  3. Error with Atmospheric Pressure Sensor - TSP:CHKUPL:FAIL (hops=255)
3 Posts 2 Posters 1.2k Views 2 Watching
  • TeknorT Offline
    TeknorT Offline
    Teknor
    Hi All,
    Thanks for a great community.
    I try to get a atm pressure sensor to work together with a 2.0 gateway. I use the standard sketch in the demo site (https://www.mysensors.org/build/pressure) but get error messages. Is this sketch not compatible with MyS 2.0?
    This is the error log from the sensor, please see the last few lines with errors:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=5)
    TSM:FPAR
    TSP:MSG:SEND 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-5 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=5)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=5)
    TSM:UPL
    TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    !TSM:UPL:FAIL
    TSM:FPAR
    Thanks for any advice!
    S 1 Reply Last reply
    • TeknorT Teknor
      Hi All,
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=5)
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=5)
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      @Teknor - looks like its looping and checking its way. What kind of gateway do you use and is it updated with 2.0 ?
      • TeknorT Offline
        TeknorT Offline
        Teknor
        wrote on last edited by Teknor
        @sundberg84 Thanks for your response. I am using an Arduino Nano connected to a RPI II (serial gateway). Using the sketch and have followed the guidelines in the build section here. No modifications in the serial sketch settings or configuration - using standard setup. I have a few other nodes up and running (light sensors, temp and humidity sensors) working perfectly.
