  3. RFID Reader ID-3LA
RFID Reader ID-3LA
9 Posts 2 Posters 2.9k Views 2 Watching
  • J
    J
    jeti
    Hello everybody,
    i am trying to establish a node with a RFID reader to recognice which Resident is at home. Therefore I have a ID-3LA including antenna.
    The reader works fin with this sketch:
    #include <SoftwareSerial.h>
    SoftwareSerial rfid = SoftwareSerial(5, 6);
    String msg;
      Serial.begin(9600);
      rfid.begin(9600);
      Serial.println("Ready");
    void loop(){
      msg = "";
      while(rfid.available()>0) {
        msg += char(rfid.read());
        delay(1);
      if(msg.length() >= 13) {
         msg=msg.substring(1,13);
         tone(4, 262, 100);
         Serial.println(msg);
    this code results on the serial Monitor with 9600 baud in something like:
    Ready
    0100B058FD14
    which is excactly what i want (for now).
    But Iam strugeling implementing it into MySensors, that is what i came up with:
     * ID-3LA       Arduino
     * GND   ->   GND
     * VCC   ->   +3.3V
     * D0   ->   D5
     * D1   ->   D6
     * FORM -> GND
    #define MY_NODE_ID 102
    String key;
    MyMessage KeyMsg(CHILD_ID, V_VAR1);
      Serial.begin(9600);
      rfid.begin(9600);
      //Serial.println("Ready");
    void presentation()  {
      sendSketchInfo("RFID Reader", "1.0");
      present(CHILD_ID, S_CUSTOM);
    void loop(){
      key = "";
        key += char(rfid.read());
        delay(1);
      if(key.length() >= 13) {
         key=key.substring(1,13);
         Serial.println(key);
         send(KeyMsg.set(key));
    but i do not get any readings... as i still consider myself as a started i have very little clou where to beginn finding the wrong/missing parts. It would be great to get some indications or tips.
    thanks in advance!
    • J jeti
      Hello everybody,
      String msg;
        Serial.begin(9600);
        rfid.begin(9600);
      void loop(){
        msg = "";
          delay(1);
           tone(4, 262, 100);
      Ready
      0100B058FD14
       * ID-3LA       Arduino
       * GND   ->   GND
       * VCC   ->   +3.3V
       * D0   ->   D5
       * D1   ->   D6
       * FORM -> GND
      String key;
        Serial.begin(9600);
        rfid.begin(9600);
      void loop(){
        key = "";
          delay(1);
      thanks in advance!
      @jeti could you post the debug output of the node? I looked at the sketch but didn't notice anyhong suspicious.
      • J
        J
        jeti
        so this is the debug:
        I also just figurer out, that i can only see the tag code when i use 9600 baud, thats why the first line is messed up. When i use 115200 baud the tag ID does not show up...
        ¸Ëÿi"ùŸÒ9q„Š3ñ“â@Ù8>‹`ÿÊ<›Ð%ŠÆ/t6þTSP:MSG:SEND 102-102-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        TSP:MSG:SEND 102-102-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
        TSP:MSG:SEND 102-102-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:READ 0-0-102 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        TSP:MSG:READ 0-0-102 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        TSP:MSG:SEND 102-102-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=ok:RFID Reader
        TSP:MSG:SEND 102-102-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
        TSP:MSG:SEND 102-102-0-0 s=1,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
        Request registration...
        TSP:MSG:SEND 102-102-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-102 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=102, parent=0, distance=1, registration=1
        TSP:MSG:READ 154-154-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        TSP:MSG:BC
        0100B058FD1
        TSP:MSG:SEND 102-102-0-0 s=1,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=ok:1
        0100B058FD1
        TSP:MSG:BC
        can it be the case the the format of the tag ID is not correct?
        thanks
        • J jeti
          Node registration=1
          TSP:MSG:BC
          0100B058FD1
          0100B058FD1
          TSP:MSG:BC
          thanks
          @jeti Looks like it has no trouble reading the tag, the print fro the node matches the one you got with the first sketch. st=ok means that the gateway acknowledged the message so it got through alright.
          What does the gateway receive? (could you post the debug log?)
            I think the problem is that Domoticz doesn't support V_VAR1. This post suggests to use V_TEXT instead.
            • J
              J
              jeti
              wrote on last edited by jeti
              I am using FHEM as controller.
              Log of the gateway:
              0;255;3;0;9;TSP:MSG:READ 102-102-0 s=1,c=1,t=24,pt=1,l=1,sg=0:1
              102;1;1;0;24;1
              so it receives a "1" correct?
              Can Mysesnors handle strings?
              • J jeti
                Log of the gateway:
                102;1;1;0;24;1
                @jeti Yes that is correct.
                https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/4 has info on how to read the debug messages.
                pt=1 means payload type 1. Payload type 1 is "byte". According to https://www.mysensors.org/download/serial_api_20#variable-types V_VAR1 has a custom type. I don't know what that means, but it looks like the MySensors library interprets that as a byte, which won't be very useful for sending an RFID tag. I have not used the custom variable types and I don't know how they work unfortunately.
                Yes, MySensors handles strings. Use S_INFO and V_TEXT as suggested in the post I linked to above.
                J 1 Reply Last reply
                  J
                  J
                  jeti
                  @mfalkvidd:
                  also with S_INFO amd V_TEXT the gateway only receives a "1"...
                  I just searched and played a little more and i got i working now:
                   * ID-3LA       Arduino
                   * GND   ->   GND
                   * VCC   ->   +3.3V
                   * D0   ->   D5
                   * D1   ->   D6
                   * FORM -> GND
                  int  val = 0;
                  char code[10];
                  int bytesread = 0;
                    Serial.begin(9600);
                    rfid.begin(9600);
                  void loop(){
                  if(rfid.available() > 0) {          // if data available from reader
                      if((val = rfid.read()) == 10) {   // check for header
                        bytesread = 0;
                        while(bytesread<10) {              // read 10 digit code
                          if( rfid.available() > 0) {
                            val = rfid.read();
                            if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
                              break;                       // stop reading
                            code[bytesread] = val;         // add the digit
                            bytesread++;                   // ready to read next digit
                        if(bytesread == 10) {              // if 10 digit read is complete
                          Serial.print("TAG code is: ");   // possibly a good TAG
                          Serial.println(code);            // print the TAG code
                        bytesread = 0;
                       send(KeyMsg.set(code));
                  The issue seemed to be the string, now with a char it works...
                  now i only need to get reset the reader every now an then to recognice if a tag is removed. The reader only updates when a tag enters the reading adistance but not when it leaves it.
                  thanks!
                  • J jeti
                    @mfalkvidd:
                     * ID-3LA       Arduino
                     * GND   ->   GND
                     * VCC   ->   +3.3V
                     * D0   ->   D5
                     * D1   ->   D6
                     * FORM -> GND
                    int  val = 0;
                    char code[10];
                    int bytesread = 0;
                      Serial.begin(9600);
                      rfid.begin(9600);
                    void loop(){
                          bytesread = 0;
                              val = rfid.read();
                          bytesread = 0;
                    thanks!
                    @jeti great work!
