  3. [SOLVED] Raspberry Pi Gateway to Vera UI7 Not adding sensors
12 Posts 4 Posters 5.0k Views 5 Watching
  • P
    P
    pete1450
    wrote on last edited by pete1450
    I've been banging my head against this for hours and I can't figure out why my veralite won't add my sensors. I've used this exact sensor before on UI5 and I can see the gateway acknowledging my movement. For starters I have done a factory reset and added only the gateway device and the "start inclusion" button never seems to do anything in the UI. I can see however that it calls the start procedure because something comes through to the gateway but the stop never happens either. I've been running the start, then the stop, then manually reload lua for good measure. The only thing I can find that seems relevant is copied below. Discarded seems bad.
    If I'm reading correctly near the middle it goes like this:
    0;0;3;0;5;1 get the gateway version
    255;255;3;0;4;1 here, have node id 1
    1;255;0;0;17;2.1.0 responds with version
    1;255;3;0;6;0 request for config
    1;255;3;0;11;Motion Sensor I'm a motion sensor
    1;255;3;0;12;1.0 Sketch version
    and then the node sending data again
    Any help would be appreciated.
    • P
      P
      pete1450
      I've tried going back to UI5 as well but no change. I'd really like to know for starters why the start button in the UI doesnt have any visible effect but aparently starts things behind the scenes.
      • anvilA
        anvilA
        anvil
        I'm having exactly the same problem. Vera never shows any text like "0 devices found" when "Start inclusion" has been pressed, it just remains blank:
        My setup:
        VeraPlus, firmware 1.7.2414
        RaspberryPi Gateway, running MySensors 2.1.0 from master branch on Github. Standard example configuration with NRF24 + IRQ connected.
        Below is the debug output when performing the steps:
        • Fresh start of mysgw on RaspberryPi
        • Restart Vera Luup engine
        • Allow Vera to connect to the Raspberry Pi gateway
        • Press "Start" inclusion from Vera GUI
        • First startup of Motion sensor after EEPROM clear
        • Press "Stop" inclusion from Vera GUI after some time
        I'd also appreciate any help! I'm well and truly stuck.
        Vera debug:
        root@OpenWrt:~# tail -f /var/log/cmh/LuaUPnP.log | grep Arduino
         2227 root      1788 S    grep Arduino
        50      01/15/17 14:56:57.984   luup_log:147: Arduino plugin: loading library L_Arduino ... <0x77037520>
        50      01/15/17 14:56:58.000   luup_log:147: Arduino plugin: library L_Arduino loaded <0x77037520>
        50      01/15/17 14:56:58.001   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 147 <0x77037520>
        50      01/15/17 14:56:58.001   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, -, 147 <0x77037520>
        50      01/15/17 14:56:58.002   luup_log:147: Arduino: Using network connection: IP address is 172.16.24.10:5003 <0x77037520>
        50      01/15/17 14:56:58.102   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 172.16.24.10:5003, 147 <0x77037520>
        50      01/15/17 14:56:58.104   luup_log:147: Arduino: Sending: 0;0;3;0;2;Get Version <0x77037520>
        50      01/15/17 14:56:58.107   luup_log:147: Arduino: Log: Gateway startup complete. <0x72fa3520>
        50      01/15/17 14:56:58.107   luup_log:147: Arduino: Presentation: 0;255;0;0;18;2.1.0 <0x72fa3520>
        50      01/15/17 14:56:58.113   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,ArduinoLibVersion, 2.1.0, 147 <0x72fa3520>
        50      01/15/17 14:57:44.225   luup_log:147: Arduino: Sending: 0;0;3;0;5;1 <0x779ff320>
        50      01/15/17 14:58:02.006   luup_log:147: Arduino: Sending: 255;255;3;0;4;1 <0x72fa3520>
        50      01/15/17 14:58:02.100   luup_log:147: Arduino: Presentation: 1;255;0;0;17;2.1.0 <0x72fa3520>
        02      01/15/17 14:58:02.140   luup_log:147: Arduino: Incoming internal command '1;255;3;0;6;0' discarded for child: nil <0x72fa3520>
        02      01/15/17 14:58:04.111   luup_log:147: Arduino: Incoming internal command '1;255;3;0;11;Motion Sensor' discarded for child: nil <0x72fa3520>
        02      01/15/17 14:58:04.132   luup_log:147: Arduino: Incoming internal command '1;255;3;0;12;1.0' discarded for child: nil <0x72fa3520>
        50      01/15/17 14:58:04.145   luup_log:147: Arduino: Presentation: 1;1;0;0;1; <0x72fa3520>
        50      01/15/17 14:58:04.176   luup_log:147: Arduino: Set variable: 1;1;1;0;16;0 <0x72fa3520>
        50      01/15/17 14:59:07.871   luup_log:147: Arduino: Sending: 0;0;3;0;5;0 <0x779ff320>
        RaspberryPi Gateway debug
        pi@pi3:~/MySensors $ sudo ./bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: Protocol version - 2.1.0
        mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.0
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: Listening for connections on 0.0.0.0:5003
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: New connection from 172.16.24.80
        mysgw: Client 0 connected
        mysgw: Client 0 disconnected
        mysgw: send: Broken pipe
        mysgw: Client disconnected.
        mysgw: Client 0: 0;0;3;0;2;Get Version
        mysgw: Client 0:
        mysgw: Client 0: 0;0;3;0;5;1
        mysgw: Client 0:
        mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        mysgw: TSF:MSG:BC
        mysgw: TSF:MSG:FPAR REQ,ID=255
        mysgw: TSF:PNG:SEND,TO=0
        mysgw: TSF:CKU:OK
        mysgw: TSF:MSG:GWL OK
        mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        mysgw: Client 0: 255;255;3;0;4;1
        mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:1
        mysgw: Client 0:
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        mysgw: TSF:MSG:PINGED,ID=1,HP=1
        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.0
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        mysgw: TSF:MSG:READ,1-1-0,s=1,c=0,t=1,pt=0,l=0,sg=0:
        mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        mysgw: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
        mysgw: Client 0: 0;0;3;0;5;0
        mysgw: Client 0:
        Motion Sensor (MySensors example sketch, 1st start following EEPROM clear) debug:
        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSM:FPAR
        15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        1033 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        1038 TSF:MSG:FPAR OK,ID=0,D=1
        2023 TSM:FPAR:OK
        2024 TSM:ID
        2025 TSM:ID:REQ
        2028 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        2044 TSF:MSG:READ,0-0-255,s=255,c=3,t=4,pt=0,l=1,sg=0:1
        2050 TSF:SID:OK,ID=1
        2052 TSM:ID:OK
        2054 TSM:UPL
        2080 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2091 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2096 TSF:MSG:PONG RECV,HP=1
        2098 TSM:UPL:OK
        2100 TSM:READY:ID=1,PAR=0,DIS=1
        2107 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2113 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2123 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
        2134 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        4144 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
        4156 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        4164 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        4169 MCO:REG:REQ
        4175 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        4182 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        4187 MCO:PIM:NODE REG=1
        4189 MCO:BGN:STP
        4191 MCO:BGN:INIT OK,TSP=1
        4197 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
        4203 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
        4208 MCO:SLP:TPD
        • P
          P
          pete1450
          I've got nowhere. Unless someone happens to pop up with somewhere to look I guess I'll be going back to see if the serial gateway will work. As the problems exists after valid data already comes through I'd think the problem will still exist but who knows.
          blaceyB 1 Reply Last reply
          • P pete1450
            blaceyB
            blaceyB
            blacey
            wrote on last edited by blacey
            First, sorry that no one has chimed in yet but let's see if we can make some progress here before you give up.
            1. Did the identical Vera configuration (UI7 and installed-plugin) work with a Serial gateway?
            2. It would be good if you can follow the steps in this post to confirm the correct Vera plugin is installed (i.e. compare the md5 checksums and if they differ, install the plugin using the link in the thread). https://forum.mysensors.org/topic/5289/ui5-to-ui7-update/13
            Cheers,
            Bruce
            P 1 Reply Last reply
            • anvilA
              anvilA
              anvil
              Hi Bruce, I've followed your advice.
              1. With serial gateway connected - the Vera plugin is working OK!
              15977 root      1788 S    grep Arduino
              50      01/19/17 22:29:43.107   luup_log:147: Arduino plugin: loading library L_Arduino ... <0x7702f520>
              50      01/19/17 22:29:43.126   luup_log:147: Arduino plugin: library L_Arduino loaded <0x7702f520>
              50      01/19/17 22:29:43.127   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 147 <0x7702f520>
              50      01/19/17 22:29:43.128   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, -, 147 <0x7702f520>
              50      01/19/17 22:29:43.128   luup_log:147: Arduino: Trying for a serial connection <0x7702f520>
              50      01/19/17 22:29:43.129   luup_log:147: Arduino: Serial port is connected <0x7702f520>
              50      01/19/17 22:29:43.129   luup_log:147: Arduino: Baud is 115200 <0x7702f520>
              50      01/19/17 22:29:43.129   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 149(115200), 147 <0x7702f520>
              50      01/19/17 22:29:43.131   luup_log:147: Arduino: Sending: 0;0;3;0;2;Get Version <0x7702f520>
              50      01/19/17 22:29:44.495   luup_log:147: Arduino: Log: MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0 <0x72f9b520>
              50      01/19/17 22:29:44.497   luup_log:147: Arduino: Log: TSM:INIT <0x72f9b520>
              50      01/19/17 22:29:44.498   luup_log:147: Arduino: Log: TSF:WUR:MS=0 <0x72f9b520>
              50      01/19/17 22:29:44.500   luup_log:147: Arduino: Log: TSM:INIT:TSP OK <0x72f9b520>
              50      01/19/17 22:29:44.502   luup_log:147: Arduino: Log: TSM:INIT:GW MODE <0x72f9b520>
              50      01/19/17 22:29:44.503   luup_log:147: Arduino: Log: TSM:READY:ID=0,PAR=0,DIS=0 <0x72f9b520>
              50      01/19/17 22:29:44.504   luup_log:147: Arduino: Log: MCO:REG:NOT NEEDED <0x72f9b520>
              50      01/19/17 22:29:44.506   luup_log:147: Arduino: Log: Gateway startup complete. <0x72f9b520>
              50      01/19/17 22:29:44.507   luup_log:147: Arduino: Presentation: 0;255;0;0;18;2.1.0 <0x72f9b520>
              50      01/19/17 22:29:44.509   luup_log:147: Arduino: Log: MCO:BGN:STP <0x72f9b520>
              50      01/19/17 22:29:44.510   luup_log:147: Arduino: Log: MCO:BGN:INIT OK,TSP=1 <0x72f9b520>
              50      01/19/17 22:30:27.504   luup_log:147: Arduino: Sending: 0;0;3;0;5;1 <0x779f6320>
              50      01/19/17 22:30:27.520   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 1, 147 <0x72f9b520>
              50      01/19/17 22:30:27.521   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 147 <0x72f9b520>
              50      01/19/17 22:30:52.681   luup_log:147: Arduino: Log: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0: <0x72f9b520>
              50      01/19/17 22:30:52.683   luup_log:147: Arduino: Log: TSF:MSG:BC <0x72f9b520>
              50      01/19/17 22:30:52.687   luup_log:147: Arduino: Log: TSF:MSG:FPAR REQ,ID=255 <0x72f9b520>
              50      01/19/17 22:30:52.689   luup_log:147: Arduino: Log: TSF:PNG:SEND,TO=0 <0x72f9b520>
              50      01/19/17 22:30:52.691   luup_log:147: Arduino: Log: TSF:CKU:OK <0x72f9b520>
              50      01/19/17 22:30:52.694   luup_log:147: Arduino: Log: TSF:MSG:GWL OK <0x72f9b520>
              50      01/19/17 22:30:53.383   luup_log:147: Arduino: Log: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 <0x72f9b520>
              50      01/19/17 22:30:54.679   luup_log:147: Arduino: Log: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0: <0x72f9b520>
              50      01/19/17 22:30:54.680   luup_log:147: Arduino: Sending: 255;255;3;0;4;1 <0x72f9b520>
              50      01/19/17 22:30:54.727   luup_log:147: Arduino: Log: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:1 <0x72f9b520>
              50      01/19/17 22:30:56.725   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 <0x72f9b520>
              50      01/19/17 22:30:56.728   luup_log:147: Arduino: Log: TSF:MSG:PINGED,ID=1,HP=1 <0x72f9b520>
              50      01/19/17 22:30:56.771   luup_log:147: Arduino: Log: !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1 <0x72f9b520>
              50      01/19/17 22:30:58.768   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.0 <0x72f9b520>
              50      01/19/17 22:30:58.769   luup_log:147: Arduino: Presentation: 1;255;0;0;17;2.1.0 <0x72f9b520>
              50      01/19/17 22:30:58.769   luup_log:147: Arduino: Found new device 1;255 <0x72f9b520>
              50      01/19/17 22:30:58.770   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 1 devices found, 147 <0x72f9b520>
              50      01/19/17 22:30:58.779   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0 <0x72f9b520>
              02      01/19/17 22:30:58.780   luup_log:147: Arduino: Incoming internal command '1;255;3;0;6;0' discarded for child: nil <0x72f9b520>
              50      01/19/17 22:31:00.770   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor <0x72f9b520>
              02      01/19/17 22:31:00.773   luup_log:147: Arduino: Incoming internal command '1;255;3;0;11;Motion Sensor' discarded for child: nil <0x72f9b520>
              50      01/19/17 22:31:00.778   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0 <0x72f9b520>
              02      01/19/17 22:31:00.780   luup_log:147: Arduino: Incoming internal command '1;255;3;0;12;1.0' discarded for child: nil <0x72f9b520>
              50      01/19/17 22:31:00.785   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=1,c=0,t=1,pt=0,l=0,sg=0: <0x72f9b520>
              50      01/19/17 22:31:00.786   luup_log:147: Arduino: Presentation: 1;1;0;0;1; <0x72f9b520>
              50      01/19/17 22:31:00.787   luup_log:147: Arduino: Found new device 1;1 <0x72f9b520>
              50      01/19/17 22:31:00.787   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 2 devices found, 147 <0x72f9b520>
              50      01/19/17 22:31:00.791   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2 <0x72f9b520>
              50      01/19/17 22:31:00.834   luup_log:147: Arduino: Log: !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1 <0x72f9b520>
              50      01/19/17 22:31:15.240   luup_log:147: Arduino: Sending: 0;0;3;0;5;0 <0x779f6320>
              50      01/19/17 22:31:15.255   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 0, 147 <0x72f9b520>
              50      01/19/17 22:31:15.256   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, , 147 <0x72f9b520>
              50      01/19/17 22:31:15.257   luup_log:147: Arduino: Inclusion mode ended. <0x72f9b520>
              02      01/19/17 22:31:15.257   luup_log:147: Arduino: Found new sensor(s). Need to restart. Please wait. <0x72f9b520>
              09      01/19/17 22:31:25.244   JobHandler_LuaUPnP::Run device 151 Arduino Motion 1 (1) room 0 type urn:schemas-micasaverde-com:device:MotionSensor:1 cat 4:3   id 1;1 parent 147/0xa4f2e0 upnp: 0 plugin:0 pnp:0 mac: ip: <0x77022320>
              09      01/19/17 22:31:25.244   JobHandler_LuaUPnP::Run device 150 Arduino Node 1 room 0 type urn:schemas-arduino-cc:device:arduinonode:1 cat 0:-1 id 1;255 p  arent 147/0xa42710 upnp: 0 plugin:0 pnp:0 mac: ip: <0x77022320>
              50      01/19/17 22:31:30.107   luup_log:147: Arduino plugin: loading library L_Arduino ... <0x7645b520>
              50      01/19/17 22:31:30.131   luup_log:147: Arduino plugin: library L_Arduino loaded <0x7645b520>
              50      01/19/17 22:31:30.131   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 147 <0x7645b520>
              50      01/19/17 22:31:30.132   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, -, 147 <0x7645b520>
              50      01/19/17 22:31:30.132   luup_log:147: Arduino: Trying for a serial connection <0x7645b520>
              50      01/19/17 22:31:30.133   luup_log:147: Arduino: Serial port is connected <0x7645b520>
              50      01/19/17 22:31:30.133   luup_log:147: Arduino: Baud is 115200 <0x7645b520>
              50      01/19/17 22:31:30.133   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 149(115200), 147 <0x7645b520>
              50      01/19/17 22:31:30.135   luup_log:147: Arduino: Sending: 0;0;3;0;2;Get Version <0x7645b520>
              50      01/19/17 22:31:30.141   luup_log:147: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,ArduinoLibVersion, 2.1.0, 147 <0x7325b520>
              50      01/19/17 22:32:26.144   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1 <0x7325b520>
              50      01/19/17 22:32:26.145   luup_log:147: Arduino: Set variable: 1;1;1;0;16;1 <0x7325b520>
              50      01/19/17 22:32:26.146   luup_log:147: Arduino: Setting variable 'Tripped' to value '1' <0x7325b520>
              50      01/19/17 22:32:26.146   luup_log:147: Arduino: urn:micasaverde-com:serviceId:SecuritySensor1,Tripped, 1, 151 <0x7325b520>
              50      01/19/17 22:32:26.149   luup_log:147: Arduino: urn:micasaverde-com:serviceId:SecuritySensor1,LastTrip, 1484865146, 151 <0x7325b520>
              50      01/19/17 22:32:26.150   luup_log:147: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1484865146, 150 <0x7325b520>
              50      01/19/17 22:32:26.151   luup_log:147: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 22:32, 150 <0x7325b520>
              50      01/19/17 22:32:26.153   luup_log:147: Arduino: Log: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1 <0x7325b520>
              50      01/19/17 22:32:26.154   luup_log:147: Arduino: Set variable: 1;1;1;0;16;1 <0x7325b520>
              1. I compared the files on the Vera with those on thread https://forum.mysensors.org/topic/5289/ui5-to-ui7-update/13 - they are identical:
              root@OpenWrt:~# sha1sum /etc/cmh-ludl/*_Arduino*
              f9875310ea581c6384046dfd733dc5c9e436ef20  /etc/cmh-ludl/D_Arduino1.json.lzo
              e3c4493c7dff216c152b8a4d50c169acf636b1fc  /etc/cmh-ludl/D_Arduino1.xml.lzo
              8f0186c85c9a6ef6e0e8ba0755f88cbb5d326e30  /etc/cmh-ludl/D_ArduinoNode1.json.lzo
              7d66187bb75beb01606f607ad1e82a6fa6b2a552  /etc/cmh-ludl/D_ArduinoNode1.xml.lzo
              722b702937db7aedcb03346229fcc38363b2c378  /etc/cmh-ludl/D_ArduinoRelay1.json.lzo
              05ea89a8d904f436c60bd326315724e79c5c47de  /etc/cmh-ludl/D_ArduinoRelay1.xml.lzo
              ed15bfde68e6615b7615bd6230ca8040a50f5f28  /etc/cmh-ludl/I_Arduino1.xml.lzo
              2f0603b6192006f88e3582788a13a168391ceee4  /etc/cmh-ludl/L_Arduino.lua.lzo
              dc1e8a26833890f2d1f412c9b2e915724576cbd4  /etc/cmh-ludl/S_Arduino.xml.lzo
              64f886de376e2d932cd55bdf8a6367ed7a394d55  /etc/cmh-ludl/S_ArduinoNode.xml.lzo
              So - certainly there is a solution to use the serial gateway with Vera UI7 - but I'd very much like to get the Raspberry Pi gateway working too :-)
              Thanks for your help!
              • blaceyB blacey
                Cheers,
                Bruce
                P
                P
                pete1450
                @blacey
                I was using the serial gateway over a year ago with UI5. I decided to update to the new version and have tried UI5 and UI7 with both the serial-to-vera and raspi-as-ethernet gateways. Can't get the serial gateway to show up so I'm back to UI7 Ethernet trying to figure out what's getting lost in the messages. SHAs seem to match yours. I'm a little confused though. Aren't id's handed out by the controller only during inclusion? If I reboot my vera, start the gateway, and clear eeprom/upload a motion sketch, I get the output below. It looks like an id is handed out and I never touched the start button.
                root@MiOS_35029342:~# sha1sum /etc/cmh-ludl/*_Arduino*
                mysgw: Client 0:
                mysgw: TSF:MSG:READ,1-1-0,s=2,c=0,t=1,pt=0,l=0,sg=0:
                mysgw: TSF:MSG:READ,1-1-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                • anvilA
                  anvilA
                  anvil
                  Solved - user error :)
                  Inside the Raspberry Pi setup (file /MySensors/examples_linux/mysgw.cpp), the inclusion mode define must be added:
                  This is present in the Serial & Ethernet gateway example ino files, just missing from the Raspberry Pi version as it is on GitHub.
                  With this added, the response to the StartInclusion mode request is then received & everything is fine:
                  • TX(fromController) 0;0;3;0;5;1
                  • RX(fromRaspberryPiGateway) 0;255;3;0;5;1
                  On the plus side, by working this out I'm a lot more familiar with the workings of MySensors!
                  Cheers!
                  P blaceyB 2 Replies Last reply
                  • anvilA anvil
                    Cheers!
                    P
                    P
                    pete1450
                    @anvil Are you kidding me! That was it. I don't have a problem fiddling with the files but I assumed the step-by-step instructions would have laid that critical step out. Or for that matter why isn't it in the source to begin with?
                    • P pete1450
                      @pete1450 the world does not revolve around Vera. There are many other controllers, and some (all?) of the others don't need inclusion mode.
                      The Raspberry Pi Gateway is fairly new. My guess is that nobody has tried it with Vera before, so no-one noticed that there was a problem.
                        P
                        P
                        pete1450
                        @mfalkvidd I didnt realize it was a vera specific flag. By the name it sounds like something that would be needed to include sensors on any platform. If not, fair point.
                        • anvilA anvil
                          Cheers!
                          blaceyB
                          blaceyB
                          blacey
                          @anvil - great code sleuthing! I have been absent due to travel but to ensure this doesn't slip through the cracks and create future confusion for other users, I have filed GitHub issue https://github.com/mysensors/MySensors/issues/770 to add these defaults into the RPI gateway example for the 2.2.0 release.
                          With your increased familiarity with the code base, feel free to make the change and submit a GitHub PR if you are so inclined, otherwise it will wait until one of the core members makes the change.
