  3. [SOLVED] Only TX led is blinking, ERR and RX led are alway on
7 Posts 3 Posters 2.7k Views 3 Watching
  • G
    G
    gvorster
    I am using v2.0.0 in Arduino ide 1.6.5 and RFM69 radios.
    I am running MockMySensors example on the node and have the following defines:
    #define MY_LEDS_BLINKING_FEATURE
    #define MY_DEFAULT_ERR_LED_PIN 5
    #define MY_DEFAULT_RX_LED_PIN    6
    #define MY_DEFAULT_TX_LED_PIN    7
    In the terminal of the node I see these ok messages:
    RandomNumber:58
    Send Battery Level
    TSP:MSG:SEND 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:58
    Request Time
    TSP:MSG:SEND 254-254-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
    Door is: Closed
    TSP:MSG:SEND 254-254-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:0
    System is: Armed
    TSP:MSG:SEND 254-254-0-0 s=1,c=1,t=15,pt=1,l=1,sg=0,ft=0,st=ok:1
    Temperature is: 25
    TSP:MSG:SEND 254-254-0-0 s=7,c=1,t=0,pt=4,l=4,sg=0,ft=0,st=ok:25
    MY_DEFAULT_ERR_LED_PIN and MY_DEFAULT_RX_LED_PIN are always on and only MY_DEFAULT_TX_LED_PIN is blinking.
    Is this normal behaviour?
    YveauxY 1 Reply Last reply
    • G gvorster
      RandomNumber:58
      Send Battery Level
      Request Time
      Door is: Closed
      System is: Armed
      Temperature is: 25
      YveauxY
      YveauxY
      @gvorster could it be that the leds that are always on are connected inverted wrt the one that's working?
      What hardware are you using and how are the leds connected?
      G 2 Replies Last reply
      • YveauxY Yveaux
        G
        G
        gvorster
        wrote on last edited by gvorster
        I tested a blink sketch on all 3 pins and they are working.
        Also when I switch the pins to:
        #define MY_DEFAULT_ERR_LED_PIN 6
        #define MY_DEFAULT_RX_LED_PIN    7
        #define MY_DEFAULT_TX_LED_PIN    5
        or
        #define MY_DEFAULT_TX_LED_PIN    6
        still only TX is blinking and other leds are always on.
        However I'm using a bare ATMEGA328P in QFP package running on the Arduino Pro Mini 3.3v 8mhz bootloader on a diy pcb board.
        I will try it later today on a Nano on breadboard.
        • G
          G
          gloob
          wrote on last edited by gloob
          How are the leds connected to the arduino? Are the LEDs connected to ground or 5V?
          G 1 Reply Last reply
          • G gloob
            G
            G
            gvorster
            Ah, sorry my bad. That's it. I had it turned around.
            Should have rtfm:
            "Each LED is connected by its anode (long leg) to +5V. The cathode (short leg) is connected through a resistor to one of the following digital pins of the Arduino:"
            • YveauxY Yveaux
              G
              G
              gvorster
              Yes that's it I had it turned around.
              • G gvorster
                YveauxY
                YveauxY
                @gvorster That's why I asked ;-)
                Well, good to hear you solved it :+1:
