  3. Basic project setup from start to finish
17 Posts 4 Posters 6.1k Views 4 Watching
  • toddsantoroT Offline
    toddsantoro
    Is there a place that explains how to set up a project from start to finish? I am a complete newbie to IOT. I am looking for instructions on how to start a project like the temperature sensor. What are the first steps? Do I create a directory in the examples folder and clone the library I need into that directory then add the dependencies? I need complete hand holding and I have not been able to find it. Thanks in advance!!!
    • toddsantoroT toddsantoro
      @toddsantoro great that you are joining the world of IoT, welcome to the MySensors community.
      The step by step guide starts here: https://www.mysensors.org/about
        toddsantoro
        Thank you this was just what I was looking for. Cheers!!!
          @toddsantoro you're welcome. Just ask if you get stuck and we'll help you get back on track.
          toddsantoroT 1 Reply Last reply
            toddsantoro
            @mfalkvidd I'm stuck again... I wired up the motion sensor and compiled the code on the motion sensor page. It pushed everything to the Nano but I get this: Sketch uses 7,500 bytes (24%) of program storage space. Maximum is 30,720 bytes.
            Global variables use 371 bytes (18%) of dynamic memory, leaving 1,677 bytes for local variables. Maximum is 2,048 bytes.
            Invalid library found in /Users/xyz/Documents/Arduino/libraries/TAS_motion_sensor: /Users/xyz/Documents/Arduino/libraries/TAS_motion_sensor
            TAS_motion_sensor is my project folder and the ino file is also named that. WHat am I missing??? DO I need to add the serial gateway stuff to the Nano that has the motion sensor attached to it? I am also using the 3.3v for the radio and the 5v for the motion sensor and I am also using the 2 different grounds provided on the board too. Any help would get me past this first sensor and then I think I will be off to the races.
            A 1 Reply Last reply
              A Offline
              A Offline
              AWI
              @toddsantoro From first glance.. you should not put your sketch in the libraries folder but in the sketches folder. Next time please publish the sketch (insert with the "</>" markt in de format menu)
                toddsantoro
                Here is what my Arduino folder looks like: https://www.dropbox.com/s/hfsg3d1xkcoydqq/Screenshot 2016-10-21 16.36.51.png?dl=0
                  toddsantoro
                  Should I create another folder in there called sketches? Here is my sketch copy and pasted from the example on this page: https://www.mysensors.org/build/motion
                   * Version 1.0 - Henrik Ekblad
                   * Motion Sensor example using HC-SR501
                   * http://www.mysensors.org/build/motion
                  // Enable debug prints
                  // #define MY_DEBUG
                  // Initialize motion message
                  void presentation()  {
                    sendSketchInfo("Motion Sensor", "1.0");
                    present(CHILD_ID, S_MOTION);
                    // Read digital motion value
                    bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                    Serial.println(tripped);
                    send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                    @toddsantoro something in the Arduino IDE is referencing libraries/TAS_motion_sensor. Do you have any idea what it could be? As AWI said, nothing should expect TAS_motion_sensor to be in the libraries folder.
                      // #define MY_DEBUG
                      @toddsantoro where did you paste the example sketch? What is the file name and in which folder is that file? (use Sketch->Show sketch folder (ctrk/cmd+K) to locate it)
                        toddsantoro
                        @mfalkvidd I removed everything I have done and started new so that is why you do not see that in the library's folder. I would like to know the exact steps no matter how trivial they are to setting up the sensors project. I am a web programmer and that may be my issue because I know how I would set things up but that does not mean thaty are correct in this situation.
                          @toddsantoro the instructions are available at https://www.mysensors.org/about/arduino
                          After installing the library you can open the examples from File->Examples->MySensors. There is no need to copy-paste from the build page (but that should work as well).
                            toddsantoro
                            @mfalkvidd OK. I will give it a try. Thanks for your help and patience. I hope to automate my whole 417 sqft home and then help others to do the same.
                              toddsantoro
                              @toddsantoro Actually I have read that and I am still in the dark. From the Arduino GUI I go FILE > NEW. COMMAND + S and save it where? It defaults to the Arduino folder on my machine with just Libraries directory in it. Do I create a SKETCHES folder and save the project there? I just don't know what to do???
                                @toddsantoro save it in the suggested directory, next to (not inside) the libraries folder.
                                toddsantoro170T 1 Reply Last reply
                                  toddsantoro170T Offline
                                  toddsantoro170
                                  @mfalkvidd ok... what goes in the file? Copy paste from the example of do I somehow use the motion sensor library? I want to get a basic, best practices work flow going. Again thanks for your help.
                                  • toddsantoro170T toddsantoro170
                                    @toddsantoro170 using the example file without modification is usually the best way to start.
