  3. need help with node not sending info
8 Posts 2 Posters 2.5k Views 1 Watching
  • carlekiC
    carlekiC
    carleki
    wrote on last edited by carleki
    I have just make my "2AA slim node" and in the serial monitor here is what I obtain :
    send: 90-90-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
    send: 90-90-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=fail:1.5.4
    send: 90-90-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    repeater started, id=90, parent=0, distance=1
    send: 90-90-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=fail:Temp Sens Bat
    send: 90-90-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.3
    send: 90-90-0-0 s=1,c=0,t=23,pt=0,l=0,sg=0,st=fail:
    send: 90-90-0-0 s=2,c=0,t=23,pt=0,l=0,sg=0,st=fail:
    send: 90-90-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 90-90-0-0 s=1,c=1,t=24,pt=7,l=5,sg=0,st=fail:230.0
    send: 90-90-0-0 s=2,c=1,t=25,pt=7,l=5,sg=0,st=fail:4.958
    send: 90-90-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:20.1
    Can someone help me ?
    • sundberg84S
      Hi @carmelo42
      "st=fail" means the receiving node or gateway has problems sending ack back to the sending node.
      Its probably a hardware issue (power and/or range). Try adding a capacitor (http://www.mysensors.org/build/connect_radio#connecting-a-decoupling-capacitor) to the receiving radio, change powersource, move receiver/sender closer to eachother or build a repeater. If you think its a software issue you can try to clear the eeprom (http://www.mysensors.org/build/debug#clearing-eeprom) and reupload your sketch.
      carlekiC 1 Reply Last reply
      • sundberg84S sundberg84
        Hi @carmelo42
        carlekiC
        carlekiC
        carleki
        @sundberg84 thanks :)
        All my nodes (and GW, pretty sure) have already decoupling capacitors ...
        I'm using "standard" temperature sketch :
         * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
         * http://www.mysensors.org/build/temp
        #include <OneWire.h>
        #include <Vcc.h>
        #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
        #define ID_BatPcnt 1
        #define ID_Bat 2
        int node_id = 93; // on donne un ID au node
        const float VccMin   = 1.6;             // Vcc mini attendu, en Volts.
        const float VccMax   = 3.06;           // Vcc Maximum attendu, en Volts (2 piles AA neuves)
        const float VccCorrection = 2.52/2.6; // calibration : Vcc mesuré au multimètre / Vcc mesuré par l'Arduino par vcc.Read_Volts() dans sketch 1/2
        Vcc vcc(VccCorrection);
        unsigned long SLEEP_TIME = 15000; // Sleep time between reads (in milliseconds)900000 15 minutes - 600000 10 minutes
        MyMessage msgBAT_PCNT(ID_BatPcnt,V_VAR1); // on utilise le type V_VAR1 pour le % de charge des piles
        MyMessage msgBAT(ID_Bat,V_VAR2);          // on utilise le type V_VAR2 pour la tension des piles
        int numSensors=0;
        boolean metric = true;
        MyMessage msg(0,V_TEMP);
          sensors.begin();
          gw.begin(NULL, node_id, true);
          gw.sendSketchInfo("Temp Sens Bat", "1.3");
          gw.present(ID_BatPcnt, S_CUSTOM);  // type S_CUSTOM pour le capteur "% de charge"
          gw.present(ID_Bat, S_CUSTOM);      // type S_CUSTOM pour le capteur "tension"
             gw.present(i, S_TEMP);
          gw.process();
        // mesure de Vcc
              float v = vcc.Read_Volts();
              // calcul du % de charge batterie
              float p = 100 * ((v - VccMin) / (VccMax - VccMin));
              // On envoie les données des capteurs et de l'état de la batterie au Gateway
              //gw.sendBatteryLevel(p);  // Inutile...
              gw.send(msgBAT_PCNT.set(p, 1)); // 1 décimale
              gw.send(msgBAT.set(v, 3));      // 2 décimales
          gw.sleep(conversionTime);
            #if COMPARE_TEMP == 1
            #else
          gw.sleep(SLEEP_TIME);
        • carlekiC carleki
          #include <Vcc.h>
          #define ID_Bat 2
          int numSensors=0;
            sensors.begin();
            gw.process();
          // mesure de Vcc
              #else
          @carmelo42 - sounds good, but there are issues with your radio since you get st=fail. Check my advice in the first post and see if something helps you.
          • carlekiC
            carlekiC
            carleki
            I have cleaned the eeprom last night after your advice, and the node is currently at 50 centimeters from the GW. (I have also changed the power source for the node : I was using 1 x CR2032 battery, but last night I have used 2 brand new AA batteries)
            On my Slim AA Node, I have not the C5 cap, I will add it ...
            Can it be a bootoloader issue ? (I'm using my Atmega at 8 Mhz)
            • carlekiC carleki
              @carmelo42 - st:fail is most probalblt not a bootloader issue.
              50cm? Have you tried separating them? Some radios doesnt like when they are to close to eachother. Also try another radio if possible.
              • carlekiC
                carlekiC
                carleki
                yes, I have tried 15 meters away : same problem
                • carlekiC
                  carlekiC
                  carleki
                  I have added the C5 capacitor (on the "My Slim 2AA node"), and replaced the nrf24 from my GW with a NRF24L01+PA+LNA.
                  It's way better :)
                  So far, no problem .. I will keep you updated in the following days
                  Anyway, thanks for your help :dancer:
