  3. DomotiGa
  4. DomotiGA
DomotiGA
Scheduled Pinned Locked Moved DomotiGa
7 Posts 6 Posters 5.3k Views 3 Watching
  • hekH Offline
    hekH Offline
    Happy to annouce that the DomotiGA controller now is supported.
    https://domotiga.nl/projects/domotiga/wiki/MySensors
    • A Offline
      A Offline
      Anticimex
      Interesting!
      • A Offline
        A Offline
        abalazs
        Super!
        Now I do not know what it would be worth using.
        • D Offline
          diamantmatch
          wrote on last edited by diamantmatch
          hello @hek ,
          i have installed the domotiga server on my ubuntu machine but i can not seem to get the usb connection working :(
          when i start domotiga i can configure the mysensors interface according to the installation guide, but i can not open the serial connection ..
          this is all i got .. what am i doing wrong?
          2014/11/20 23:03:12 [Plugin] MySensors, Instance #1 enabled.
          2014/11/20 23:03:12 [MySensors] ERROR: MySensors serial interface FAILED to connect to port /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A800eFAw-if00-port0
          2014/11/20 23:03:12 [MySensors] ERROR: Cannot open serial port (#5)
          2014/11/20 23:03:12 [MySensors] Relay disabled.
          • D Offline
            daulagari
            @diamantmatch Too bad this is not working.
            The serial port did work for me some weeks back but I have been busy to transition to an Ethernet gateway (not done yet). Let me get the serial gateway back up and give it a try.
            Which version of DomotiGa are you using?
            • D Offline
              diamantmatch
              @daulagari
              i installed DomotiGa with a git command as described on the installation page. so i guess i have th latest version.
              Eventhough i did execute the command sucessfully and the response was that i am already a member of the group i think something must have gone wrong is this step. i wouldnt know how to check or redo/undo whatever this step.
              $ sudo addgroup domo dialout
              thanks!
              • M Offline
                M Offline
                meanpenugin
                Try sudo cat /etc/groups
                This will print the contents of the file "groups" in the /etc directory.
                addgroup modifies this file.
