  3. Node - Gateway communication issues
2 Posts 1 Posters 1.2k Views 1 Watching
  • M Offline
    M Offline
    mihai.aldea
    I have a test setup comprised of two 3.3V Arduino Pro Minis, each hooked to an RFM69HW 433MHz module.
    I configured the Temp/RH node to send the readings every second to the gateway. All works fine until either I reset the gateway, or some hickup occurs and then the remote node stops sending messages even if I reset the gateway, or reinstall its sketch. Looks like if it can't reach the gateway it enters some fault mode and stays there until I reset it.
    Here's the node's sketch
    #define MY_NODE_ID 2
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY   RF69_433MHZ
    #define MY_IS_RFM69HW
    #define MY_RFM69_NETWORKID     100
    #include <Wire.h>
    #include "Adafruit_Si7021.h"
    #define COMPARE_TEMP 0
    unsigned long SLEEP_TIME = 1000;
    Adafruit_Si7021 sensor = Adafruit_Si7021();
    MyMessage msgTemp(1, V_TEMP);
    MyMessage msgRh(2, V_HUM);
    float lastTemp;
    float lastRh;
    boolean requestACK = false;
      delay(100);
      sendSketchInfo("Temperature/RH Sensor N1 RFM69", "1.1");
      sensor.begin();
      present(1, S_TEMP);
      present(2, S_HUM);
      unsigned long startTime = micros();
      lastRh = sensor.readHumidity();
      lastTemp = sensor.readTemperature();
      send(msgTemp.set(lastTemp,2));
      send(msgRh.set(lastRh,2));
      unsigned long endTime = micros();
      unsigned long txTime = endTime - startTime;
      Serial.print("Time awake: "); Serial.print(txTime/1000); Serial.println("ms");
      sleep(SLEEP_TIME);
    And here's the gateway sketch
     * The ArduinoGateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on radio network.
     * The GW code is designed for Arduino Nano 328p / 16MHz
     * Wire connections (OPTIONAL):
     * - Inclusion button should be connected between digital pin 3 and GND
     * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
    bool promiscuousMode = true;
    void presentation() {
    The libraries are untouched and I'm using Arduino IDE 1.6.13 with the AVR Boards version 1.6.15.
    Here's what happens to the node when I reset the gateway:
    Starting sensor (RRNNA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=2)
    TSM:FPAR
    TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=2)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=ok:Temperature/RH Sensor N1
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
    TSP:MSG:SEND 2-2-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 2-2-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    !TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
    Request registration...
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=2, parent=0, distance=1, registration=1
    TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:23.40
    TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.47
    Time awake: 128ms
    TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:23.39
    TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.44
    Time awake: 126ms
    TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.46
    Time awake: 128ms
    TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.45
    Time awake: 126ms
    TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:23.41
    Time awake: 170ms
    Time awake: 168ms
    !TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:41.45
    Time awake: 300ms
    TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:23.39
    Time awake: 147ms
    Time awake: 157ms
    Time awake: 183ms
    !TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:23.40
    !TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=fail:41.45
    Time awake: 333ms
    !TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=fail:23.40
    !TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=fail:41.45
    Time awake: 335ms
    !TSP:MSG:SEND 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=fail:23.39
    !TSP:MSG:SEND 2-2-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=fail:41.46
    Time awake: 335ms
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Time awake: 54ms
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    I don't even know what's the meaning TSP and TNR.
    • M Offline
      M Offline
      mihai.aldea
      It seems that adding:
      is of some help, however I did noticed a large increase in TX time even though i set
      So the whole protocol appears to resemble more with TCP rather than UDP. All things considered I believe the remote battery powered nodes should be able to successfully recover from a temporarily gateway failure without increasing their TX time substantially. The TNR state is excellent when it comes to TX time during gateway failure but it misses a mechanism to automatically recover from this state once the gateway is back. ** MY_PARENT_NODE_IS_STATIC** allows for recovery but at the expense if doubling the TX time. So in production you either manually reset all sensor nodes after a gateway failure, or you take immediate action to minimize the impact on the sensors batteries.
