  3. Mysensors TFT LCD Display
1 Posts 1 Posters 3.7k Views 4 Watching
  • gersongarcia67G
    gersongarcia67G
    gersongarcia67
    wrote on last edited by gersongarcia67
    Overview
    This is my project to add TFT LCD 1.8" color display to my home automation.
    I use TFT LCD 1.8" Full Color 128x120 SPI Display module compatible with Adafruit ST7735 Driver.
    Since Mysensors Radio also uses SPI, I connect the display using "any pin" method, it is slower than SPI but it will not interfere with the radio.
    WiringThings Up
    Start by connecting the radio module.
    Required libraries
    Adafruit ST7735 Library
    Adafruit GFX Library If you want to display bitmap images.
    Example
    This example will:
    • Request the current date and time from the controler when power on/reset.
    • Use "display mask" to only update parts of display to improve performance.
    • Update display every minute.
    • It uses Arduino Time library to manipulate date and time.
    • It display message sent by your controller.
     * Created by Gerson Garcia <gersongarcia67@hotmail.com>
     * Copyright (C) 2016-2017
     * Version 1.0: Gerson Garcia
     * This sketch provides an example of how to implement a TFT LCD 1.8" color display
    #include <Adafruit_GFX.h>    // Core graphics library
    #include <Adafruit_ST7735.h> // Hardware-specific library
    #include <EEPROM.h>
    #include <TimeLib.h>
    // For the breakout, you can use any 2 or 3 pins
    // These pins will also work for the 1.8" TFT shield
    #define TFT_CS     5
    #define TFT_RST    0  // you can also connect this to the Arduino reset
                          // in which case, set this #define pin to 0!
    #define TFT_DC     6
    // Option 2: use any pins but a little slower!
    #define TFT_SCLK 8
    #define TFT_MOSI 7
    Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
    #define CHILD_TFT_ID 1   // Id of the sensor child
    //MyMessage msg(CHILD_TFT_ID, V_TEXT);
    String RadioData;     // Data received from Radio
    bool timeReceived = false;
    bool clockbuilt=false;
    unsigned long previousMillis=0, lastRequest=0;
      sendSketchInfo("TFT", "1.0");
      present(CHILD_TFT_ID, S_INFO);
    void setup(void) {
      // Request latest time from controller at startup
      requestTime();
      // Use this initializer if you're using a 1.8" TFT
      tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
      // large block of text
      tft.fillScreen(ST7735_BLACK);
      unsigned long currentMillis=millis();
      if (timeReceived) {
        updateclock();
        previousMillis = currentMillis;
        timeReceived=false;
        clockbuilt=true;
      if(clockbuilt) {
        // Received the clock already, build the rest of display
        tft.setTextColor(ST7735_WHITE);
        tft.setCursor(17,65);
        tft.setTextSize(1);
        tft.print("From controller:");
        tft.drawRect(5,75,tft.width()-8,20,ST7735_WHITE);
        tft.fillRect(7,78,tft.width()-11,16,ST7735_BLACK);
        clockbuilt=false;
      // Update display every minute
      if (currentMillis - previousMillis >= 60000) {
        Serial.print("ENTER currentMillis=");Serial.print(currentMillis);Serial.print(" previousMillis=");Serial.println(previousMillis);
        updateclock();
    void updateclock() {
      time_t t=now();
      String weekdays[7]={"SUN","MON","TUE","WED","THU","FRI","SAT"};
      String months[12]={"JAN","FEB","MAR","APR","MAY","JUNFRI","JUL","AUG","SEP","OCT","NOV","DEC"};
      // Update display
      tft.drawRect(0,0,tft.width(),55,ST7735_BLACK);
      tft.fillRect(0,0,tft.width(),55,ST7735_BLACK);
      tft.setCursor(8,5);
      tft.setTextSize(2);
      tft.print(weekdays[weekday(t)-1]);
      tft.setCursor(53,12);
      tft.setTextSize(1);
      tft.print(months[month(t)-1]);
      tft.print(" ");
      tft.print(day(t));
      tft.print(" ");
      tft.print(year(t));
      tft.setCursor(15,30);
      tft.setTextSize(3);
      if (hour(t)<10) { tft.print("0"); }
      tft.print(hour(t));
      tft.print(":");
      if (minute(t)<10) { tft.print("0"); }
      tft.print(minute(t));
    //  tft.print(":");
    //  if (second(t)<10) { tft.print("0");
    //  tft.print(second(t));
      if (message.type == V_TEXT) {
        // Get the message string
        RadioData=message.getString();
        Serial.print("Incoming data from controller:");
        Serial.println(RadioData);
        // Update display
        //tft.drawRect(0,0,tft.width(),55,ST7735_BLACK);
        //tft.fillRect(0,0,tft.width(),55,ST7735_BLACK);
        tft.setCursor(12,82);
        tft.setTextSize(1);
        tft.print(RadioData);
    // This is called when a new time value was received
    void receiveTime(unsigned long controllerTime) {
      // Ok, set incoming time
      Serial.print("Time value received: ");
      Serial.println(controllerTime);
      setTime(controllerTime);
      timeReceived = true;
    Shopping list
    1.8" inch Full Color 128x120 SPI Full Color TFT LCD Display Module replace OLED
