  3. πŸ’¬ Adjustable Boost Converter with Pass-Through
boostboost convertermcp1640step-upvoltage
34 Posts 8 Posters 12.2k Views 7 Watching
  • NeverDieN
    NeverDieN
    #21
    I just now revised the board to expose the Enable pin, so now you can do a pass-through if you wish. I also made it more compact and gave it a ground-plane on the back. Enjoy!
    • NeverDieN
      NeverDieN
      #22
      i received the upgraded PCB and assembled it. It tests out correctly. The project photo now shows the newest board. Project completed. :)
      For 3.3v output, use R1=976 ohms and R2=562 ohms, as per the datasheet.
      NeverDieN 1 Reply Last reply
      • NeverDieN NeverDie
        NeverDieN
        NeverDieN
        BTW, the same PCB and circuit can also be used with the MCP1640T instead of the MCP1640C if so desired. In that case, the ENABLE pin acts like an ON/OFF switch, instead of an ON/Pass-through switch.
        • KoreshK
          KoreshK
          Koresh
          Just little tip from me :) Use thermal relief instead of direct polygon connection.
          It is much more useful in such cases.
          • KoreshK Koresh
            NeverDieN
            NeverDieN
            @Koresh said in πŸ’¬ Adjustable Boost Converter with Pass-Through:
            Where do I put that exactly?
            KoreshK 1 Reply Last reply
              KoreshK
              KoreshK
              Koresh
              @NeverDie
              • NeverDieN
                NeverDieN
                Sorry if I'm being dense, but how are the thermal reliefs better? What's their advantage?
                  KoreshK
                  KoreshK
                  Koresh
                  wrote on last edited by Koresh
                  #28
                  @NeverDie It is much easier to solder the wire to pads with relief connection than the wire to directly connected pads. Your soldering point even can be unreliable if your pad is directly connected to very huge polygon and your soldering iron don't have enough power.
                  • B
                    B
                    bilbolodz
                    Please upload it on PCBS.io and provide a direct link
                    B 1 Reply Last reply
                    • B bilbolodz
                      B
                      B
                      bilbolodz
                      I've uploaded it on PCBs.io:
                      https://PCBs.io/share/zagYj
                      ordered but no tested yet. Cost of for PCB: 1,35 USD
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        #31
                        @NeverDie I have got MCP1640CT-I/CHY in SOT-23 (BX5V marking on the chip)
                        Can these be used for this project please?
                        I also have some 8 pins ones, but there are not suitable
                        • alexsh1A alexsh1
                          NeverDieN
                          NeverDieN
                          @alexsh1
                          If the pinout is the same, then the PCB should work.
                          • openhardware.ioO openhardware.io
                            https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
                            Shravan V.KS
                            Shravan V.KS
                            Shravan V.K
                            @openhardware-io
                            I am having issues can someone help
                            I am getting output voltage same as input , i removed enable pin supply still i was getting output voltage same as input what might be the issue?
                            • skywatchS
                              skywatchS
                              skywatch
                              Did it work before or is it a new build?
                              With your input, this post could be even better πŸ’—
