  3. Two motion sensors on one Arduino. How?
8 Posts 4 Posters 3.4k Views 2 Watching
  • edsteveE
    edsteveE
    edsteve
    Hey,
    pin 2 and 3 can get interrupt on Arduino. Pin 2 is used for radio already. So only one pin left.
    I am so much of a noob that i can't tell if there is a solution for that problem?
    Anybody knows how to get two motion sensors running on one Arduino?
    That would safe me money, time and space :)
    Thx
    ED
    • scalzS
      scalzS
      wrote on last edited by scalz
      Hi.
      Yes you can use multiple interrupts. two ways:
      • http://www.gammon.com.au/forum/?id=11091 . So you can use multiple input on one of your interrupt pin (INT0 or INT1)
      • I'm using this one to save diodes footprint on one of my board : http://gammon.com.au/forum/?id=11488&reply=6#reply6
        But it's less easy in sketch if you're noob
      • edsteveE
        edsteveE
        edsteve
        Thanks for your answer. Great that it is possible even-though it will take some time for me as a noob.
        But as usual: every problem has a solution. Just have to find (ask for) it :dancer:
        • edsteveE edsteve
          Hey,
          Thx
          ED
          @edsteve - Pin2 isnt used by the nrf24l01 what I know. (Atleast not prior to 2.0) You can use this pin as well for interrupt.
          • tbowmoT
            tbowmoT
            tbowmo
            @sundberg84
            We have some changes coming up, that needs the interrupt from NRF, used for queuing of packets. But the feature can be disabled, so you can use PIN2 as interrupt for other purposes. At least as it is now.
            • edsteveE
              edsteveE
              edsteve
              Cool. There is even a noob solution. For now :)
              • edsteveE
                edsteveE
                edsteve
                Huff. I am too nooobish in programming :(
                Can anyone tell me how to change the example code to get a second motion sensor on pin2 working with Domoticz?
                Here the example:
                // Enable debug prints
                // #define MY_DEBUG
                // Initialize motion message
                void presentation()  {
                  sendSketchInfo("Motion Sensor", "1.0");
                  present(CHILD_ID, S_MOTION);
                  // Read digital motion value
                  Serial.println(tripped);
                  send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                  sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                edsteveE 1 Reply Last reply
                • edsteveE edsteve
                  Here the example:
                  // #define MY_DEBUG
                  edsteveE
                  edsteveE
                  edsteve
                  Nobody? :disappointed:
