  3. Serial Gateway with Sensors
8 Posts 3 Posters 3.8k Views 4 Watching
  • A
    A
    alfredocdmiranda
    Hi guys,
    Sorry if there is already a topic with this, however I couldn't find any helpful information.
    There is a long time since last time I have "played" with MySensors.
    Then, I am trying to run a Serial Gateway with a relay attached. However, it seems that it is not calling the presentation() function.
    My code:
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define CHILD_ID 1
    void presentation() {
     present(CHILD_ID, S_LIGHT);
    My output:
    0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0)
    Another question that I couldn't find in docs is how can I set hardcode the node ID?
    • A alfredocdmiranda
      Hi guys,
      My code:
      #define CHILD_ID 1
      My output:
      @alfredocdmiranda the id of a gateway is always 0, it can not be changed.
      • A
        A
        alfredocdmiranda
        About the Gateway ID it is fine. My main problem is that it seems presentation function is not being run.
          Please use the development branch. There was a bug fixed related to presentations of gateway attached sensors.
          A 1 Reply Last reply
            A
            A
            alfredocdmiranda
            @hek Thanks! Now it worked :)
            Hey, and can you answer me about how to set hardcode ID in some other node(not gateway)?
              @alfredocdmiranda #define MY_NODE_ID
              See https://www.mysensors.org/download/sensor_api_20 for details
                A
                A
                alfredocdmiranda
                @mfalkvidd
                Oh, okay! Thanks. I haven't seen this code!
                Really thanks for your help, guys :)
                  @mfalkvidd
                  @alfredocdmiranda you're wlecome. We're happy to be of assistance.
