  3. Energy meter pulse sensor (ambiguous) won't compile
6 Posts 3 Posters 3.0k Views 3 Watching
  • O Offline
    O Offline
    Opus40
    Hi All
    Im trying to get the Energy meter pulse sensor sketch working but when i test the code i get the following message.
    (exit status 1
    call of overloaded 'set(volatile long unsigned int&)' is ambiguous)
    any ideas would be great
    thanks in advance
    I'm running arduino 1.6.12
    and using the development branch
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "home"
    #define MY_ESP8266_PASSWORD "Password"
    // Enable UDP communication
    //#define MY_USE_UDP
    // #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_IP_ADDRESS 192,168,1,198
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
    #define CHILD_ID 1              // Id of the sensor child
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    bool pcReceived = false;
    volatile unsigned long watt = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
      request(CHILD_ID, V_VAR1);
      // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
      // If no pullup is used, the reported usage will be too high because of the floating pin
      pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
      lastSend=millis();
    void presentation() {
      sendSketchInfo("Energy Meter", "1.0");
      present(CHILD_ID, S_POWER);
      unsigned long now = millis();
      bool sendTime = now - lastSend > SEND_FREQUENCY;
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        // New watt value has been calculated
        if (!SLEEP_MODE && watt != oldWatt) {
          // Check that we dont get unresonable large watt value.
          // could hapen when long wraps or false interrupt triggered
          if (watt<((unsigned long)MAX_WATT)) {
            send(wattMsg.set(watt));  // Send watt value to gw
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // Pulse cout has changed
        if (pulseCount != oldPulseCount) {
          send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh;
        lastBlink = newBlink;
      pulseCount++;
    T 1 Reply Last reply
    • O Opus40
      Hi All
      (exit status 1
      thanks in advance
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
      double oldKwh;
        lastSend=millis();
            oldWatt = watt;
              oldKwh = kwh;
          lastSend = now;
          lastSend=now;
        if (SLEEP_MODE) {
          pcReceived = true;
      void onPulse()
        if (!SLEEP_MODE) {
            return;
        pulseCount++;
      T Offline
      T Offline
      TheoL
      @Opus40 I can't compile it for ESP because I don't have it installed. But when I change it to an RFF sensor it compiles without errors in Arduino 1.6.8 IDE.
      Could you post the compile errors?
      • O Offline
        O Offline
        Opus40
        hi so this is what i get from the error messages
        C:\Users\opus\Desktop\GatewayESP8266_-power_meter\GatewayESP8266-_power_meter.ino: In function 'void loop()':
        GatewayESP8266_-_power_meter:189: error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
        C:\Users\opus\Desktop\GatewayESP8266_-power_meter\GatewayESP8266-_power_meter.ino:189:30: note: candidates are:
        In file included from C:\Program Files (x86)\Arduino\libraries\MySensors-development/MySensors.h:322:0,
                     from C:\Users\opus\Desktop\GatewayESP8266_-_power_meter\GatewayESP8266_-_power_meter.ino:134:
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
        MyMessage& MyMessage::set(const char* value) {
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:222:12: note: no known conversion for argument 1 from 'volatile long unsigned int' to 'const char*'
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
        MyMessage& MyMessage::set(bool value) {
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
        MyMessage& MyMessage::set(uint8_t value) {
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
        MyMessage& MyMessage::set(uint32_t value) {
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
        MyMessage& MyMessage::set(int32_t value) {
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
        MyMessage& MyMessage::set(uint16_t value) {
        C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
        MyMessage& MyMessage::set(int16_t value) {
        GatewayESP8266_-_power_meter:197: error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
        C:\Users\opus\Desktop\GatewayESP8266_-power_meter\GatewayESP8266-_power_meter.ino:197:32: note: candidates are:
        exit status 1
        • O Opus40
          exit status 1
          T Offline
          T Offline
          TheoL
          @Opus40 Might be a bug in the development branch. I use the 2.0 release.
          What happens if you compile it for a normal arduino and not as a gateway? (Just comment all the gateway and esp stuff and uncomment NRF) That's what I did.
          • H Offline
            H Offline
            https://forum.mysensors.org/topic/4820/water-meter-pulse-sensor/7
            • O Offline
              O Offline
              Opus40
              Thanks Hek that's done it, should have looked for threads on the water sensor as well. and thanks to you alsoTheoL
              12.2k
