  3. Help hacking a LED outdoor security light motion sensor
8 Posts 2 Posters 3.1k Views 2 Watching
  • breimannB
    breimannB
    breimann
    Hi there, love this community! You all rock!
    My topic relates to an outdoor LED security light i'm trying to turn into a node on my MYS network.
    I have 3 of them, they have a 6v battery pack on them, a pretty standard motion sensor and a high intensity LED. Also a 7v 1W solar panel to charge the battery.
    I measured the voltage that the sensor sends to the LED and it's 3.95volts.
    My question is this:
    I'm hoping to put a Pro Mini 3.3volt 8MHz inside plus a 1 channel relay board plus NRF.
    BUT
    **If I just directly send the motion sensor triggered voltage of 3.95volts to a digital input pin on the Pro Mini, would it blow something up since it's more than 3.3volts??
    Thanks!
    AWIA 1 Reply Last reply
    • breimannB breimann
      BUT
      Thanks!
      AWIA
      AWIA
      AWI
      @breimann that would be a risk. I can think of a few other options. But to keep your line of thought : use a voltage divider or resistor with a 3v zener diode.
      breimannB 2 Replies Last reply
      • AWIA AWI
        breimannB
        breimannB
        breimann
        Thanks @AWI. Can you possibly send a little circuit diagram or a link to one like you are referring to?
        I was thinking of using an SMD 3.3v regulator but it seems like a bit of overkill and I'm trying to save on space as much as possible.
        • AWIA AWI
          breimannB
          breimannB
          breimann
          @AWI do you mean something like this?
          where the 5v input is my 3.95v and I replace the zener with a 3v zener instead?
          If that's right, could you help me with calculating the value of the resister and the exact specs for the zener please?
          Thanks in advance.
            Thanks in advance.
            AWIA
            AWIA
            AWI
            @breimann That is exactly what I meant ;-) You can use any zener (3.3V is fine also) and the value of 10kohm for the resistor is ok.
            Another solution would be to just use a 5v pro-mini.
            breimannB 1 Reply Last reply
            • AWIA AWI
              breimannB
              breimannB
              breimann
              @AWI thanks a lot for this advice. very helpful.
              I could use a 5v pro mini, true, but wouldn't the power consumption be more?
              I also don't have any, just 3.3v ones, 8mhz.
              AWIA breimannB 2 Replies Last reply
                AWIA
                AWIA
                AWI
                @breimann The power consumption of (a non modified) 5v pro mini, is only a little higher. Looking at your setup you should have some power left.
                But then again, if you have only 3.3v ones available.. go for the zener solution.
                  breimannB
                  breimannB
                  breimann
                  @AWI i've since done some more work on this and discovered the switched 3.95v didn't share a common ground with the rest of the circuit. So i ended up hooking up a DIL reed relay PRMA 0105 (5v) onto it, and used the relay contacts to connect to pin D3 on my nano.
                  So i've got it operating that whenever the motion sensor is tripped it toggles my 1 channel relay board, but what isn't working is being able to manually switch it from in domoticz.
                  Would someone be able to take a look at my code which i've taken from this thread
                  My code is:
                  DESCRIPTION
                  Sketch for 1x relay with buttons bistable. After back power all relays set OFF and send correct status OFF to controller.
                  // Enabled repeater feature for this node
                  #define MY_REPEATER_FEATURE
                  #include <Bounce2.h>
                  // Define Relays
                  #define RELAY_ON 1 // GPIO value to write to turn on attached relay
                  // Define Sensor ID's
                  #define SSR_A_ID 1 // Id of the sensor child
                  // Define buttons and relays
                  const int buttonPinA = 3;
                  const int relayPinA = 4;
                  // Define Variables
                  int oldValueA = 0;
                  bool stateA = false;
                  int trigger = 0;
                  Bounce debouncerA = Bounce();
                  MyMessage msgA(SSR_A_ID, V_STATUS);
                  pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                  // After setting up the buttons, setup debouncer
                  debouncerA.attach(buttonPinA);
                  debouncerA.interval(5);
                  digitalWrite(relayPinA, RELAY_OFF);
                  pinMode(relayPinA, OUTPUT);
                  /*--------------------- Added these lines for toggle switch-------------------------*/
                  oldValueA = digitalRead(buttonPinA); // set oldValueA to the current status of the toggle switch
                  // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                  // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                  void presentation() {
                  sendSketchInfo("Relay with Bistable", "1.1");
                  present(SSR_A_ID, S_LIGHT);
                  Example on how to asynchronously check for new messages from gw
                  if (trigger == 0){
                  trigger = 1;
                  debouncerA.update();
                  // Get the update value
                  int valueA = debouncerA.read();
                  if (valueA != oldValueA) {
                  // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                  send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
                  stateA = stateA ? false : true; // invert the state
                  digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF); // toggle the relay
                  oldValueA = valueA;
                  switch (message.sensor) {
                    case 1:
                      stateA = message.getBool();
                      digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                      break;
                    case 2:
                      break;
                    // Write some debug info
                  Serial.println(message.sensor);
                  Serial.print("from node:");
                  Serial.println(message.sender);
