  3. [Solved] Communication from Gateway to Sensor node not working
7 Posts 3 Posters 3.6k Views 2 Watching
  • palande.vaibhavP
    palande.vaibhavP
    palande.vaibhav
    wrote on last edited by tekka
    Hello guys,
    I have built temperature sensor DS18B20 using the example sketch, I also have a simple on off switch and LED on my sensor node. I am using Arduino Uno for both Gateway and sensor node.
    My sensors work and show values on the MYSController. Now when I try to control LED using the MYSController, it doesn't work.
    Here is the screenshot of what happens in MYSController:
    I have tried with with and without payload. My code doesn't really need a payload to turn on or off the LED. It just toggles the state of an LED when it receives V_LIGHT message.
    Here is my code for sensor node:
    #include <OneWire.h>
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    //Initialize switch message
    MyMessage msg1(6, V_TRIPPED);
    void before()
      sensors.begin();
      // Setup the buttons for switch
      pinMode(2, INPUT);
      // Activate internal pull-ups
      digitalWrite(2, HIGH);
      //Set LED pin to OUTPUT
      pinMode (4, OUTPUT);
    void presentation() {
      sendSketchInfo("Temperature and switch", "1.0");
      //for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
         present(0, S_TEMP);
         //preset the switch
         present(6, S_DOOR);
         //present LED
         present(7, S_LIGHT);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      //sleep(SLEEP_TIME);
      //Code for switch
      uint8_t value;
      static uint8_t sentValue=2;
      value = digitalRead(2);
      if (value != sentValue) {
         // Value has changed from last transmission, send the updated value
         send(msg1.set(value==HIGH ? 1 : 0));
         digitalWrite(8,!(digitalRead(8)));
         String string = "Value changed to: ";
         Serial.println(string += value);
         sentValue = value;
     // Sleep until something happens with the sensor
      //sleep(0,CHANGE,0);
      Serial.println("Received command");
      //Check for the message from controller
      if (message.type==V_LIGHT)
        digitalWrite(4, !digitalRead(4));
        Serial.println("LED status changed");
    For gateway I am using the example code without making any change. When I send command using MYSController, I can see RX LED blink on the Gateway Arduino but nothing on the sensor node serial monitor.
    Serial Monitor for sensor node:
    What am I doing wrong?
    I will really appreciate the help.
    Thank You,
    Vaibhav
    • sundberg84S
      Looks like the radio communication is fine!?
      What kind of hardware do you use to control LED?
      palande.vaibhavP 1 Reply Last reply
      • sundberg84S sundberg84
        palande.vaibhavP
        palande.vaibhavP
        palande.vaibhav
        wrote on last edited by palande.vaibhav
        @sundberg84
        I just have LED connected to the pin 4 of Arduino.
        I have written code such that when receive() is executed the LED is toggled.
        • palande.vaibhavP palande.vaibhav
          @sundberg84
          @palande.vaibhav - and when you recieve the command it doesnt turn on?
          What does this mean?
          In the relaysketch its this;
          Try HIGH/LOW on a normal led/blink sketch and see if that works.
            palande.vaibhavP
            palande.vaibhavP
            palande.vaibhav
            @sundberg84
            No it doesn't turn on. And I even don't see anything on the serial monitor for the sensor node. I think I should be able to see the READ on the serial monitor for the sensor node. But I don't get that on there.
            This means,
            digitalRead(4) ------> Read the value at pin 4.
            ! -----> Toggle it, that is after reading the value, if it is 0 then make it one and if it is 1 make it 0.
            digitalWrite(4, ----> Write it back to pin 4.
            This line actually checks for the payload that comes with the received signal and makes RELAY_ON or RELAY_OFF decision accordingly.
            So, I am doing much simpler task than relay example. I am trying to not even check what the received message says, I am just checking if I get the message or not and make LED toggle if I do get the message.
            BartEB 1 Reply Last reply
              @sundberg84
              This means,
              BartEB
              BartEB
              BartE
              @palande.vaibhav
              i think the answer is in the code
              Replace sleep(); by wait();
              During a sleep the GW does not receives the message acknowledge and thus claims the broadcast did fail.
              • BartEB BartE
                @palande.vaibhav
                palande.vaibhavP
                palande.vaibhavP
                palande.vaibhav
                @BartE
                @BartE said:
                @palande.vaibhav
                This worked.
                Thanks a lot for the help. I guess I need to read stuff properly.
                Thanks for the help.
