  3. 💬 Smart Alarm Clock
💬 Smart Alarm Clock
alarmled ring lightspeakerdomoticzmysensorsclock
37 Posts 10 Posters 14.9k Views 12 Watching
  • N
    N
    Newzwaver
    SO does anyone have any code for this project? I need the arduino code. Thanks in advance, excellent project btw.
    • micahM
      micahM
      micah
      Hey everyone.
      Sorry, had a computer crash and file loss issue a few months ago.
      I can't find my final code file, but I did find an older version (incomplete) called ClockRebuild.ino and I uploaded it to the project.
      Hopefully that helps
      One day I'll come back and truly finish this project, life just keeps getting in the way
      • N
        N
        Newzwaver
        Thanks for the arduino code, i will give it a shot.
        • dbemowskD
          dbemowskD
          I am just curious why you did your switch board the way you did? You can do a similar style switch setup using all the same value resistors. Then you don't have to buy so many different resistor values. Something like this:
          0_1508986754912_upload-8f7eb5ee-6fac-4bb8-8ef7-c5a3c6f82e0c
          In this approach, whichever button you press, the resistor values, being in series, add up giving you a different voltage on your analog pin. With your approach, you use different resistor values on each switch which gives you your different voltage. My approach is only slightly different than yours. I am just wondering if there is an advantage one way or another.
          Nca78N 1 Reply Last reply
          • dbemowskD dbemowsk
            Nca78N
            Nca78N
            @dbemowsk said in 💬 Smart Alarm Clock:
            I guess it is useful in the case when user pushes more than one button ?
            dbemowskD micahM 2 Replies Last reply
            • Nca78N Nca78
              dbemowskD
              dbemowskD
              @Nca78 said in 💬 Smart Alarm Clock:
              I hadn't thought about that, but you are right. In my example, you couldn't press more than one button.
              • Nca78N Nca78
                micahM
                micahM
                micah
                @Nca78
                exactly correct.
                I originally went with the same resistor value so that it was easy. But then when I thought about how many button combinations I wanted (thinking about a real clock where you hold down the alarm set button then press the hour button) I went with different values.
                My implementation still isn't perfect, since I'm a bloody amateur... lol. I think 1 or 2 of the combinations I never got working.
                But for the most part it accomplished what I wanted... provided many buttons and combinations on a single input pin, since I was quickly running out of them
                • micahM
                  micahM
                  micah
                  I found a library online.... #include <AnalogMatrixKeypad.h>
                  I made some modifications (although I can't quite remember what they were), I think about the number of buttons, or combinations, or target values.
                  But generally the library provided the 1 wire, resistor ladder and debouncing functionality I needed
                  dbemowskD 1 Reply Last reply
                  • micahM
                    micahM
                    micah
                    I often wish our fancy mysensor nRF chips only used 1 arduino wire :(
                    • micahM micah
                      dbemowskD
                      dbemowskD
                      @micah Picking resistor values based on the number of switches you have shouldn't be too terribly difficult. You ar just creating a voltage divider circuit. When pushing multiple buttons, you just have to look at the resistor values for the buttons you have and calculate out the parallel resistance. Then you just have to figure out the analog value for any key combinations you want to use and create IF or Switch/Case statements to perform your logic.
                      • dbemowskD
                        dbemowskD
                        So, I didn't look the sketch over for this, but I am planning on building one of these and I have some questions. Does this show in 12 hour or 24 hour format? If it is 12 hour, how do you indicate AM or PM? Also, do you have a way of indicating that alarms are set? I may add some LEDs for these features.
                        micahM 1 Reply Last reply
                        • dbemowskD
                          dbemowskD
                          Here is my start on this. No speaker yet and I haven't added the LEDs for AM/PM and alarms, but that will come.
                          0_1509333312144_upload-29d46ab7-e40a-49b9-aa1e-330beede8488
                          I will need to make a bunch of modifications to the sketch. Mainly because I am using a different RTC module (DS1307). It is one that I have had laying around in my parts bin for years. I get a bunch of compile errors when I try to include the RTC library for this module.
                          0_1509333483010_upload-75b8f66d-d692-412f-9171-d0175ea0402d
                          Here is the board layout so far.
                          0_1509333525901_upload-7777b1c8-2200-4300-aae8-c0a94786b7c8
                            micahM
                            micahM
                            micah
                            @dbemowsk
                            To use a 24 hour clock switch the following bool
                            bool Screen_HourFormat24 = false;
                            I think I used the colon to signify that an alarm was set, I think I flashed it on and off. in the Update_Screen method
                               if ((Alarm1_Enabled) && (!Keys_ShowAlarmOnScreen)){
                                  if(Screen_ClockPoint)ledScreen.point(POINT_ON);
                                  else ledScreen.point(POINT_OFF);
                                } else
                            • micahM micah
                              @dbemowsk
                                  } else
                              dbemowskD
                              dbemowskD
                              @micah said in 💬 Smart Alarm Clock:
                              I wasn't necessarily saying that I wanted to switch to 24hr format. I was wondering if you had a way of indicating AM and PM when in 12 hour format.
                              I see, so when it is blinking there is an alarm and when it is on solid there is not. I may add a different alarm indicator..
                              One other question on this. I see you have 5 buttons on your switch panel. What were your planned uses of those 5 buttons? I didn't see anything documented on that.
                              • micahM
                                micahM
                                micah
                                wrote on last edited by micah
                                #35
                                The method Check_KeyPad (Line 300) handles the buttons.
                                Currently my buttons do the following
                                • show/program alarm
                                • hour
                                • minute
                                • turn alarm on and off
                                • turn on or off nightlight
                                • micahM
                                  micahM
                                  micah
                                  Another thing that I've thought of is removing the RTC module completely since we can query the time from the server periodically.
                                  This would save components and pins, but it would limit the clock to only working with the controller, whereas the current design allows it to run independently
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    :-D Wow, what an amazing design.
