  3. Placing strings in flash
6 Posts 3 Posters 1.6k Views 3 Watching
  • kk02067K
    kk02067K
    kk02067
    Hi.
    This line in a sketch:
    sendSketchInfo("Nod 200 - Altan", "V1.3");
    places the string both in flash and in ram. And when doing this:
    sendSketchInfo(PSTR("Nod 200 - Altan"), "V1.3");
    Places the string only in flash but it don't seem to work.
    the line:
    #include <avr/pgmspace.h>
    is in the begining of the sketch.
    Would like to save the ramspace
    Any ideas?
    mfalkviddM AWIA 2 Replies Last reply
    • kk02067K kk02067
      Hi.
      the line:
      Any ideas?
      @kk02067 why do you get the impression that it doesn't work?
      Does the code not compile? If so, are there any error messages?
      Does the compile, but execution fails? If so, how does it fail?
      kk02067K 1 Reply Last reply
        kk02067K
        kk02067K
        kk02067
        @mfalkvidd
        The string in the gateway becomes unreadable.
        • kk02067K kk02067
          @mfalkvidd
          @kk02067 unreadable in what way? You're not giving us much to go on here :)
          • kk02067K kk02067
            Hi.
            the line:
            Any ideas?
            AWIA
            AWIA
            AWI
            @kk02067 said:
            PSTR
            You cannot just replace any "string" in a sketch with a PSTR macro. As these strings are stored in a 'different' memory space (due to the AVR Harvard architecture) you also need other methods to handle these strings. As far as I know these are not implemented in MySensors.
            A few ways to save RAM space:
            • (simple) if you are using the same text at multiple places. Store the text once in a char array and point to and combine the unique parts
            • (more complex) handle the copy from the ROM to RAM space yourself in a separate routine with a pgm_read_byte(str) function. Just search one of the arduino forums.
            • AWIA AWI
              @kk02067 said:
              PSTR
              kk02067K
              kk02067K
              kk02067
              @AWI thanks for clarifying. I will read up on the subject. Strings i C is not my favourite subject.
