  3. Arduino Pro Mini & DS18B20
7 Posts 3 Posters 5.4k Views 3 Watching
    martim
    I tried for 2 days now to build this project https://www.mysensors.org/build/temp. Unfortunatly I am not able to get this temperature read out with a Arduino Pro Mini. When I use a Nano it works. !?!
    What could be wrong here? I tried 2 different Arduino Pro Mini boards but both don't work.
    What could be different between the Arduino Pro Mini and Nano?
    • bjacobseB
      bjacobseB
      bjacobse
      wrote on last edited by bjacobse
      Do have the famous 4k7 Ohm resistor from VCC to data pin? DS18B20 min voltage is 3.0V and regardless if you use a 5V or 3,3V Arduino voltage it should work.
      Maybe if you use read too quick it can't get enough voltage/power to the DS18B20 in parasite power mode
        martim
        Yes, I have the 4k7 resister from VCC to data pin. The voltage is 3.3.
        • bjacobseB
          bjacobseB
          bjacobse
          when compiling in Arduino IDEdo you remember to select correct Arduino board, Pro Mini and choose 3.3v 8MHz.
          Tools->Board->"Arduino Pro or Pro Mini"
          Tools->Board->Processor->3,3V 8MHz
          Maybe if you forget this you will compile with wrong oscillator frequency and get wrong timings to your communication to DS18B20
          M 1 Reply Last reply
          • bjacobseB bjacobse
            martim
            @bjacobse
            Thanks!! Yes this was the trick! Wrong Speed!
            Happy New Year!!
            bjacobseB 1 Reply Last reply
            • M martim
              @bjacobse
              Happy New Year!!
              bjacobseB
              bjacobseB
              bjacobse
              @martim
              Good that you replied what made the trick for you, so other can read what to check :-)
              Godt Nytår
              solaS 1 Reply Last reply
                @martim
                Godt Nytår
                solaS
                solaS
                sola
                @bjacobse
                Couldn't agree more.
                This might just be the problem I face.
