    just put a time in ms into the wait function.
                    • HonkH Honk
                      R
                      R
                      Reza
                      @Hermann-Kaiser
                      ok .this is true .
                      so where i add this ? after sleep(SLEEP_TIME); ???
                      also this is for radio ? is this right ? so for sensor and arduino !! there are not any function in mysensors?
