  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
    mihai.aldea
    @Tag Use this info:
    http://linux-sunxi.org/Sunxi-tools
    To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
    If you haven't done this before, it's quite simple.
    apt-get install sunxi-tools
    cd ~
    bin2fex /boot/script.bin > script.fex
    Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
    Then
    fex2bin script.fex > /boot/script.bin
    Reboot, then you should have the SPI1 active.
    T 1 Reply Last reply
    • R
      R
      Reza
      @marceloaqno
      i have error yet
      orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
      M 1 Reply Last reply
      • M mihai.aldea
        @Tag Use this info:
        cd ~
        Then
        Tag
        wrote on last edited by Tag
        #63
        @mihai.aldea
        Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
        [update]
        • modified the script file,
        • changed spi_used = 1
        • compiled back and rebooted
        just 1 device file in called spidev0.0 no new device files are created..... :(
        dmesg output:
        [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
        [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
        [    0.815569] spi spi0: master is unqueued, this is deprecated
        [    0.816776] spi spi1: master is unqueued, this is deprecated
        Thx, will keep you posted!
        • R Reza
          @marceloaqno
          i have error yet
          marceloaqno
          Code Contributor
          @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
          @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
          M R 2 Replies Last reply
          • M marceloaqno
            mihai.aldea
            Here it is
            root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
            [OK] init system detected: systemd
            [SECTION] Saving configuration.
            [SECTION] Cleaning previous builds.
            [OK] Finished.
            root@opi-pc-1:~/rf24opi/MySensors# make
            gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
            g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
            g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
            g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
            g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
            g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
            g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
            g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
            g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
            g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
            g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
            In file included from examples_linux/mysgw.cpp:77:0:
            ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
            In file included from ./drivers/RF24/RF24.cpp:23:0,
                             from ./MySensors.h:294,
            ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory
            compilation terminated.
            Makefile:98: recipe for target 'build/examples_linux/mysgw.o' failed
            make: *** [build/examples_linux/mysgw.o] Error 1
            • M mihai.aldea
              Here it is
              [OK] Finished.
              marceloaqno
              Code Contributor
              #66
              @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
              rm -rf marceloaqno-spidev
              git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
              cd marceloaqno-spidev
              git checkout spidev
              ./configure
              make
              • M marceloaqno
                R
                R
                Reza
                @marceloaqno
                i have not any folder "gpio" in class folder .
                what am i do ? :(
                can you create a new topic with all steps after full fix on orange pi ?
                thank you. i follow this topic
                  mihai.aldea
                  wrote on last edited by mihai.aldea
                  #68
                  @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
                  root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
                  Cloning into 'marceloaqno-spidev'...
                  fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
                  Anyway, I found another way:
                  git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                  cd marceloaqno-spidev/
                  git pull origin spidev
                  ./configure
                  make
                  This time it compiled successfuly, but when I fired up mysgw all I got was:
                  mysgw: Starting gateway...
                  mysgw: Protocol version - 2.2.0-beta
                  with no other output.
                  Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
                  For reference here's the gpio readall on my OPi PC:
                   +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                   | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                   |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                   |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                   |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                   |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
                   |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
                   |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
                   |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
                   |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                   |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
                   |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                   |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
                   |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
                   |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
                   |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                   |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
                   |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
                   |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                   |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
                   |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                   |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
                   +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                  • M mihai.aldea
                    ./configure
                    make
                    Tag
                    #69
                    @mihai.aldea
                    Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
                    Look at mine:
                    root@orangepizero:~# gpio readall
                     |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
                     |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
                     |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
                     |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                     |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                     |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
                     |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
                     |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                    It is the same... and shows 40 pins while the OPI Zero only has 26.......
                    There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
                    • pansenP
                      pansenP
                      pansen
                      @marceloaqno: are you planning to create a pull request? also, like @Reza suggested i think it would be smart to gather all information somehwhere, unfortunately mysensors does not seem to have a wiki. can we write an article somehow? i could take care of that.
                      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                      • pansenP pansen
                        marceloaqno
                        Code Contributor
                        #71
                        @mihai.aldea sorry about the github link mistake.
                        @pansen Yes, I will.
                        Is the orientation of the pins correct in the image?
                        • M marceloaqno
                          Tag
                          @marceloaqno
                          Nope pinout is reversed!,
                          The link below shows the correct one!
                          https://oshlab.com/orange-pi-zero-pinout/
                          • T Tag
                            @marceloaqno
                            marceloaqno
                            Code Contributor
                            #73
                            @Tag Oops, did I get it right this time (I reuploaded the image)?
                            • T
                              Tag
                              @marceloaqno
                              Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... :( )
                              Used the follwing to for the radio:
                              RF24 radio(2,0);
                              Output from gettingstarted:
                              root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
                              RF24/examples/GettingStarted/
                              STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                              RX_ADDR_P0-1     = 0x0000000000 0xff00000000
                              RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
                              TX_ADDR          = 0xffffffffff
                              RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
                              EN_AA            = 0xff
                              EN_RXADDR        = 0xff
                              RF_CH            = 0xbc
                              RF_SETUP         = 0xff
                              CONFIG           = 0xff
                              DYNPD/FEATURE    = 0xff 0xff
                              Data Rate        = 1MBPS
                              Model            = nRF24L01
                              CRC Length       = 16 bits
                              PA Power         = PA_MAX
                               ************ Role Setup ***********
                              Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
                              • T Tag
                                @marceloaqno
                                RF24 radio(2,0);
                                EN_AA            = 0xff
                                EN_RXADDR        = 0xff
                                RF_CH            = 0xbc
                                RF_SETUP         = 0xff
                                CONFIG           = 0xff
                                Data Rate        = 1MBPS
                                Model            = nRF24L01
                                PA Power         = PA_MAX
                                marceloaqno
                                Code Contributor
                                #75
                                @Tag Could you fill this table with your current setup?
                                nRF24L01 | OrangePi  | OrangePi
                                         | phyPin    | GPIO
                                _________|_______________________
                                VCC      | 3V3-PWR   | 3V3-PWR
                                GND      | GND       | GND
                                CSN      |           |
                                CE       |           |
                                MOSI     | 19        | 15
                                SCK      | 23        | 14
                                MISO     | 21        | 16
                                • M marceloaqno
                                           | phyPin    | GPIO
                                  GND      | GND       | GND
                                  CSN      |           |
                                  CE       |           |
                                  MOSI     | 19        | 15
                                  SCK      | 23        | 14
                                  MISO     | 21        | 16
                                  Tag
                                  @marceloaqno
                                  Sure here it is,
                                           | phyPin    | GPIO
                                  GND      | GND       | GND
                                  CSN      | 24        | 13
                                  CE       | 22        | 2
                                  MOSI     | 19        | 15
                                  SCK      | 23        | 14
                                  MISO     | 21        | 16
                                  Radio seems to be recognised, still need to test data transfer...
                                  • T Tag
                                    @marceloaqno
                                    Sure here it is,
                                             | phyPin    | GPIO
                                    GND      | GND       | GND
                                    CSN      | 24        | 13
                                    CE       | 22        | 2
                                    MOSI     | 19        | 15
                                    SCK      | 23        | 14
                                    MISO     | 21        | 16
                                    marceloaqno
                                    Code Contributor
                                    #77
                                    I created the draft for the official article: https://www.mysensors.org/build/orange
                                    mfalkviddM T R 3 Replies Last reply
                                    • M marceloaqno
                                      @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
                                      jirmJ 1 Reply Last reply
                                        jirmJ
                                        jirmJ
                                        jirm
                                        wrote on last edited by jirm
                                        #79
                                        @marceloaqno
                                        @mfalkvidd @Tag @pansen @Reza @mihai.aldea @hausinger
                                        Wooow woow woow !!!
                                        Only few days "off" and the problem to make work Mysensors on OPI are solved.
                                        So many many thanks to all people here that have been involved to make that OPI good little boards can work with Mysensors.
                                        This is the proof that when good people join can reach the most difficult achievements and all humanity can benefit.
                                        Awesome work !
                                        Regards
                                        • M marceloaqno
                                          Tag
                                          #80
                                          @marceloaqno
                                          Great work!!! the GPIO part most probably needs some additions for OPI zero on the topic of the spidev1.0 driver and the GPIO pins, send it to you once i got everything documented.
                                          Really many thanks for your hard work here!!
