  3. Newbie problems - node not working
3 Posts 2 Posters 1.7k Views 2 Watching
  • pgvP
    pgvP
    pgv
    HI
    I have a RPi gateway setup and appears to be working well...
    pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    However I have a node I am trying to set up and it is not working . It is based on a Leonardo board and I uploaded the dimmable LED sketch to it. Running V2.2 Installed a Cap across 3.3V supply, tried an independent 3.3V supply. I have double...maybe triple checked wiring to the radio which is a NRF24L01+ and I have swapped the modules between the gateway and the node however all I get is this which I understand indicates the Leonardo is not communicating with the radio:
    1260215 TSM:INIT
    1260221 !TSM:INIT:TSP FAIL
    1260221 TSM:FAIL:CNT=7
    1260221 TSM:FAIL:PDT
    1320224 TSM:FAIL:RE-INIT
    1320224 TSM:INIT
    1320230 !TSM:INIT:TSP FAIL
    1320230 TSM:FAIL:CNT=7
    1320230 TSM:FAIL:PDT
    1380232 TSM:FAIL:RE-INIT
    1380232 TSM:INIT
    1380238 !TSM:INIT:TSP FAIL
    1380238 TSM:FAIL:CNT=7
    1380238 TSM:FAIL:PDT
    Anyone got any suggestions of where else to go or what to look for?
    TIA
    T 1 Reply Last reply
    • pgvP pgv
      HI
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      1260215 TSM:INIT
      1320224 TSM:INIT
      1380232 TSM:INIT
      TIA
      TimO
      Hey @pgv!
      At which pins did you connect the NRF24 modules to the Leonardo? The Leonardo uses different pins for SPI than Uno, Nano, Mini.
      I don't have a Leonardo myself, but you should find the SPI pins at the ISP header.
      • pgvP
        pgvP
        pgv
        Thanks @TimO much appreciated. All working OK now! It's easy when you know where to look!
        Just missing a few packets but I will work on that. Thanks again
