  3. Building a MQTT Gateway
1 Posts 1 Posters 905 Views 1 Watching
  • tandobkhcmT
    tandobkhcmT
    tandobkhcm
    wrote on last edited by tandobkhcm
    Hi Guys! I'm newbie.I want to do smarthome with MQTT and OpenHab. I start to build a MQTT Gateway (Ethernet Shield w5100). This result :
    it's working?. i don't see line "Sending message on topic: mygateway1-out/2/1/1/0/49"
    My Sketch :
    //#define MY_RADIO_NRF24
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out/2/1/1/0/49"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in/2/1/1/0/49"
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
     // #define MY_SOFTSPI
     // #define MY_SOFT_SPI_SCK_PIN 14
    //  #define MY_SOFT_SPI_MISO_PIN 16
     // #define MY_SOFT_SPI_MOSI_PIN 15
    //#endif
     // #ifndef MY_RF24_CE_PIN
      //#define MY_RF24_CE_PIN 5
      //#endif
      //#ifndef MY_RF24_CS_PIN
     // #define MY_RF24_CS_PIN 6
    //#endif
    #define MY_IP_ADDRESS 192,168,10,103
    #define MY_IP_GATEWAY_ADDRESS 192,168,10,1
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 10, 102
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <Ethernet.h>
    #include <DHT.h>
    // set this to the pin you connected the DHT's data pin to
    #define DHT_DATA_PIN 2
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 30000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    void presentation() {
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    i combine sketch "humiditysensor" and " MQTTGateway". is it right?
    thank you for help !
