  3. Multiple buildings - two gateways or repeaters?
6 Posts 2 Posters 3.3k Views 3 Watching
  • N
    N
    namomitk
    I have two buildings on my property. In building A, I have setup an RPi3 with HomeAssistant as a controller and using NRF24 configured as an MQTT Gateway. I have configured a few sensors and successfully report them in Hass.
    I would like to expand to building B. Wifi and LAN reach building B.
    I have:
    Arduino UNO R3 / W5100 Shield
    Can I use the MQTT Gateway sketch? Will this be a problem if the Arduino picks up on one of the sensors from Building A?
    OR
    Should I use the Repeater node sketch? Is this as flexible? Can I still attach sensors or actuators to the repeater node?
    Any tips?
    I've searched and searched and can't seem to figure out the best way or a functional way of setting this up.
    Thanks in advance.
    • N namomitk
      I have:
      OR
      Any tips?
      Thanks in advance.
      A MySensors network can only have one gateway. Therefore, you should probably have a separate network for building b. The networks are separated by using different radio channels (#define MY_RF24_CHANNEL , see https://github.com/mysensors/MySensors/blob/dd9dff77ed1948db2b348bbdb82d0d3daa9e8e3a/MyConfig.h#L544 For details)
      Sensors and actuators can be attached to repeater nodes, but adding a repeater node will only help if the repeater node is able to forward the messages so they reach a gateway.
      N 1 Reply Last reply
      • N
        N
        namomitk
        This post is deleted!
          N
          N
          namomitk
          @mfalkvidd
          That makes sense. I think I can run with that.
          So Building A would run on CH76 by default. Building B I would select a different channel for the gateway out there and configure the sensors/actuators to communicate on that channel, say 124.
          When I setup the MQTT gateway for building B, can I publish/subscribe to the same topic prefix as building A's gateway or do they need to be different? If both "networks" had a relay node 1, would telling one of them to "turn off" cause them both to turn off. I imagine the payloads would be the same?
          • N namomitk
            @mfalkvidd
            @namomitk I think you would need different topics. As you said, there would be trouble differentiating the nodes otherwise.
              N
              N
              namomitk
              wrote on last edited by namomitk
              Edit: Found this in the forums. Is it still relevant or did 1.6.15/16 solve the issue? https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/3
              I've setup the UNO with the default sketch and made the changes to make it a separate gateway.
              I'm seeing the following on repeat. I've tried a few changes here or there to no success.
              Serial output shows:
              IP: 192.168.4.35
              0;255;3;0;9;MQTT connected
              0;255;3;0;9;Sending message on topic: mysensors-outb/0/255/0/0/18
              0;255;3;0;9;Message arrived on topic: mysensors-inb/3/255/3/0/6
              0;255;3;0;9;!TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:I
              0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSF:WUR:MS=0
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              Mosquitto log shows:
              1483156702: New connection from 192.168.4.35 on port 1883.
              1483156702: New client connected from 192.168.4.35 as mygateway2 (c1, k15, u'pi').
              1483156717: Socket error on client mygateway2, disconnecting.
              Any ideas?
