  3. HELP !! cannot make Sensor work with RFM69
25 Posts 7 Posters 9.8k Views 8 Watching
  • christophe cluzelC Offline
    christophe cluzel
    Hi everyone, I decided to jump into the wonderful world of IOT and decided to do a simple project to start : a Weather Station, and at a starting point : a Temperature and humidity sensor (using DHT22).
    Sorry in advance for the long email, I tried to put as many details as possible
    So My hardware setup is :
    Gateway : ESP8266-ESP12 / RFM69CW 868 Mhz
    Sensor : Arduino Pro Mini / DHT22 / RFM69CW 868 Mhz
    My gateway code is :
    #define MY_BAUD_RATE 115200
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "xxxxx"
    #define MY_ESP8266_PASSWORD "yyyyyy"
    #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    #define MY_IP_ADDRESS 192,168,0,15
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 2
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
    	// Send locally attech sensors data here
    My Sensor Node Code is :
    // Enable debug prints
    //#define MY_RFM69_FREQUENCY RF69_868MHZ
    //#define MY_IS_RFM69HW
    ..#define MY_RFM69_NETWORKID 100
    //#define MY_RS485
    #define MY_NODE_ID 10
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      metric = getConfig().isMetric;
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    The gateway Connection between ESP8266 and RFM69 I followed this Forum topic
    RFM69 <-> ESP8266:
    DIO0 <-> GPIO4
    SCK <-> GPIO14
    MOSI <-> GPIO13
    MISO <-> GPIO12
    CS <-> GPIO15 (AKA NSS)
    And of course GND + VCC
    For The radio Connection for the sensor node I followed exactly the Mysensors Guide :
    Arduino RFM69
    GND GND
    3.3V VCC
    10 NSS
    13 SCK
    11 MOSI
    12 MISO
    2 DI00
    And DHT22 is connected on Digital PIN3
    Now if I look at the debug from the Sensor Node it seems not able to connect to Radio :+1:
    0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.0
    4 TSM:INIT
    4 TSF:WUR:MS=0
    8 TSM:INIT:TSP OK
    10 TSM:INIT:STATID=10
    12 TSF:SID:OK,ID=10
    14 TSM:FPAR
    3141 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    5148 !TSM:FPAR:NO REPLY
    5150 TSM:FPAR
    8275 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    10283 !TSM:FPAR:NO REPLY
    10285 TSM:FPAR
    13412 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    15419 !TSM:FPAR:NO REPLY
    15421 TSM:FPAR
    18548 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20555 !TSM:FPAR:FAIL
    20557 TSM:FAIL:CNT=1
    20559 TSM:FAIL:PDT
    Looking at the Gateway have the following
    0;255;3;0;9;TSF:LRT:OK
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    ....scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with Cluclus, channel 11
    ip:192.168.0.15,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.15
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.0.15
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/0/0/18
    pm open,type:2 0
    It does connect to the WIFI but it seems pretty much it, nothing else is happening.
    I am honestly loosing my mind I check 25 times the connections. I tried different RFM69 Modules. I triple check the code, Tried to read about everything I can find but I cannot figure out what is wrong.
    Please help...
    christophe cluzelC 1 Reply Last reply
    • christophe cluzelC christophe cluzel
      //#define MY_RS485
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      RFM69 <-> ESP8266:
      DIO0 <-> GPIO4
      SCK <-> GPIO14
      MOSI <-> GPIO13
      MISO <-> GPIO12
      Arduino RFM69
      GND GND
      3.3V VCC
      10 NSS
      13 SCK
      11 MOSI
      12 MISO
      2 DI00
      4 TSM:INIT
      4 TSF:WUR:MS=0
      8 TSM:INIT:TSP OK
      12 TSF:SID:OK,ID=10
      14 TSM:FPAR
      5150 TSM:FPAR
      10285 TSM:FPAR
      15421 TSM:FPAR
      20559 TSM:FAIL:PDT
      ....scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      .IP: 192.168.0.15
      IP: 192.168.0.15
      pm open,type:2 0
      Please help...
      christophe cluzel
      Sorry I forgot to mention : I am using the version 2.0 of Mysensors, I use Arduino IDE 1.6.13.
      I have check the Voltage to the RFM69 and I am getting 3.28V.. and it is quite stable
      For the Gateway, the power is a 9 battery step down via a LM1117 and 2 capacitor of 10uF
      For the Node, the 3.3V is supplies by the Arduino Board (I have tried with a UNO and a NANO as well)
      • F Offline
        F Offline
        Fabien
        Uno is 5V powered and RFM69 inputs are not 5V compliant. Perhaps your radio is dead.
        • F Fabien
          christophe cluzel
          @Fabien I supplied the power from the 3.3V output of the Board not the 5V output, I was very careful about this so I really doubt that I fried the Radio
          • F Offline
            F Offline
            Fabien
            You powered your radio with 3.3V but UNO outputs are 5V (except some specials boards like iteaduino). I fried 1 radio with this mistale !
            • F Fabien
              christophe cluzel
              @Fabien This is the pinout of my board
              I just double check the output from the 3.3V pinout to be sure and I get 3.28V.
              Just to say, I was getting the exact same result with a standalone power supply @3.3V.
              • F Offline
                F Offline
                Fabien
                MISO, MOSI, etc ... are 5V outputs and RFM69 unlike NRF24 is not 5V tolerant even if it's powered with 3.3V
                • F Fabien
                  christophe cluzel
                  @Fabien understand your point and I may have fried it with the UNO, but I doubt it is the cause as I had exactly the same output with my first build with a Pro mini 3.3v, every pin were 3.3V and the debug looked exactly the same. I tried with the UNO after countless attempts with 3.3V boards. But taking your point I will try again with a different radio module and a 3.3V.
                  Any other ideas?
                    Any other ideas?
                    christophe cluzel
                    Following @Fabien idea, I tried with a different RF69M module I had spare with a Arduino Pro Mini 3.3V, I also added a Capacitor of 10uF between the 3.3V of Radio and GND. And I still get the same message.... Arrrgggggg
                    • F Offline
                      F Offline
                      Fabien
                      wrote on last edited by Fabien
                      Ok try t add this in your Gateway sketch (before MySensors.h) :
                      #define MY_RF69_IRQ_PIN 4  // GPIO 4
                      #define MY_RF69_IRQ_NUM 4
                      #define MY_RF69_SPI_CS  15  // GPIO 15
                      I have exactly the same setup on gateway, working fine.
                      • F Fabien
                        christophe cluzel
                        @Fabien I tried yesterday but it doesn't seem to work. I will try again tonight as I did the test in a rush and may have overseen something.
                        I just thought about something, could it be possible that the RFM69 doesn't get enough power ? I will try with a separate power source tonight to rule out this.
                        Thx
                        • mamanM Offline
                          mamanM Offline
                          maman
                          @christophe-cluzel Yes, I got the same problem, I have been 3days to find out the solution, but no result.
                          I configure the RFM69 with ESP8266 as a gateway and Promini as a node.
                          The pin connections same with yours.
                          I realy need help to solve the problem
                            Thx
                            christophe cluzel
                            OK I tried again, recheck the wiring, move DI0 to GPIO5 and added the following in the sketch of the Gateway
                            #define MY_RF69_SPI_CS  5  // GPIO 5
                            Put the RFM69 in a separate power source, added a 100uF capacitor for the radio.
                            And still the same result.....
                            I am litteraly loosing my mind, cannot figure out what else to do...
                              christophe cluzel
                              What I just realized is that neither on the Gateway Debug nor the Node Debug I see the following message :
                              TSM:RADIO:OK
                              how do I know that the Arduino or the ESP is communicating or seeing the RFM module ?
                                TSM:RADIO:OK
                                christophe cluzel
                                I am trying a different approach, I order NRF24L01+ to try tonight and see if I am getting better success with different modules...
                                • mamanM Offline
                                  mamanM Offline
                                  maman
                                  Using NRF24, actually, mysensors system is no problem. The node (ATMEGA328) and the gateway (ESP8266) can work properly. Now we have 3 nodes and one gateway, working properly. We use MyController.org software deployed in cloud server as the controller.
                                  We want to work on RFM69, because the radio can use 433MHz, while NRF24 use 2.4GHz.
                                  This is the crowded frequency.
                                  christophe cluzelC 2 Replies Last reply
                                  • mamanM maman
                                    christophe cluzel
                                    @maman I agree, but I am trying to get my project starting to be fair I do not live in a Mansion and my further sensor will be the one in the Garden for the weather station and the Watering system. So maybe the NRF24L01+ will be ok.
                                    I will keep working in parallel on the RFM69, but right now I feel that I am just wasting time and getting nothing achieved.
                                    I have new RFM69 on Order (RFM69HW instead of the RFM69CW I currently have) I am quite hoping that getting to a differet version of the RFM69 will solve the problem...
                                    • S Offline
                                      hmm..something is wrong with your hardware or settings, with pro mini or esp it should work..
                                      What frequency do you want to use?
                                      and maybe a dumb question, but in case.. have you soldered an antenna on your rfm69 modules?
                                      • S scalz
                                        christophe cluzel
                                        wrote on last edited by christophe cluzel
                                        @scalz I use 868 Mhz, I soldered antenna (82 mm), trust me there is no dumb question :)
                                        I get what you say, it should work but I cannot figure out what is wrong
                                        • mamanM Offline
                                          mamanM Offline
                                          maman
                                          I want to use 433MHz
                                          I have soldered wire antenna (about 17 cm)
